Advantage of doing that on a dyno is more consistent and smoother power runs, so you'll be able to fine tune the ignition timing better.
#681
Posted 11 August 2013 - 10:47 AM
#682
Posted 11 August 2013 - 10:53 AM
This is the only problem of doing it on road the software does pick up every bump in the road But you could get it close then fine tune at RRAdvantage of doing that on a dyno is more consistent and smoother power runs, so you'll be able to fine tune the ignition timing better.
#683
Posted 11 August 2013 - 02:05 PM
#684
Posted 11 August 2013 - 02:07 PM
Chill we need to find a nice flat straight road around here that is very quite?This is the only problem of doing it on road the software does pick up every bump in the road But you could get it close then fine tune at RRAdvantage of doing that on a dyno is more consistent and smoother power runs, so you'll be able to fine tune the ignition timing better.
#685
Posted 11 August 2013 - 02:09 PM
Yes we do good luck with that its pot hole heavenChill we need to find a nice flat straight road around here that is very quite?This is the only problem of doing it on road the software does pick up every bump in the road But you could get it close then fine tune at RRAdvantage of doing that on a dyno is more consistent and smoother power runs, so you'll be able to fine tune the ignition timing better.
Edited by CHILL Gone DUTCH, 11 August 2013 - 02:32 PM.
#686
Posted 11 August 2013 - 02:29 PM
I've found parts of MK are ideal for power runs, go up the road one way, around the roundabout and back down. That way you're taking into account the change in altitude.
Roads are sh*t though. I think we need to build in some mapping time into a euro trip.
#687
Posted 11 August 2013 - 03:12 PM
or do a group hire of a dyno?
#688
Posted 11 August 2013 - 03:16 PM
#689
Posted 11 August 2013 - 03:29 PM
Edited by Bumblebee, 11 August 2013 - 03:29 PM.
#690
Posted 11 August 2013 - 03:50 PM
Yes I spoke to him before I did my conversion and he said the Dutch software looked impressive and he asked for a link to the software.I can vouch for Chris (efi parts) he's done a lot of work on the family's cars over the years and he really knows his stuff
#691
Posted 11 August 2013 - 07:49 PM
#692
Posted 19 August 2013 - 03:00 PM
#693
Posted 19 August 2013 - 03:09 PM
I got mine back in about 5 days, 2 days to send with peter for a day or less then 2 days to get back so if you send on a Monday you could have by friday.
Can't help with the rest as mine is still sitting in my desk draw cos I'm a lazy ass!
#694
Posted 19 August 2013 - 03:16 PM
there should not be a need to send it over to holland , just writing a new bin file onto the ecu would just take 10 minutes.
#695
Posted 19 August 2013 - 03:19 PM
And how would that work with the only bin writer being located in Peters attic?
Edited by smiley, 19 August 2013 - 03:24 PM.
#696
Posted 19 August 2013 - 03:26 PM
Edited by NickB777, 19 August 2013 - 03:28 PM.
#697
Posted 19 August 2013 - 03:27 PM
I can read and write thats the easy bit, cable adaptor is the same that Peter supplies . You need a laptop to use the obd tune software .
Opel Speedster 2.2 16V 147hp Z22SE petrol/gasoline engine Delco GMPT E15 Hw 12202073 BZ Sw 12210633
#698
Posted 19 August 2013 - 03:43 PM
I bet you can.
But why would he hand over the sourcecode of 6 years of labour?
#699
Posted 19 August 2013 - 04:27 PM
tbh if I wanted to reverse engineer peters windows software , the editing tool , then I could.
#700
Posted 19 August 2013 - 05:39 PM
The magic is in the serverside software, not the client.
But go ahead i would say. See if you can crack the encryption
The Market Place →
Car Parts For Sale →
Piper 2.5” Manifold And Miltek Mid Section For Z22seStarted by F757lkk@gmail.com , 30 Jun 2024 ![]() |
General Discussion →
Tuning & Modifications →
The Market Place →
Car Parts Wanted →
2.4L Intake Manifold (Gm12587878) For Z22SeStarted by HydroMike , 11 May 2020 ![]() |
VX220 Discussion →
Replacing The Ecu And Having IssuesStarted by den7 , 29 Feb 2020 ![]() |
VX220 Discussion →
Dbilas Turbo Kit - Z22SeStarted by Franke , 24 Feb 2020 ![]() |
