obdtuner remap z22se ecu
2116 replies to this topic
#721 CHILL Gone DUTCH
Posted 20 August 2013 - 01:27 PM
Can I use a secondary lambda cheat with this software ?
No it needs second lambda and you will need wide band
#722 CHILL Gone DUTCH
Posted 20 August 2013 - 01:34 PM
I will be available from the 2 sept
#723 slindborg
Posted 20 August 2013 - 03:33 PM
why does it need the second lambda sensor? its only narrow band so next to fecking useless.
#724 Chris P Duck
Chris P Duck
    I can change this?
  • 1,506 posts
Posted 20 August 2013 - 04:19 PM
From the "Overview" page on his website "Programmable catalytic converter check" So I'd assume that no, it doesn't need the 2nd Lambda sensor. You also don't need a "cheater" you just disable the check.
Edited by Chris P Duck, 20 August 2013 - 04:24 PM.
#725 davemate
davemate
    Harrop!!!
  • 3,228 posts
  • Interests:Provoking Badgers
Posted 20 August 2013 - 04:55 PM
Davemate had some spare a few weeks ago, drop him a pm, or see who has them in a box on the shelf and replace them with zip ones they took about a week to get here.
I had two sets, sold tem to Arctic and Bargi... They got a bargain too :)
#726 smiley
Posted 20 August 2013 - 06:13 PM
Disabling in the software does not mean eligable for removal iirrc. The presence check remains.
#727 Chris P Duck
Chris P Duck
    I can change this?
  • 1,506 posts
Posted 20 August 2013 - 08:31 PM
Really? Not claiming that I know but I can't see any logic for that. So the sensors doesn't do anything but it still checks that the sensor is there?
#728 smiley
Posted 20 August 2013 - 08:57 PM
95%. Can't find the discussion atm :mellow:
#729 rik
rik
  • 2,187 posts
Posted 20 August 2013 - 09:07 PM
That option just disables the EML for the emissions check  - when the cat is malfunctioning (or missing :rolleyes: )
EML will still come on if the lambda sensor itself is not plugged in or faulty in another way
We discussed this earlier in either this thread or chill's thread but the 2nd lambda is still used to "back up" the first one, possibly to make it more accurate or in case of failure
#730 slindborg
Posted 22 August 2013 - 05:38 PM
There is no way in hell it can make the system more accurate. It is only a simple bang bang sensor.
#731 siztenboots
Posted 23 August 2013 - 07:49 AM
calibrated correctly , arguably you could discard both sensors.
#732 slindborg
Posted 23 August 2013 - 10:04 AM
yes, with proper calibration and software you 'could' run open loop and have things still accurate enough and less breakages to worry about. although that does then put all your eggs in the inlet sensors being right basket.
#733 smiley
Posted 23 August 2013 - 10:33 PM
All i mentioned was that peter was testing it when i met him. He's at Zandvoort with LOT coming friday. I'll ask what his plans are.
Excellent, guess I'll see you guys there Friday.
He wants to cram more functionality into v3 then just water injection and multimap, so this is not gonna happen/released any time soon.
#734 Chris P Duck
Chris P Duck
    I can change this?
  • 1,506 posts
Posted 31 August 2013 - 02:07 PM
Go on, you know you want to speculate! Start some rumours!
Edited by Chris P Duck, 31 August 2013 - 02:09 PM.
#735 Bargi
Bargi
  • 4,483 posts
Posted 04 September 2013 - 04:20 PM
Chaps got a quick question.
I've taken the plunge and money and ECUs are on their way to Holland
Peter has come back to me asking for my spec which is the regular CS setup and said the following.
[font="arial;font-size:small;"]I think the MAP sensors from Courtenay Sport cannot measure the boost[/font]
[font="arial;font-size:small;"]temperature, for this you will need a TMAP sensor from Bosch and you have[/font]
[font="arial;font-size:small;"]to modify your wiring loom to make it work[/font]
What's the modifications needed with the M62 in place to fit it?
I have the 2.5bar TMAP sensor in prep for the Harrop later, but if it's a benefit to fit it now and it's not to hard I'm thinking why not?
#736 CHILL Gone DUTCH
Posted 04 September 2013 - 04:32 PM
The instruction give details of installing section 9.12 I think
#737 Exmantaa
Posted 04 September 2013 - 05:10 PM
The 2.5 TMAP is the OEM GM fitment on the M62 LSJ engine, so you would have very few issues fitting it on an M62 Z22SE...  :happy:
#738 smiley
Posted 08 September 2013 - 06:40 PM
2.6.1.2 released.
Different way of selecting injectors, and fuel pressure selection.
(have not tried it myself yet)
Edited by smiley, 08 September 2013 - 06:41 PM.
#739 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 09 September 2013 - 06:41 AM
Will download it when I get back
#740 speedster
speedster
    Future of Speed
  • 3,600 posts
Posted 12 September 2013 - 09:01 AM
What type/level of improvements have users of this software achieved/achieving?
