obdtuner remap z22se ecu
2116 replies to this topic
#881 CHILL Gone DUTCH
Posted 28 December 2013 - 03:56 PM
Do you have to do it off the cam lobes then?
Yes I think so. I assume Saab had a tool to lock the cams in position before the sprockets are bolted on. The good thing with them is you can adjust the cam timing.
The sprocket does have the bigger hole for using the checking tool after turning the engine manually 720 degrees
#882 CHILL Gone DUTCH
Posted 28 December 2013 - 03:58 PM
As seen here
#883 CHILL Gone DUTCH
Posted 29 December 2013 - 04:09 PM
1. Artic
2. Bargi
3.Chill   ASAP
4. Tony H
are we all ready to order these
#884 ArticMonkey
ArticMonkey
  • 4,792 posts
Posted 29 December 2013 - 04:32 PM
Yep
#885 CHILL Gone DUTCH
Posted 29 December 2013 - 05:34 PM
are you speaking for all the others if so lets do it,
i really want my saab engine asap
#886 Bargi
Bargi
  • 4,483 posts
Posted 29 December 2013 - 06:49 PM
Make it so
#887 CHILL Gone DUTCH
Posted 29 December 2013 - 07:55 PM
Are you sorting this one stu I'm hoping to get my engine in before end of jan
#888 smiley
Posted 29 December 2013 - 08:27 PM
Would it not be handy to create 1 central B207 conversion thread, and try to keep all stuff in it?
Now all major technical stuff is splattered in a group buy topic, a cams topic and a software topic.
#889 CHILL Gone DUTCH
Posted 29 December 2013 - 08:39 PM
Would it not be handy to create 1 central B207 conversion thread, and try to keep all stuff in it? Now all major technical stuff is splattered in a group buy topic, a cams topic and a software topic.
Yes I've struggled finding the right thread myself
#890 Tony H
Tony H
    Lotus on Crack
  • 1,729 posts
Posted 29 December 2013 - 09:05 PM
Whose flywheel are we buying?
#891 CHILL Gone DUTCH
Posted 29 December 2013 - 09:07 PM
I think matt Bentley is organising a group buy
#892 ArticMonkey
ArticMonkey
  • 4,792 posts
Posted 29 December 2013 - 09:12 PM
back to work in the morn so could you take the lead on this one? :) start a new thread on it all, you'll have minimum of 4 for the GB.
#893 CHILL Gone DUTCH
Posted 30 December 2013 - 11:52 AM
bargi
artic
and tonyH
please look here asap
http://www.vx220.org...-valve-springs/
#894 smiley
Posted 03 January 2014 - 08:25 PM
The forum on obdtuner.com is now enabled chinky chinky
#895 CHILL Gone DUTCH
Posted 03 January 2014 - 08:27 PM
 peter said he was looking in to this,
#896 CHILL Gone DUTCH
Posted 04 January 2014 - 09:09 AM
Turns out somone has tried obd tuner on a Astra and all other functions like traction control are working
#897 oakmere
oakmere
  • 2,143 posts
Posted 10 January 2014 - 07:21 PM
Latest version of OBD tuner has revised power settings putting torque where it should be (lower). Power is also slightly lower. Peter has re-calibrated the software to a hub dyno where multiple runs were done.
#898 CHILL Gone DUTCH
Posted 10 January 2014 - 08:03 PM
Yes I have lost 12 ponies on the new version
#899 CHILL Gone DUTCH
Posted 10 January 2014 - 08:04 PM
Which means I can add more advance to my ignition
#900 oakmere
oakmere
  • 2,143 posts
Posted 10 January 2014 - 08:48 PM
I have lost 6 bhp and 15 Nm. Peter now thinks it is much more accurate. My graph is now making peak power higher in the rev range are you seeing the same Chill?
