obdtuner remap z22se ecu
2116 replies to this topic
#941 oakmere
oakmere
  • 2,143 posts
Posted 27 February 2014 - 10:27 PM
Very few SC cars will be making power above 7400 rpm (Harrop may be an exception). When you get around to power runs see where you make max Power and limit around that point. People have had problems with std valve springs above 7200 rpm. Remember the forces on the engine components from 6800 rpm to 7800 will have doubled. So don't use more than you need!
#942 don.hasi
don.hasi
  • 320 posts
Posted 28 February 2014 - 12:20 PM
is it worth doing even if you just fit the 2.4 manifold ??
in opposite to smileys direct reply, I would say: YES.
I have had a special mapping on board before and the mapping of obdtuner is better in all points. Plus it has set free some more ponies and the engine revs another step more free, more racier.
overall advantage: if you go later further on with mild or greater mods, you have your perfect mapping already in your back :)
#943 vocky
Posted 28 February 2014 - 03:33 PM
wise words  thumbsup
#944 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 08 March 2014 - 11:46 PM
Is there a licensing key I need it buy to run the software or does this come with the ecu?
#945 CHILL Gone DUTCH
Posted 08 March 2014 - 11:54 PM
peter sent me my license key by e-mail,
but i think if you read ECU to PC (from base map) i think the key might come up automatically
#946 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 09 March 2014 - 12:10 AM
Ok no problem. I was just reading through his manual and it says a firmware might need to be bought so wasn't sure if I needed to pay for something else.
#947 smiley
Posted 09 March 2014 - 12:34 AM
No, peter should mail you they key for free.
It's linked to your specific ecu though, so not a general key.
#948 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 09 March 2014 - 01:54 AM
Sounds good. Think I'm all set now and just waiting for the ecu to come back. Had a good read through his manual tonight and I must admit it looks harder then I thought so hope you don't mind if Im asking loads of daft questions as I tend to over think things to much.
#949 CHILL Gone DUTCH
Posted 09 March 2014 - 07:15 AM
I think the hardest thing was getting the ECU and PC to talk to each other in the setting of lap top
#950 MAXR
MAXR
  • 2,719 posts
Posted 09 March 2014 - 07:58 AM
wise words  thumbsup
Neil,
Thankfully you've built me an engine that thrives on abuse (that's what I tell myself) My car spends much of its time up at the top end of the rev range & I have no intention to stop. I've also not noticed any noticeable drop off in power up at the very top end. The 4.17 forces you to use the revs. I don't find it an issue although I do have a spare 4.17 fully rebuilt & ready to go.
#951 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 19 March 2014 - 06:00 PM
I was wondering if anyone knows what settings from my wide band I have to you to use to put into Peters program. Here is my manual as I can't understand as there's so many numbers. http://www.schnitzra...uals/AEMWBK.pdf. Thanks for anyhelp.
Edited by haggi961, 19 March 2014 - 06:00 PM.
#952 CHILL Gone DUTCH
Posted 19 March 2014 - 06:05 PM
If that's is deffo the right instructions you need details from table 2 Column 1 and 3
Edited by CHILL Gone DUTCH, 19 March 2014 - 06:05 PM.
#953 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 19 March 2014 - 06:07 PM
Yep that's the one as I found my one tonight, so I typed the online version one in to make is easier.
#954 CHILL Gone DUTCH
Posted 19 March 2014 - 06:09 PM
If you want me to guide you through it give me a call
#955 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 19 March 2014 - 06:18 PM
If that's ok I will. I've got a full tank tonight so just waiting for the laptop to come back then I can get off out and do some mapping.
#956 CHILL Gone DUTCH
Posted 19 March 2014 - 06:24 PM
We will put last nights work into the ecu Then Sort the wideband Do a very short log session so we can see wideband working Then do the final base fuel learn session
#957 CHILL Gone DUTCH
Posted 27 March 2014 - 01:45 PM
#958 robin
robin
  • 3,810 posts
Posted 04 April 2014 - 07:32 AM
A question so apart from sending ecu away to be Programed and a lap top and lead what else is required As in does it require a obd2 reader or scangage Or is all of it done with just pc?
#959 techieboy
Posted 04 April 2014 - 07:37 AM
In it's most basic setup, that's all that's required. A wideband lambda wired into the EGR loom is an option (but you need to keep the two OEM lambda sensors in place and connected). If you were supercharged, a TMAP sensor wired into the original MAP sensor loom and the old IAT sensor loom is a good call to measure inlet temps in the inlet manifold instead of pre-throttle body.
Then just a nice long stretch of smooth as possible road.
The laptop and the OBDTuner Windows GUI software can/will act as an OBD2/Scanguage on steroids, if you need it to.
#960 fezzasus
Posted 04 April 2014 - 07:41 AM
It's all done with the laptop. Very simple once you get familiar with the software
