obdtuner remap z22se ecu
2116 replies to this topic
#701 ArticMonkey
ArticMonkey
  • 4,792 posts
Posted 19 August 2013 - 05:40 PM
Right just got back from my holiday didn't spend as much money as I thought ;-) so have just emailed Peter about ecu and am going ahead with this few questions people ? How long does it take after ecu sent to get it back ? Who wants a drive in and help me map my beast ? Who has got some 630 injectors they want to sell ?
Just txt you. :)
#702 leevx2.2
leevx2.2
  • 4,830 posts
    getting p!!sed
Posted 19 August 2013 - 05:58 PM
Can I use a secondary lambda cheat with this software ?
#703 leevx2.2
leevx2.2
  • 4,830 posts
    getting p!!sed
Posted 19 August 2013 - 06:00 PM
About 5 days I am here Lee, should be mapping mine again soon Davemate had some spare a few weeks ago, drop him a pm, or see who has them in a box on the shelf and replace them with zip ones they took about a week to get here. You going to see if he will do v3 as it allows for WI and different maps?
V3 ?
#704 ArticMonkey
ArticMonkey
  • 4,792 posts
Posted 19 August 2013 - 06:16 PM
V3 ?
Version 3.
#705 smiley
Posted 19 August 2013 - 06:20 PM
V3 is not public yet guys.
#706 ArticMonkey
ArticMonkey
  • 4,792 posts
Posted 19 August 2013 - 06:27 PM
When, when, when!
#707 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 19 August 2013 - 06:54 PM
Peter suggested that we leave the second lambda in place.
#708 smiley
All i mentioned was that peter was testing it when i met him.
He's at Zandvoort with LOT coming friday. I'll ask what his plans are.
#709 oakmere
oakmere
  • 2,143 posts
Posted 19 August 2013 - 08:04 PM
The second lambda is needed as a fail safe but it will not throw an eml if you have no cat or a sports cat. I would love to help but unfortunately don't live anywhere near you. I can help with any questions you might have. You will need a wide band to map your car safely.
Edited by oakmere, 19 August 2013 - 08:08 PM.
#710 fezzasus
Posted 19 August 2013 - 09:51 PM
Lee, I might be able to help depending when you get it. I've had mine running for about a month and am very happy with it.
#711 slindborg
Posted 19 August 2013 - 10:18 PM
I'd like a nosey :)
#712 ArticMonkey
ArticMonkey
  • 4,792 posts
Posted 19 August 2013 - 10:25 PM
I'd like a nosey :)
Ill have it fitted soonish and you're only 20mins away. ;)
#713 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 19 August 2013 - 10:43 PM
So which map sensor have you guys bought or could the one we have fitted work fine. Ive got my injectors and wideband sorted now so is there anything else I'm going to need to buy?
#714 Exmantaa
Posted 19 August 2013 - 10:49 PM
You can choose to use your existing SC 2 bar Delphi MAP sensor, or rewire the IAT for the Bosch TMAP sensor. (search)
(The 2.5 bar verdsion should be enough for most serious SC builds)
#715 ArticMonkey
ArticMonkey
  • 4,792 posts
Wide band sensor protector and a 2.5BAR Bosch map sensor which are common as muck.
#716 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 19 August 2013 - 11:00 PM
Sounds good. Il get them ordered and then hopefully it's just the mapping then to sort out. What bhp are you harrop lads running with this software?
#717 Bargi
Bargi
  • 4,483 posts
Posted 20 August 2013 - 06:23 AM
All i mentioned was that peter was testing it when i met him. He's at Zandvoort with LOT coming friday. I'll ask what his plans are.
Excellent, guess I'll see you guys there Friday. Can heap the car on the day if I pay him cash :D
#718 fezzasus
Posted 20 August 2013 - 07:20 AM
so far I think it's only Davemate and I'm not sure if he's RR'ed it. Generally speaking the max bhp won't change compared to a CS map, but the fueling between idle and open throttle will be much better and a result of that will be more power across the rev range.
#719 Bargi
Bargi
  • 4,483 posts
Posted 20 August 2013 - 07:26 AM
That should say map the car!
#720 CHILL Gone DUTCH
Posted 20 August 2013 - 01:24 PM
I will do the mapping lee
    Bing (1)
