obdtuner remap z22se ecu
2116 replies to this topic
#601 oakmere
oakmere
  • 2,143 posts
Posted 05 May 2013 - 08:49 PM
Sorry I would have popped around if I knew you were so close you must be all of about 10 mins from my house. I will PM you when I get back next week.
#602 CHILL Gone DUTCH
Posted 05 May 2013 - 08:51 PM
:grouphug:
#603 2-20
2-20
  • 1,317 posts
Posted 05 May 2013 - 09:42 PM
Make sure you measure the rear wheel size by marking the tyre and roll the car until it reaches the same point and measuring the distance travelled in mm.
I realised that this point is very important and a key for realistic figures.
#604 davemate
davemate
    Harrop!!!
  • 3,228 posts
  • Interests:Provoking Badgers
Posted 07 June 2013 - 01:49 PM
I am wonderign if anyone can help me out. I am trying to answer/get the right parts for this software and my Harrop...
So far he has the following and needs the later bit of information:
Known
    [*][color=rgb(31,73,125);][font="calibri;"]Harrop 80mm pulley[/color][/font]
    [*][color=rgb(31,73,125);][font="calibri;"]Ported Saab head[/color][/font]
    [*][color=rgb(31,73,125);][font="calibri;"]Blower cams[/color][/font]
    [*][color=rgb(31,73,125);][font="calibri;"]Eagle rods[/color][/font]
    [*][color=rgb(31,73,125);][font="calibri;"]Siemens 60lb injectors[/color][/font]
    [*][color=rgb(31,73,125);][font="calibri;"]68mm throttle body[/color][/font]
    [/list]
    [color=rgb(31,73,125);][font="calibri;"]Unknown:[/color][/font]
      [*][color=rgb(31,73,125);][font="calibri;"](T)MAP sensor type?[/color][/font]
      [*][color=rgb(31,73,125);][font="calibri;"]Do you want to use the temperature sensor from the TMAP for measuring the boost temperature?[/color][/font]
      [*][color=rgb(31,73,125);][font="calibri;"]Engine RPM limiter setting?[/color][/font]
      [*][color=rgb(31,73,125);][font="calibri;"]Fuel pressure?[/color][/font]
      [*][color=rgb(31,73,125);][font="calibri;"]Max boost?[/color][/font]
      [/list]
      The first two parts are where I am lost, if anyone can point in int he right diection of getting the correct info for this this please do help :)
      Fuel pressure with the siemens injectors does not need to be changed as far as I am aware, so standard? :unsure:
      Max boost? no idea!
      RPM setting, i am on a saab ported head from vocky.
      My car specs are as follows. 2.5" free flowing exhaust, it got great results and is a true 2.5" system (i am aware that this may still be a bottle neck)
      harrop on the provided 80mm pulley.
      eagle rods
      blower cams
      balance shafts removed
      Saab head exhaust ported
      i do not have any additional cooling such as water injection.
      Edited by davemate, 07 June 2013 - 01:50 PM.
#605 CHILL Gone DUTCH
Posted 07 June 2013 - 01:53 PM
Have you spoke to Peter He is always happy to help and give guidance
Edited by Chill, 07 June 2013 - 01:53 PM.
#606 ArticMonkey
ArticMonkey
  • 4,792 posts
Posted 07 June 2013 - 01:57 PM
What about pistons and compression ratio?
#607 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 07 June 2013 - 02:01 PM
[color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]MAP Sensor (2.5 Bar)... Bosch # [/color][color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]0 261 230 042[/color][color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;] begin_of_the_skype_highlighting 0 261 230 042 [/color][color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]...... 0.2 to 2.5 Bar ie Max 1.5 Bar of boost[/color]
[color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]MAP Sensor (3.0 Bar)... Bosch # [/color][color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]0 281 002 437[/color][color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;] begin_of_the_skype_highlighting 0 281 002 437 [/color][color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]...... 0.2 to 3.0 Bar ie Max 2.0 Bar of boost[/color]
[color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]either will work with Peters software I believe[/color]
[color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]Tmap will use the oem temp sensor taken from the intake pipe which will then read temp alongside the [/color]
use the oem  fuel pressure regulator with the 630cc injectors will be ok.
RPM is what you like I suggest not over 7200 if you don't have double valve springs
Boost will depend on the size of the pulley you use
Edited by NickB777, 07 June 2013 - 02:07 PM.
#608 davemate
davemate
    Harrop!!!
  • 3,228 posts
Posted 07 June 2013 - 02:36 PM
Thankyou gentlemen.
It was peter that asked the question, so i assumed i needed to get the information for him.
Compression ratio is 8.9:1 on overbore wiseco pistons.
I havebeen told that the saab head has better springs than the stadnard head and therefore will stand up to more. but agree a circa 7k rev limit is wise till i can upgrade to be sure. Without additional cooling keeping it lower is probably best.
Does anyone know a cheap source for the map sensor?
#609 techieboy
Posted 07 June 2013 - 02:38 PM
eBay has millions of them as the 2.5bar and 3.0bar sensors seemed to be fitted to just about everything GM have ever made and at decent prices to. Just make sure you get a genuine Bosch one.
#610 NickB787
NickB787
  • 7,813 posts
Posted 07 June 2013 - 02:41 PM
Saab valves are better for turbo/S/C setup not certain what their max revs would be, ebay for the TMAP sensor numbers above.
#611 techieboy
Posted 07 June 2013 - 02:42 PM
Here's a 3.0bar Bosch MAP with the OEM loom plug still attached for a proper install. Just need to modify the loom for the existing MAP and the existing IAT sensor and connect them into this plug and bingo, you've got intake temps as well as pressure measured in the manifold and not intake temps measured pre-charger
#612 NickB787
NickB787
  • 7,813 posts
Posted 07 June 2013 - 02:45 PM
http://www.ebay.co.u...=item43bb3d239f
grab this Dave, I'll get another plug
#613 CHILL Gone DUTCH
Posted 07 June 2013 - 02:51 PM
These are the sensors supported by Dutch ECU
#614 davemate
davemate
    Harrop!!!
  • 3,228 posts
Posted 07 June 2013 - 02:55 PM
Bought :)
awesome, thanks Nick.
#615 davemate
davemate
    Harrop!!!
  • 3,228 posts
Posted 07 June 2013 - 02:56 PM
And thanks for the pic of the list Chill, that was very useful and reassuring to see the code on the list.
#616 NickB787
NickB787
  • 7,813 posts
Posted 07 June 2013 - 03:05 PM
I have sent Peter an email but anyone used or know if I can use a PLX sideband?
http://www.plxdevice...d=WDBDSMAFR_DM6
#617 techieboy
Posted 07 June 2013 - 03:07 PM
It'll work fine. As long as you've obviously got the controller with it, it'll output what the ECU needs for logging.
#618 NickB787
NickB787
  • 7,813 posts
Posted 07 June 2013 - 03:10 PM
I have the controller box with it just thinking about input to the erg valve plug
#619 davemate
davemate
    Harrop!!!
  • 3,228 posts
Posted 07 June 2013 - 03:13 PM
That does look pretty neat.
#620 CHILL Gone DUTCH
Posted 07 June 2013 - 03:16 PM
Info required by program
