obdtuner remap z22se ecu
2116 replies to this topic
#1121 CHILL Gone DUTCH
Posted 13 June 2014 - 10:18 AM
Are you processing the AFR as you do power runs ??
#1122 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 13 June 2014 - 11:45 AM
Chris can you remember if my wideband was showing a reading of 14.7 on my older logs? I'm wondering that if my wideband sensor is crap and showing the readings in getting.
#1123 CHILL Gone DUTCH
Posted 13 June 2014 - 12:00 PM
No sorry Luke Can't recall If you want to contact me you can get by pm on Facebook
#1124 chris_uk
Posted 13 June 2014 - 09:12 PM
has anyone experienced the OBDII interface thing stopping working and then being undetectable?
I was in the middle of a power run and an error came up which was unrelated and then it wouldn't connect to the software.. tried pretty much everything I could think off and nothing..
when you plug in into the laptop nothing appears, nothing shows up just nothing happens.. tried to find the com ports in the device manager and nothing is there either..
any idea?
just to add, the lights on the interface work and the red light stays illuminated as long as its plugged into the laptop, or the OBD port on the car.
Edited by chris_uk, 13 June 2014 - 09:14 PM.
#1125 Bargi
Bargi
  • 4,483 posts
Posted 15 June 2014 - 10:07 AM
When you say an error came up is that Windows error or the OBDTuner software? I get occasional problem with it not seeing the com ports but I'm using Bluetooth and 99% of the time its if I've brought the laptop out of standby. Have you tried turning it off and on again? :D
#1126 smiley
Posted 15 June 2014 - 11:56 AM
2.7.2.2 has been released.
http://www.obdtuner....c.php?f=4&t=208
#1127 ufods
ufods
  • 235 posts
Posted 05 July 2014 - 01:35 PM
@chris_uk I see your power runs. Impressive cool intake temp. What was the ambiant temperatur? Do you keep on working and can show a new diagramm? Christian.
#1128 chris_uk
Posted 05 July 2014 - 02:45 PM
if i rememeber correctly they were about 17c ambient
#1129 ufods
ufods
  • 235 posts
Posted 05 July 2014 - 04:29 PM
So you achieve this without water injection?
#1130 CHILL Gone DUTCH
Posted 06 July 2014 - 12:19 PM
Are your cooler intakes due to direct air cooling Chris_NL
#1131 chris_uk
Posted 06 July 2014 - 12:56 PM
yes.
Chill.. i dont know how much that direct air feed it doing tbh.
#1132 oakmere
oakmere
  • 2,143 posts
Posted 13 July 2014 - 04:32 PM
I would recommend anyone using or planning on the OBD software get a new O2 sensor. Since a new fuel lean the fuel trims have been very low. Also the car drives and idles better. The sensor I used was an NTK which was identical to the original GM.
#1133 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 13 July 2014 - 05:14 PM
Which 02 sensor are you meaning as there's 2?
#1134 Bargi
Bargi
  • 4,483 posts
Posted 13 July 2014 - 05:18 PM
First one, its the important one
#1135 oakmere
oakmere
  • 2,143 posts
Posted 13 July 2014 - 05:19 PM
Primary (before the cat). This is the sensor used to control the fuelling. I would like to add there was no fault with the original sensor. Also the above should read fuel learn not lean oops!
Edited by oakmere, 13 July 2014 - 05:20 PM.
#1136 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 13 July 2014 - 05:46 PM
Where's the best price you have found one?
#1137 oakmere
oakmere
  • 2,143 posts
Posted 13 July 2014 - 06:09 PM
Part No: OZA531-GM6 eBay amazon etc. £50-60.
#1138 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 13 July 2014 - 06:36 PM
Cheers mate.
#1139 pete-r
pete-r
  • 2,771 posts
Posted 27 July 2014 - 06:01 PM
Hi guys I'm posting my ecu to peter tomorrow and have two questions.
1. The ecu compatibility says G15 as the required ecu, but mine doesn't say G15 anywhere on it? Before I send it can someone assure a thicko like me that it'll work lol?
2. Who is best to send with? Royal Mail or a private firm and do I insure it for a particular price?
Cheers,
Pete.
#1140 CHILL Gone DUTCH
Posted 27 July 2014 - 06:03 PM
1. Did this ecu work on your car ??? If so it will be fine. 2. Royal Mail
