#521
Posted 19 April 2013 - 02:30 PM
#522
Posted 19 April 2013 - 02:46 PM
#523
Which brand/type did you use?
I have Schrick camshafts and valve springs. I was not going to bother with camshafts but I got them at very good price.
OBD software works fine with the cams but I am trying to achieve a flat idle. Every z22se engine with camshafts fitted has lumpy idle.
I have Comp Blower cams. No amount of mapping will give OE idle on high lift cams though.
#524
Posted 19 April 2013 - 02:49 PM
That blown up engine is really getting into your head huh.
Not so much killing the engine. That's kind of almost acceptable given the number of trackdays I'd done and the abuse it was given. It would certainly have been nicer for it to have happened to the OEM engine, before it had had all the forged bits fitted though.
It's more the whole Z22SE engine I don't like. The strained revability of an over-square engine (even with no balancers and lightweight fly, it still doesn't feel/sound like it likes it), the piston slap thing, the oversized bores with increased oil usage (and probably weakened liners as a result
Hence wanting to go to an OEM engine that's a bit stronger out of the box and hopefully retaining OEM reliability. No idea whether things like the piston oil jets really help (can't see them hurting though) but having stock bores, forged crankshaft, square dimensions, proper LSJ supercharger cams, etc, will hopefully make it a nicer engine all round. An extra 1.5 litres of oil in the sump probably isn't a bad thing (as long as it doesn't mean the crank drags through it on sustained high G cornering). Might even be nice to use the standard LSJ cam driven vacuum pump to keep the brake servo nicely topped up, whatever the throttle is doing. I'll probably give away some torque and peak bhp by losing the 200-300cc difference in capacity but I can live with that, as I thought the car was better balanced at 260bhp and a nicer drive than it is with 300bhp anyway. Sh!t, I've almost talked myself into going in to the garage again.
#525
Posted 19 April 2013 - 03:09 PM
#526
Posted 19 April 2013 - 03:10 PM
#527
Posted 19 April 2013 - 03:12 PM
Cliffie
The frustrating part is I have almost got it with the Schrick cams. I agree the wilder the cams get the lower the chance of getting good idle.
But then if we all chased perfection, none of us would have bought a VX220.
#528
Posted 19 April 2013 - 03:28 PM
I think you will love the characteristics of a 2.0 lsj or saab techie.
I know i did on a short demo.
I really hope so. Last chance saloon for the car, this time. I really do need to enjoy driving it again and if I don't like it after this, it's probably a case of scrounging up a vanilla Z22SE and getting rid, I think.
#529
Posted 19 April 2013 - 04:36 PM
Cliffie
True
#530
Posted 19 April 2013 - 04:50 PM
we're talking about the red marked in the picture when talking about "PCV"? Is that correct?
In the intake manifold is a valve that opens under negative pressure so gases can pass through at low throttle. This valve closes under boost so no boost can pump up crankcase.
This hole was closed (Z22SE head-hole and valve in the manifold are not in the right position together) at my first hitec conversion.
Since running the B207 engine the position is right. So the system works.
I sended Peter a mail about that... Or perhaps he answers here.
Edited by ultimate, 19 April 2013 - 04:51 PM.
#531
Posted 19 April 2013 - 06:01 PM
Edited by PaulCP, 19 April 2013 - 06:02 PM.
#532
Posted 19 April 2013 - 06:27 PM
Just been trying to read/take in today's posts
Fcuk my head hurts !
Just un-sorned the car today and it can stay as it is. - no more messing with it
I dont believe that Paul
#533
Posted 19 April 2013 - 08:40 PM
I dont believe that Paul :happy:/>
You're right, I'll need to get the oil changed
#534
Posted 19 April 2013 - 08:43 PM
#535
Posted 19 April 2013 - 09:52 PM
blower are idling ok here
#536
Posted 19 April 2013 - 10:35 PM
#537
Posted 19 April 2013 - 10:49 PM
#538
Posted 19 April 2013 - 10:57 PM
Edited by ultimate, 19 April 2013 - 11:00 PM.
#539
Posted 19 April 2013 - 11:56 PM
#540
Posted 27 April 2013 - 04:15 PM
The Market Place →
Car Parts For Sale →
Piper 2.5” Manifold And Miltek Mid Section For Z22seStarted by F757lkk@gmail.com , 30 Jun 2024 ![]() |
General Discussion →
Tuning & Modifications →
The Market Place →
Car Parts Wanted →
2.4L Intake Manifold (Gm12587878) For Z22SeStarted by HydroMike , 11 May 2020 ![]() |
VX220 Discussion →
Replacing The Ecu And Having IssuesStarted by den7 , 29 Feb 2020 ![]() |
VX220 Discussion →
Dbilas Turbo Kit - Z22SeStarted by Franke , 24 Feb 2020 ![]() |
6 user(s) are reading this topic
Bing (2)
