#1041
Posted 03 June 2014 - 05:48 PM
#1042
Posted 04 June 2014 - 03:22 PM
Can someone point me in the direction of what exactly I need to buy, hardware wise, to get this up and running? ECU, what else? Which ECU, etc?
#1043
Posted 04 June 2014 - 03:25 PM
uses existing ecu , just need adaptor cable to plug laptop into OBD plug for live mapping
#1044
Posted 04 June 2014 - 03:29 PM
#1045
Posted 04 June 2014 - 03:37 PM
Do you not have to send the ECU over to get plugged into somit over in Euro land? Quite like the idea of having a second ECU that I play around with and my current one that I can swap back if things to wrong/run out of time for somit
#1046
Posted 04 June 2014 - 03:47 PM
#1047
Posted 04 June 2014 - 03:48 PM
Both? Can I not just send my key, and the new ECU? Also, what car do I need to get it from, an Astra or similar?
#1048
Posted 04 June 2014 - 04:07 PM
Edited by chris_uk, 04 June 2014 - 04:08 PM.
#1049
Posted 04 June 2014 - 04:09 PM
You have to change your forum name when you first start car up on Dutch software, Chris_NLMy ecu is on its way home
#1050
Posted 04 June 2014 - 04:11 PM
If you drop peter a email about what you want he will advise youBoth? Can I not just send my key, and the new ECU? Also, what car do I need to get it from, an Astra or similar?
#1051
Posted 04 June 2014 - 04:20 PM
You need the old ECU for the immobiliser code.
VAUXHALL VECTRA 2.2 PETROL Z22SE CODE DELPHI ECU SET - Part No. 12202143 DLKL
This should do the trick.
#1052
Posted 04 June 2014 - 05:35 PM
You have to change your forum name when you first start car up on Dutch software, Chris_Holy_crap_i_should_have_done_this_a_year_agoMy ecu is on its way home
EFA
#1053
Posted 04 June 2014 - 05:54 PM
As should all z22se ownersEFA
#1054
Posted 04 June 2014 - 06:09 PM
EFA
#1055
Posted 05 June 2014 - 07:43 AM
What is Peters email address? Ta
#1056
Posted 05 June 2014 - 08:17 AM
peter @munckhof.demon.nl
#1057
Posted 05 June 2014 - 08:37 AM
I have sent only my spare ECU to Peter but at the same time i emailed him the files of my "on car" ECU that i had copied with a specific OBD device.
#1058
Posted 05 June 2014 - 09:13 AM
EFA
is the undriveable<2000rpm bit optional
#1059
Posted 05 June 2014 - 12:25 PM
Anyone know when we can expect a new version of ODBDTuner including good idle with non OEM cams ??
#1060
Posted 05 June 2014 - 01:03 PM
Sounds like it's a fix in the calibration and doesn't need firmware/software changes.
The Market Place →
Car Parts For Sale →
Piper 2.5” Manifold And Miltek Mid Section For Z22seStarted by F757lkk@gmail.com , 30 Jun 2024 ![]() |
General Discussion →
Tuning & Modifications →
The Market Place →
Car Parts Wanted →
2.4L Intake Manifold (Gm12587878) For Z22SeStarted by HydroMike , 11 May 2020 ![]() |
VX220 Discussion →
Replacing The Ecu And Having IssuesStarted by den7 , 29 Feb 2020 ![]() |
VX220 Discussion →
Dbilas Turbo Kit - Z22SeStarted by Franke , 24 Feb 2020 ![]() |
