#621
Posted 07 June 2013 - 03:17 PM
#622
Posted 07 June 2013 - 03:25 PM
the PLX is
0v = 10AFR
5v = 20AFR
wonder if you can change the software perimeters
#623
Posted 07 June 2013 - 03:29 PM
#624
Posted 07 June 2013 - 03:32 PM
Edited by Chill, 07 June 2013 - 03:32 PM.
#625
Posted 07 June 2013 - 03:33 PM
Says you can in the manual.the PLX is 0v = 10AFR 5v = 20AFR wonder if you can change the software perimeters
#626
Posted 07 June 2013 - 03:34 PM
How would you connect it up if your using egr wiring
Good point! doh.
#627
Posted 07 June 2013 - 03:35 PM
Unless gauge is from more wiring from the sensorGood point! doh.How would you connect it up if your using egr wiring
#628
Posted 07 June 2013 - 03:36 PM
#629
I would have throught i could get the data out through OBD anyway...
#630
Posted 07 June 2013 - 03:37 PM
Are you using scanguageI would have throught i could get the data out through OBD anyway...
#631
Posted 07 June 2013 - 03:40 PM
Most of the info being discussed is in the Manual. The latest version has info about the wide band and Tmap sensor and how to connect them.
I'll download the latest version thanks
#632
http://www.14point7.com/
#633
Posted 07 June 2013 - 03:42 PM
#634
Posted 07 June 2013 - 03:46 PM
don't do that.
I need to get the emulator sorted so i can use the mac.
#635
Posted 07 June 2013 - 03:49 PM
Don't bring me into this. I've read the manual and know how it works.
#636
Posted 07 June 2013 - 03:51 PM
#637
Posted 07 June 2013 - 03:54 PM
The difference is, you're using it for real, so need to know the minutiae. I've just read it out of interest to see how flexible it is and understand how the TMAP, injector scaling and wideband in lieu of EGR work.
#638
Posted 07 June 2013 - 04:00 PM
O good in that case I have a job for you
#639
Posted 07 June 2013 - 04:22 PM
Compression ratio is 8.9:1 on overbore wiseco pistons.
So more like CR = 9.4 with a Z22se Head gasket
#640
Posted 07 June 2013 - 05:54 PM
[color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]MAP Sensor (2.5 Bar)... Bosch # [/color][color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]0 261 230 042[/color][color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;] begin_of_the_skype_highlighting 0 261 230 042 [/color][color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]...... 0.2 to 2.5 Bar ie Max 1.5 Bar of boost[/color]
[color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]MAP Sensor (3.0 Bar)... Bosch # [/color][color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]0 281 002 437[/color][color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;] begin_of_the_skype_highlighting 0 281 002 437 [/color][color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]...... 0.2 to 3.0 Bar ie Max 2.0 Bar of boost[/color]
[color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]either will work with Peters software I believe[/color]
[color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]Tmap will use the oem temp sensor taken from the intake pipe which will then read temp alongside the [/color]
use the oem fuel pressure regulator with the 630cc injectors will be ok.
RPM is what you like I suggest not over 7200 if you don't have double valve springs
Boost will depend on the size of the pulley you use
Harrop with 80mm pulley and decent exhaust should stay below 1.5 bar boost, so use the 2.5 TMAP for best resolution.
Ehh, point of the TMAP sensor is to move the T sensor from intake pipe to the manifold. So lengthen the Z22SE IAT sensor signal (1 wire only) to the manifold and wire it up according the scheme.
Std Z22SE fuel regulator (3.8 bar) is perfect for the 630's
Saab valvesprings are same as Z22SE and with higher lift blower cams I would even stay below 7000. But surprised your ported head had no stiffer springs fitted?
Boost is also dependent on exhaust backpressure. My mate on a 80mm Harrop and 2,5 system gets around 1.25bar, but revs to 7600rpm. ;-)
Edited by Exmantaa, 07 June 2013 - 05:55 PM.
The Market Place →
Car Parts For Sale →
Piper 2.5” Manifold And Miltek Mid Section For Z22seStarted by F757lkk@gmail.com , 30 Jun 2024 ![]() |
General Discussion →
Tuning & Modifications →
The Market Place →
Car Parts Wanted →
2.4L Intake Manifold (Gm12587878) For Z22SeStarted by HydroMike , 11 May 2020 ![]() |
VX220 Discussion →
Replacing The Ecu And Having IssuesStarted by den7 , 29 Feb 2020 ![]() |
VX220 Discussion →
Dbilas Turbo Kit - Z22SeStarted by Franke , 24 Feb 2020 ![]() |
