Did anybody ever seen a 7" running full windows 7? (the ones running 8 are to recent and expensive as a gadget for me)
#1221
Posted 28 August 2014 - 01:10 PM
#1222
Posted 28 August 2014 - 01:32 PM
Can't remember whether they were 7" or 8" but Archos and Acer (with the W series tablets) both did "small" Windows 7 tablets. They should be pretty cheap on eBay these days. That said, their older Windows 8 based tablets should be available cheaply too. Your big problem is that Windows 7 is near unusable in 7". It's touch support is basic at best and it doesn't scale apps (Windows 8/8.1 isn't much better in that respect either). It really needs a stylus for input, especially when you're stabbing at tray icons and OBDTuner's spreadsheet type layout means it's hard work to see/use and even worse once Windows pops up a virtual keyboard eating up another 50% of the screen. Conversely, OP-COM due to it's really simple interface with massive buttons works almost perfectly.Did anybody ever seen a 7" running full windows 7? (the ones running 8 are to recent and expensive as a gadget for me)
I just blagged three free Dell Venue Pro 8's from our Dell Account manager. Hoping they'll be delivered to my personal tech stockpile today or tomorrow.(the ones running 8 are to recent and expensive as a gadget for me)
#1223
Posted 28 August 2014 - 01:35 PM
Got any contacts at Alienware?Can't remember whether they were 7" or 8" but Archos and Acer (with the W series tablets) both did "small" Windows 7 tablets. They should be pretty cheap on eBay these days. That said, their older Windows 8 based tablets should be available cheaply too. Your big problem is that Windows 7 is near unusable in 7". It's touch support is basic at best and it doesn't scale apps (Windows 8/8.1 isn't much better in that respect either). It really needs a stylus for input, especially when you're stabbing at tray icons and OBDTuner's spreadsheet type layout means it's hard work to see/use and even worse once Windows pops up a virtual keyboard eating up another 50% of the screen. Conversely, OP-COM due to it's really simple interface with massive buttons works almost perfectly.Did anybody ever seen a 7" running full windows 7? (the ones running 8 are to recent and expensive as a gadget for me)
Last time I looked they were available from the Dell Outlet at circa £150 and are effectively brand new.
#1224
Posted 28 August 2014 - 01:42 PM
Afraid not. Only Dell enterprise/business stuff. Can't even get a decent discount on their XPS and Inspiron ranges of lower end home/small business oriented stuff. Had to threaten withholding an order for some replacement kit to tease the tablets out of him.Got any contacts at Alienware?
#1225
Posted 28 August 2014 - 01:45 PM
#1226
Posted 28 August 2014 - 05:40 PM
#1227
Posted 28 August 2014 - 05:44 PM
make a bracket which sits under the dash, cover the inside in the soft part of velcro and then you can just slide it in and out.
#1228
Posted 28 August 2014 - 05:46 PM
#1229
Posted 28 August 2014 - 05:58 PM
#1230
Posted 28 August 2014 - 06:08 PM
#1231
Posted 28 August 2014 - 06:22 PM
#1232
Posted 28 August 2014 - 06:23 PM
#1233
Posted 28 August 2014 - 06:24 PM
There were loads on flidBay when I linked to the auction for a batch of 5 of them, they go for anywhere from £40 to £100 depending on stupid people are.Nick where did you get it for £75
#1234
Posted 28 August 2014 - 06:30 PM
#1235
Posted 28 August 2014 - 06:32 PM
Well, how is it charged now? Via a USB socket? Or via a dedicated power socket? If it's USB that's a simple enough 5v power supply, you just need to know how much current it needs, which should be marked on the existing charger or the the PC itself. Then you can just get a suitably powerful 12v-5v USB power supply from flidBay and away you go. Like this maybe: http://www.ebay.co.u...=item5d4f699cf4 If it has a dedicated power socket, then you're probably looking at something more like a 12v power supply, in which case you'll either need to try an find a matching polarity plug from Maplins or it's like and then wire it up to an ignition switched power source via a fuse, or either use the adapter I linked to or hack apart your existing charger and remove the lighter plug end and connect the wires as before but you need to know whether there is any kind of voltage reduction circuity in the existing lighter lead.I could do but the little bit of extra wiring don't bother me to much. I'm just after a clean look and no hassle when I need to use it.
#1236
Posted 28 August 2014 - 06:34 PM
But Nick was talking about the same 10" Novatech tablet that Luke has or I linked to originally.If there was a 7 inch version that would work then that would be nice. 10 inch is nice but I think I would prefer 7 inch due to being a bit smaller and easier to fit/hide.
#1237
Posted 28 August 2014 - 06:39 PM
#1238
Posted 28 August 2014 - 06:49 PM
That looks good. Is it just a case of wiring it off something like the stereo wiring?Easiest way as it sounds like you've already got a cigarette charger lead for it: http://www.ebay.co.u...=item5b03613aab
#1239
#1240
Posted 28 August 2014 - 06:56 PM
Yep. With an inline fuse of suitable capacity. Obviously only worth using if you have an existing power lead that terminates in a cigarette lighter plug thingy.That looks good. Is it just a case of wiring it off something like the stereo wiring?Easiest way as it sounds like you've already got a cigarette charger lead for it: http://www.ebay.co.u...=item5b03613aab
The Market Place →
Car Parts For Sale →
Piper 2.5” Manifold And Miltek Mid Section For Z22seStarted by F757lkk@gmail.com , 30 Jun 2024 ![]() |
General Discussion →
Tuning & Modifications →
The Market Place →
Car Parts Wanted →
2.4L Intake Manifold (Gm12587878) For Z22SeStarted by HydroMike , 11 May 2020 ![]() |
VX220 Discussion →
Replacing The Ecu And Having IssuesStarted by den7 , 29 Feb 2020 ![]() |
VX220 Discussion →
Dbilas Turbo Kit - Z22SeStarted by Franke , 24 Feb 2020 ![]() |
Bing (1)
