Edited by CHILL Gone DUTCH, 10 January 2014 - 08:59 PM.
#901
Posted 10 January 2014 - 08:58 PM
#902
Posted 10 January 2014 - 08:59 PM
#903
Posted 10 January 2014 - 09:01 PM
If it's Tmap its in instructions, Can't link it as I'm on phone at a B day partyAnyone got the guide for when I come to fit my map sensor. I've seen it somewhere but can't remember where.
#904
Posted 10 January 2014 - 09:10 PM
#905
Posted 11 January 2014 - 05:47 PM
#906
Posted 11 January 2014 - 07:35 PM
#907
Posted 16 January 2014 - 11:08 PM
been away from this thread and site a while
so what do we think about this ecu option ?
is it worth doing even if you just fit the 2.4 manifold ??
a must for sc'ing ?
worth a laugh even on a standard car ????
Edited by Baron Von Scubadaddy, 16 January 2014 - 11:08 PM.
#908
Posted 16 January 2014 - 11:32 PM
I would say no for NA (silly), and No for 2.4 (just get a CS map it, or live with the new behaviour)
For SC it's definitly a must, as the current used CS/klasen/hitec/dbilas mapping is a compromise with some quirks.
To verify the last, just ask anybody here who has switched to obdtuner on their SC.
Edited by smiley, 16 January 2014 - 11:33 PM.
#909
Posted 17 January 2014 - 02:52 AM
What was conclusion to this?Chaps got a quick question.
I've taken the plunge and money and ECUs are on their way to Holland
Peter has come back to me asking for my spec which is the regular CS setup and said the following.
[font="arial;"]I think the MAP sensors from Courtenay Sport cannot measure the boost[/font]
[font="arial;"]temperature, for this you will need a TMAP sensor from Bosch and you have[/font]
[font="arial;"]to modify your wiring loom to make it work[/font]
What's the modifications needed with the M62 in place to fit it?
I have the 2.5bar TMAP sensor in prep for the Harrop later, but if it's a benefit to fit it now and it's not to hard I'm thinking why not?
#910
Posted 17 January 2014 - 05:00 AM
#911
Posted 17 January 2014 - 07:47 AM
Somewhat longer answer. Use TMAP when you track. I've been on MAP and IAT for far over a year now in complete ignorance and never had an issue. But I don't track. That means WOT 1% of the time and the engine bay doesn't get heat soaked. As OBDTuner calculates air density using the IAT, it thinks the air is cooler than it actually is, which comes down to overfueling. With an IAT of 20C and a real T after SC of 60C it comes down to about 10% overfueling. That's not too bad (I think). And I don't think that under normal conditions (driving not to far from legal limits in NL or the UK) you'll reach 60C.
I'm about to order a TMAP sensor and put it in, but that's more because I'm looking for something to do
#912
Posted 17 January 2014 - 09:59 AM
#913
Posted 17 January 2014 - 10:16 AM
Edited by CHILL Gone DUTCH, 17 January 2014 - 10:18 AM.
#914
Posted 17 January 2014 - 10:29 AM
#915
Posted 17 January 2014 - 12:07 PM
#916
Posted 17 January 2014 - 12:14 PM
I see. So actually swapping between OBDtuner and CS ECUs would actually ba bit if a challenge?
Yes, once converted to Peter flash, it's no longer a "normal" ecu. Even opel/vauxhall cannot access Peters part.
That is why using a spare ecu is so handy.
#917
Posted 17 January 2014 - 01:52 PM
I simply stuck with the standard CS setup with the MAP sensor and ran Peters software as I wanted to keep everything the same initially in case I had issues. (which it turns out I have)
Does the CS map mind it being a TMAP rather than the usual MAP sensor?
Not sure, but I think Lee is or did run a TMAP on a CS map
Another question, Would OBEtuner be able to identify an under-performing fuel pump?
If you leave the MAP sensor and configure Peters software for it you can swap back and forth with your CS map ECU not problem.
I've had to do this as Peters software has shown up some issues/errors with my second O2 and potentially Crank sensor that the CS map seems to ignore.
If Peter can diagnose Nicks rad fans running in reverse I'm sure he could pick a failing fuel pump
There is a logging mode that pulls a lot of info, you could do a run with full logging and see what shows up.
What's the symptoms you're seeing? it's not the misfire you got before the bigger fuel tank?
#918
Posted 17 January 2014 - 02:08 PM
Ray Pm me your phone no I will have a chat
#919
Posted 17 January 2014 - 03:22 PM
#920
Posted 17 January 2014 - 03:49 PM
I would definitely like to see a shootout between CS maps and OBDTuner maps.
Same RR, Same day.
The Market Place →
Car Parts For Sale →
Piper 2.5” Manifold And Miltek Mid Section For Z22seStarted by F757lkk@gmail.com , 30 Jun 2024 ![]() |
General Discussion →
Tuning & Modifications →
The Market Place →
Car Parts Wanted →
2.4L Intake Manifold (Gm12587878) For Z22SeStarted by HydroMike , 11 May 2020 ![]() |
VX220 Discussion →
Replacing The Ecu And Having IssuesStarted by den7 , 29 Feb 2020 ![]() |
VX220 Discussion →
Dbilas Turbo Kit - Z22SeStarted by Franke , 24 Feb 2020 ![]() |
