obdtuner remap z22se ecu
2116 replies to this topic
#821 CHILL Gone DUTCH
Posted 22 December 2013 - 07:29 PM
I am keeping the standard internals 2.0L for higher rev range,M32 charger , 2.5" Tullett full system, CS mapping, VXT injectors will be added on the final mapping when run in.
surely the rev range will be limited by the efficiency of the charger rather than the 2,0 litre??
#822 Kieran McC
Kieran McC
  • 3,416 posts
Posted 22 December 2013 - 07:46 PM
Rev range should be good for 7500 so I am told,plus  6 speed gear box LOL
#823 CHILL Gone DUTCH
Posted 22 December 2013 - 07:48 PM
yes that gear box will do nicely  B)
#824 Kieran McC
Kieran McC
  • 3,416 posts
Posted 22 December 2013 - 07:52 PM
Had to have a new fly wheel machined to fit , This gear box should be bomb proof with the amount of work and money spent on it.Its cost more than the bloody engine.
Edited by kieranmcc, 22 December 2013 - 07:53 PM.
#825 Bargi
Bargi
  • 4,483 posts
Posted 22 December 2013 - 10:02 PM
When you get it remapped Kieran can you ask the duty cycle of the VXT injectors, when I had the duty cycle was over 92% , which is bad should be below 80% to give ECU enough range for injecting more fuel Peter was very quick to pick up on this when I first sent him my setup, he said VXT injectors would be over 90% duty cycle ( 3.1 pulley).
How small is the pulley your using Kieran?
I maxed out tubby injectors with a 3inch.
Are you sure you're CS aren't putting VXR ones on?
#826 CHILL Gone DUTCH
Posted 22 December 2013 - 10:04 PM
CS also mapped john turbo SC with 3.1 pulley with turbo injectors Unless they were changed
Edited by CHILL Gone DUTCH, 22 December 2013 - 10:05 PM.
#827 JohnTurbo
JohnTurbo
    SuperScruff
  • 3,635 posts
  • Interests:Performance cars!
Posted 22 December 2013 - 10:17 PM
They will map the m62/2.2 with a 6750rpm limit with the 3.1" pulley.
I had the 3.35" on and then swapped to the 3.1" later - it tugged a touch harder. Went back to 3.35" before it moved on just so it was safe for new owner.
#828 CHILL Gone DUTCH
Posted 22 December 2013 - 10:19 PM
They will map the m62/2.2 with a 6750rpm limit with the 3.1" pulley.   I had the 3.35" on and then swapped to the 3.1" later - it tugged a touch harder. Went back to 3.35" before it moved on just so it was safe for new owner.
Cheers for clearing that up john it's something I have been trying to get a answer to for some time
#829 smiley
Posted 22 December 2013 - 10:40 PM
Going over the tubby injector limits can also have to do with the lifespan of the fuelpump, filter etc.
In my case the standard stage II ran lean with the turbo injectors, and i switched to vxr's to fix that.
#830 smiley
Posted 23 December 2013 - 09:51 PM
Just noticed version 2.7
Website now updated with changelog :)
[color=#000000;font-family:Verdana, 'sans-serif';font-size:8.5pt;]Version 2.7.1.6[/color]
  • [color=#000000;font-family:Verdana, 'sans-serif';font-size:8.5pt;]More realistic injector times in fuel tables. The underlying calibration has not changed, only the view on the calibration has been changed. So do NOT not copy the injector times from the old PC software versions into this new version. From now on only use this version to view all your calibration files.[/color]
  • [color=#000000;font-family:Verdana, 'sans-serif';font-size:8.5pt;]Warning to first make the new calibration permanent when parameters are changed.[/color]
  • [color=#000000;font-family:Verdana, 'sans-serif';font-size:8.5pt;]More realistic power numbers above 300 hp.[/color]
  • [color=#000000;font-family:Verdana, 'sans-serif';font-size:8.5pt;]Problem fixed for boost pressures higher than 2.6 bar.[/color]
  • [color=#000000;font-family:Verdana, 'sans-serif';font-size:8.5pt;]Part numbers added to dropdown list.[/color]
#831 CHILL Gone DUTCH
Posted 23 December 2013 - 09:56 PM
<p>
 Website now updated with changelog :) [color=#000000;][font="Verdana;"]Version 2.7.1.6[/color][/font]
    [*][color=#000000;][font="Verdana;"]More realistic injector times in fuel tables. The underlying calibration has not changed, only the view on the calibration has been changed. So do NOT not copy the injector times from the old PC software versions into this new version. From now on only use this version to view all your calibration files.[/color][/font]
    [*][color=#000000;][font="Verdana;"]Warning to first make the new calibration permanent when parameters are changed.[/color][/font]
    [*][color=#000000;][font="Verdana;"]More realistic power numbers above 300 hp.[/color][/font]
    [*][color=#000000;][font="Verdana;"]Problem fixed for boost pressures higher than 2.6 bar.[/color][/font]
    [*][color=#000000;][font="Verdana;"]Part numbers added to dropdown list.[/color][/font]
    [/list]
What does that actually mean
#832 fezzasus
Posted 23 December 2013 - 10:20 PM
<p>
    [/list]
The way the injector timing is illustrated in the program has changed, however the configuration in the ECU has not. Everything else on the list appears to be bug fixes and functionality improvement.s
#833 Kieran McC
Kieran McC
  • 3,416 posts
Posted 24 December 2013 - 02:55 PM
Edit I spoke to Jon last night They are VXR injectors.
#834 alanoo
alanoo
  • 1,324 posts
Posted 27 December 2013 - 12:31 PM
Not with the standard valve springs
#835 CHILL Gone DUTCH
Posted 27 December 2013 - 12:34 PM
I'm will be trying 7500rpm on standard valve springs
#836 s-express
s-express
  • 311 posts
  • Interests:cars (obviously) but also turning into a bit of a conservationist....which doesn't really make sense...
Posted 27 December 2013 - 01:49 PM
Eek! I wouldn't. I started to drop a valve due to running stnd springs with piper cams. Luckily I caught it before it dropped in. The stnd valve springs allowed valve bounce which allowed the collets to chew away on the valve stems.
#837 CHILL Gone DUTCH
Posted 27 December 2013 - 02:07 PM
Thanks for heads up maybe I will keep mine around 7350rpm just in case
#838 ArticMonkey
ArticMonkey
  • 4,792 posts
Posted 27 December 2013 - 05:10 PM
Or buy some springs like the dutch guys did? You've spent ££££ and forged the engine so why skimp on this area?
Edited by ArticMonkey, 27 December 2013 - 05:10 PM.
#839 CHILL Gone DUTCH
Posted 27 December 2013 - 05:19 PM
If I'm being really honest I can't see the point of reving a M62 charger past 7250 rpm with anything less than a 3.1 pulley (maybe bigger) Unless/Untill we come up with a effective way of cooling the air
Edited by CHILL Gone DUTCH, 27 December 2013 - 05:19 PM.
#840 ArticMonkey
ArticMonkey
  • 4,792 posts
Posted 27 December 2013 - 05:27 PM
Fair enough.
    Bing (1)
