Thanks to everyone for the quick responses!
Much appreciated.
All being well there'll be another OBD Tuner supercharged vx around within a few weeks!
R
Posted 24 May 2014 - 01:10 PM
Much appreciated.
R
Posted 29 May 2014 - 11:01 AM
Much better than a totally standard car on OEM map, by the look/sound of it.
Posted 29 May 2014 - 11:38 AM
Posted 29 May 2014 - 11:42 AM
It's loads better then it was standard. I've been cruising for towns in 5th gear which I could never do before.
I'm going to have to sort this as currently mine just splutters at low revs in high gears....
Chuffed there seems to be a fix for it as it is a bit disconcerting
Posted 29 May 2014 - 12:03 PM
The spluttering is because the CS map overfuels over part throttle.
Posted 29 May 2014 - 01:17 PM
We are talking about the dutch software here though not a CS map - Unless it's a common thing..?
Whatever the cause, if Peter is now in a postion to help improve, I'm a happy bunny
Posted 29 May 2014 - 01:34 PM
Edited by CHILL Gone DUTCH, 29 May 2014 - 01:34 PM.
Posted 29 May 2014 - 01:40 PM
This is mainly for after market cams on the Dutch software which some people get cam overlap causing the car to splutter under 2000 ish rpm
Yep - Stage 2 Comp Camps...!
Posted 29 May 2014 - 02:00 PM
Stage 2 ZZP comp cams hereYep - Stage 2 Comp Camps...!This is mainly for after market cams on the Dutch software which some people get cam overlap causing the car to splutter under 2000 ish rpm
Posted 29 May 2014 - 02:46 PM
Oh, I thought you meant you are still using a CS map.
I'll soon be running stage 2 comp cams on a 2.0 so it'll be a good test of how good the control is.
Posted 29 May 2014 - 02:54 PM
Edited by CHILL Gone DUTCH, 29 May 2014 - 02:55 PM.
Posted 29 May 2014 - 02:55 PM
sounds like tip-in problem
Posted 29 May 2014 - 10:48 PM
How is the idle now with these latest OBD mapping improvements? Steady?
I finished my 2.0 with Harrop & ZZP st2 cams this week and the idle (~875) and low load driving seem pretty good sofar But I'm running an LSJ ecu and now playing with injector settings.
Posted 30 May 2014 - 06:20 AM
Posted 30 May 2014 - 06:31 AM
Posted 03 June 2014 - 01:44 PM
yep, tip in and tip out are the two hardest things to actually calibrate properly :s
Posted 03 June 2014 - 01:54 PM
Posted 03 June 2014 - 01:59 PM
The Transient Ignition Retard function is designed to introduce ignition retard during transient conditions.
Transient conditions are identified by a fast change in Throttle Position (TPS) or Manifold Absolute Pressure (MAP). Ignition is retarded depending on the rate of change of TPS or MAP, then held retarded for a particular number of engine cycles.
Posted 03 June 2014 - 02:13 PM
fnnarrr
The Market Place →
Car Parts For Sale →
Piper 2.5” Manifold And Miltek Mid Section For Z22seStarted by F757lkk@gmail.com , 30 Jun 2024 ![]() |
General Discussion →
Tuning & Modifications →
The Market Place →
Car Parts Wanted →
2.4L Intake Manifold (Gm12587878) For Z22SeStarted by HydroMike , 11 May 2020 ![]() |
VX220 Discussion →
Replacing The Ecu And Having IssuesStarted by den7 , 29 Feb 2020 ![]() |
VX220 Discussion →
Dbilas Turbo Kit - Z22SeStarted by Franke , 24 Feb 2020 ![]() |
