Edited by CHILL Gone DUTCH, 24 April 2014 - 09:09 PM.
#981
Posted 24 April 2014 - 09:08 PM
#982
Posted 24 April 2014 - 09:16 PM
Make sure the tablet is on socket power connected when you try.
(as peter allready expressed worry about clockspeed, and some dial down on cpu speed when on battery)
#983
Posted 24 April 2014 - 09:18 PM
#984
Posted 24 April 2014 - 09:26 PM
Didn't know that it loses connection power when on battery. I thought he meant just in general.Make sure the tablet is on socket power connected when you try. (as peter allready expressed worry about clockspeed, and some dial down on cpu speed when on battery)
#985
Posted 24 April 2014 - 09:30 PM
Yes, it's going to be interesting to see if your model is up to the job cpu wize.
#986
Posted 24 April 2014 - 09:33 PM
#987
Posted 24 April 2014 - 10:25 PM
Not so easy.
800Mhz should do the job though.
If it works on socketpower, just not on battery, you can put a converter in to emulate socketpower.
Just try to get it to work at all i would say.
#988
Posted 02 May 2014 - 08:53 PM
Got an afr learning session planned tomorrow with a buddy.
Hi's eml is on because of second lambda.
Any chance it will still work if i cleared the code, knowing it will come back in 10 min?
Any chance i can use the laptop real-time to see the fuel table getting hit correct, if i can't use the eml light?
#989
Posted 02 May 2014 - 08:56 PM
You can update the table every few minutes if you want just don't process measurement until you have finishedGot an afr learning session planned tomorrow with a buddy. Hi's eml is on because of second lambda. Any chance it will still work if i cleared the code, knowing it will come back in 10 min? Any chance i can use the laptop real-time to see the fuel table getting hit correct, if i can't use the eml light?
#990
Posted 02 May 2014 - 09:36 PM
You mean write results back from ecu to laptop for viewing?
#991
Posted 02 May 2014 - 09:50 PM
YesYou mean write results back from ecu to laptop for viewing?You can update the table every few minutes
Edited by CHILL Gone DUTCH, 02 May 2014 - 09:51 PM.
#992
Posted 06 May 2014 - 07:25 PM
#993
Posted 06 May 2014 - 07:41 PM
I visited him 2 weeks back to get my V2 updated. (I had an early release)
He´s not responding to mail?
#994
Posted 06 May 2014 - 07:44 PM
PmedI visited him 2 weeks back to get my V2 updated. (I had an early release) He´s not responding to mail?
#995
Posted 07 May 2014 - 06:24 PM
Went for the software too as the CS map is unusable when fitting back a cat. Sent my ECU to Peter on monday and it's already on it's way back!
Also getting rid of the Z20LET injectors and moving to the blue Z20LEH injectors + TMAP sensor after Peter his feedback. Apparently the current injectors are already running over 80% duty cycle with my current setup (3" pulley).
Can't wait to get started with the mapping.
Edited by Denthrax, 07 May 2014 - 06:27 PM.
#996
Posted 07 May 2014 - 06:42 PM
Edited by CHILL Gone DUTCH, 07 May 2014 - 06:42 PM.
#997
Posted 07 May 2014 - 06:49 PM
Yes, that why I'm moving to the blue ones. Currently I have black ones fitted from the turbo (Z20LET). Ordered a pair of blues from autovaux wich are currently on sale for £105!
Edited by Denthrax, 07 May 2014 - 06:50 PM.
#998
Leh are blue Vxr injectorsAre you sure you don't need Vxr injectors ?? (Blues)
#999
Posted 07 May 2014 - 06:50 PM
Sorry I didn't see blue Vxr injectors in your first post must if missed itYes, that why I'm moving to the blue ones. Currently I have black ones fitted from the turbo (Z20LET). Order a new pair of blues from autovaux wich are currently on sale for £105!
#1000
Posted 07 May 2014 - 06:51 PM
Do you a set for £75 delivered ;-)Yes, that why I'm moving to the blue ones. Currently I have black ones fitted from the turbo (Z20LET). Ordered a pair of blues from autovaux wich are currently on sale for £105!
The Market Place →
Car Parts For Sale →
Piper 2.5” Manifold And Miltek Mid Section For Z22seStarted by F757lkk@gmail.com , 30 Jun 2024 ![]() |
General Discussion →
Tuning & Modifications →
The Market Place →
Car Parts Wanted →
2.4L Intake Manifold (Gm12587878) For Z22SeStarted by HydroMike , 11 May 2020 ![]() |
VX220 Discussion →
Replacing The Ecu And Having IssuesStarted by den7 , 29 Feb 2020 ![]() |
VX220 Discussion →
Dbilas Turbo Kit - Z22SeStarted by Franke , 24 Feb 2020 ![]() |
