obdtuner remap z22se ecu
2116 replies to this topic
#1161 slindborg
Posted 29 July 2014 - 11:24 AM
and then you have cams, heads, valves, cooling effectiveness,exhaust, different injectors and so on...
proof, again, that stage tuning is stupid and wrong unless you are a chooner selling something to idiots.
Or are those selections on the dutch SW.... in which case... erm
#1162 smiley
Posted 29 July 2014 - 11:26 AM
It has nothing to do with the software.
Never has.
#1163 slindborg
Posted 29 July 2014 - 11:29 AM
well thats a relief :)
but still labling by stages of choon is retarded, especially when you say Stage 2, but I also have XYZ so its not comprable to another stage 2 :lol:
I guess it works well within jap circles and VW circles as they all like to sheep it up, and to an extent in the ZLET (astra) crowd too.
#1164 smiley
Posted 29 July 2014 - 11:33 AM
You would rather see signatures listing all the mods?
#1165 slindborg
Posted 29 July 2014 - 11:51 AM
no, because thats equally naff :lol:
#1166 techieboy
Posted 29 July 2014 - 11:57 AM
Just stick a '+' or 'and a bit' after the Stage x. Sorted. :lol:
#1167 nicollow
nicollow
  • 3,801 posts
Posted 29 July 2014 - 12:33 PM
Stages don't have to be integers. I have a stage 2.38+
#1168 G-Bob
G-Bob
    Embarrassing VX's in an MX5
  • 8,256 posts
Posted 29 July 2014 - 12:43 PM
When did that happen?
Last time I spoke to you, you were at stage 2.34!!!
Did you run redex through it?
#1169 nicollow
nicollow
  • 3,801 posts
Posted 29 July 2014 - 12:48 PM
Keep up Bob:
Took a sh*t, +0.01
Only put half a tank of fuel in it, for weight saving, +0.01
Used V Power, +0.01
Took my Spice Girls MiniDisc out, for weight saving, +0.01
Put redex through it, + a plus
Total, as of 29/7/14, 13:48: 2.38+
#1170 siztenboots
Posted 29 July 2014 - 12:51 PM
how valid is limits of stage 2 and 3 , how many failures have there been documented
#1171 Exmantaa
Posted 29 July 2014 - 01:34 PM
provided you all had near identical performing intake manifolds , then the speed density could cope
Scrap that.
Engine volume, intake, manifold, head + valves, cams and exhausts ALL influence a Speed Density based system.
Some more that others, but that's why you need to do a fuel learn on each engine, as no engine is the same. :wacko:
Peter has several good base maps that he tailors for your application and will get you going, but for max performance some more effort is required. First you must check if fuel trims and knock retard are within limits and build from there..
Edit; and agree with the "Stage" bollocks. It was good for the base Courtenay SC-1 and SC-2 (chargecooled) difference, but beyond that simply list your mods.   :happy:
Edited by Exmantaa, 29 July 2014 - 01:41 PM.
#1172 Chris P Duck
Chris P Duck
    I can change this?
  • 1,506 posts
Posted 29 July 2014 - 07:49 PM
Stage quoting is fine as long as the reader had the intelligence to realise what it really means, IE a rough idea of what's been done and a rough idea of a BHP range. Like it or lump it people will always quote stages as it's a fcuk load easier and quicker than listing all their mods. As an example mine has: Walbro 255 pump VXR injectors Pipercross RS500 filter 68mm LSJ throttle body m62 supercharger with 3.35" pulley Front mounted Pro Alloy Charge Cooler Chris Tullett tubular exhaust manifold Custom 2.5" downpipe with no pre-cat and 200 cell main cat 2.5" "U-bend" De-restricted tubby backbox 266 degree piper cams EGR system deleted LSJ Tmap sensor OBD Tuner software Runs OEM fuel pressure Uses OEM compression ratio Has a 6,800rpm limit ...or, I could say stage 2.5 and peoples assumption will be in the right ball park
Edited by Chris P Duck, 29 July 2014 - 07:50 PM.
#1173 chris_uk
Posted 29 July 2014 - 08:39 PM
Stages should be about power not individual mods.. Stage 1 - 200 - 220 bhp Stage 2 - 220 - 260 bhp Stage 3 - 260 - 300 bhp Stage 4 - 300 - 360 bhp
#1174 Chris P Duck
Chris P Duck
    I can change this?
  • 1,506 posts
Posted 29 July 2014 - 08:53 PM
Whoohooo, forget everything I just said fcuk you bitches, I just went up to stage 3
Edited by Chris P Duck, 29 July 2014 - 08:55 PM.
#1175 CHILL Gone DUTCH
Posted 29 July 2014 - 08:54 PM
I think I'm short of stage 4 by a exhaust
#1176 Chris P Duck
Chris P Duck
    I can change this?
  • 1,506 posts
Posted 29 July 2014 - 08:56 PM
Your car must be fecking loud without one!
#1177 CHILL Gone DUTCH
Posted 29 July 2014 - 08:57 PM
You have been in it
#1178 Chris P Duck
Chris P Duck
    I can change this?
  • 1,506 posts
Posted 29 July 2014 - 08:59 PM
And it was fecking loud :D
#1179 CHILL Gone DUTCH
Posted 29 July 2014 - 09:00 PM
Only when you get above 140 leptons
#1180 techieboy
Posted 29 July 2014 - 09:02 PM
I just went up to stage 4, according to one particular dyno run on one particular dyno on one particular day. So double fcuk you. :D
Also shows why stages based on arbitrary power numbers are even more stupid than basing it on hardware.
6 user(s) are reading this topic
    Bing (2)
