obdtuner remap z22se ecu
2116 replies to this topic
#961 smiley
Posted 04 April 2014 - 07:54 AM
And just learning sessions for afr and ignition, are done with laptop disconnected.
So you fire off a learning session via the laptop, then disconnect, and go for your learning drive.
Then when you come back, DO NOT SHUT OFF IGNITION, attach laptop again, then save from ecu learning table to final table.
#962 techieboy
Posted 04 April 2014 - 08:13 AM
That's what Peter should add to OBDTuner. Airbag fault clearing, immobiliser key chip programming/pairing and ABS fault clearing (even better if he could work out whatever is needed to put the ABS module into service mode for proper bleeding). Then no more reliance on OpCom or TECH2.
#963 siztenboots
Posted 04 April 2014 - 08:31 AM
if he could capture the packet stream protocol for resetting the TRW 4 channel abs. Remove immo option would make our life easier.
#964 techieboy
Posted 04 April 2014 - 08:34 AM
Yeah, I don't think he was too keen on binning the immobiliser requirement unfortunately. I'm pretty sure he could do it today but I can see his concern that then the ECU could be used to drive away any car.
#965 vocky
Posted 04 April 2014 - 09:42 AM
don't forget you need an ELM327 interface cable  thumbsup
#966 robin
robin
  • 3,810 posts
Posted 04 April 2014 - 09:54 AM
Do you think he could also add a lotto hack to give winning numbers?
#967 techieboy
Posted 04 April 2014 - 10:04 AM
It would be good to know what string need to be sent to the ABS to push the actuator pistons out and then pull them back in. Can't be any more complicated than the command strings on the scangauge to active/deactivate the cooling fans. Would just needed a fully wired OBD cable so that it can talk via the ABS pin in the connector - which I don't think the Scangauge is wired up for.
#968 robin
robin
  • 3,810 posts
Posted 04 April 2014 - 10:47 AM
Be cool if this was a app for a ipad to work from.
#969 smiley
Posted 04 April 2014 - 11:48 AM
A german guy build a contraption for that a few weeks ago.
Shall try if i can find it.
#970 Exmantaa
Posted 04 April 2014 - 11:50 AM
That's what Peter should add to OBDTuner. Airbag fault clearing, immobiliser key chip programming/pairing and ABS fault clearing (even better if he could work out whatever is needed to put the ABS module into service mode for proper bleeding). Then no more reliance on OpCom or TECH2.I highly doubt Peter will
I highly doubt that Peter will work on that. Just buy a cheap OpCom and you can do all those things, except the ABS bleeding.
Ow, and note that the immobiliser clearing/reprogramming is disabled in OBD Tuner, so you cannot  clear and swap OBD ecu's between cars. Probably some extra copyright security from Peter...
Edited by Exmantaa, 04 April 2014 - 11:50 AM.
#971 techieboy
Posted 04 April 2014 - 12:21 PM
I highly doubt it too. Extra VX specific features would be more useful than twatpad support though.
If somebody isn't technically literate enough to have chosen something other than an iDevice, they shouldn't be mapping an engine. :lol:
#972 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 24 April 2014 - 08:19 PM
I've bought a windows tablet to run permanently in the vx but I'm struggling to get the obd to work with it. When I plug in the obd to the tablet and do a test on the settings tab it says test successful. Once connected to the car and I do a reconnect to ecu it says connected at the bottom right corner but if I try to do a log or power run it says =
Anyone have any ideas how to make it work because if I plug the laptop back in it connects up straight away and works fine.
#973 CHILL Gone DUTCH
Posted 24 April 2014 - 08:23 PM
Have a look at the speed rate In settings and then check what rate the tablet is set to
#974 Bargi
Bargi
  • 4,483 posts
Posted 24 April 2014 - 08:31 PM
as Chill said, try setting it down to 9600 in OBDTuner and the COM Port
#975 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 24 April 2014 - 08:53 PM
I've set it at the normal rate of 38400 i think it was. I will have to have a look because I'm sure it would let me select any other speed.
#976 CHILL Gone DUTCH
Posted 24 April 2014 - 08:56 PM
Your port speed will have to match the setting Do you know what your port speed is
#977 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 24 April 2014 - 09:03 PM
It doesn't tell me port speed in the device manger settings and only says com4. When I got it to connect on the software I had to try loads of the speed rates until it said test successful.
#978 CHILL Gone DUTCH
Posted 24 April 2014 - 09:04 PM
Do you have a keyboard on the tablet ??
#979 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 24 April 2014 - 09:06 PM
Yeah a built in key board with half the buttons on one side and half the other.
#980 CHILL Gone DUTCH
Posted 24 April 2014 - 09:07 PM
Push windows button and R
    Bing (1)
