obdtuner remap z22se ecu
2116 replies to this topic
#1241 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 28 August 2014 - 07:23 PM
They're sh!t and discontinued now but go for anywhere between £40 and £100. Fill your boots on five of 'em.   http://www.ebay.co.u...=item51c1f89184
just wanted something to map the car easy to handle and doesn't cost to much.
#1242 CHILL Gone DUTCH
Posted 28 August 2014 - 07:27 PM
How much did you offer nick
#1243 NickB787
NickB787
  • 7,813 posts
Posted 28 August 2014 - 07:28 PM
could have had it for 80 but went back for 75
#1244 CHILL Gone DUTCH
Posted 28 August 2014 - 07:44 PM
I was thinking of offering 50 incl delivery
#1245 NickB787
NickB787
  • 7,813 posts
Posted 28 August 2014 - 07:55 PM
try that good call hoping the Techieboy may show a link to something we can use and cheap.I know nothing about these things...
#1246 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 29 August 2014 - 09:17 AM
Here a video to show you guys mine works and is quite quick http://i1174.photobu...zpskegqtg0d.mp4
#1247 oakmere
oakmere
  • 2,143 posts
Posted 29 August 2014 - 01:00 PM
Looks good. I might get one of these to replace the XP net book I use.
#1248 CHILL Gone DUTCH
Posted 29 August 2014 - 05:17 PM
Do you think we could get discount on buying together ??
#1249 NickB787
NickB787
  • 7,813 posts
Posted 30 August 2014 - 07:38 AM
I asked but he didn't reply when I asked him that
#1250 NickB787
NickB787
  • 7,813 posts
Posted 30 August 2014 - 09:02 AM
just out mapping, noticed on a power run my AFR has jumped to 20 any ideas why? I checked the wideband hookup looks ok
#1251 vocky
Posted 30 August 2014 - 09:14 AM
can you try recalibrating the sensor ?
Not even sure you can, but worth a go  :unsure:
#1252 NickB787
NickB787
  • 7,813 posts
Posted 30 August 2014 - 09:25 AM
I have a PLX they don't need calibrating in open air if I remember correctly, may have died..
#1253 Arno
Arno
  • 1,238 posts
Posted 30 August 2014 - 11:18 AM
Jump to 20 in most wideband applications tends to indicate a loose wire or wiring break somewhere. Eg. between wideband controller voltage output and gauge or ECU.
Also check for melting wiring to the sensor..
Edit: in some cases it can be a sensor overheat that makes it shutdown. IN that case you need to fit it with a cooling spacer or further downstream.
Edited by Arno, 30 August 2014 - 11:19 AM.
#1254 NickB787
NickB787
  • 7,813 posts
Posted 30 August 2014 - 11:43 AM
Thanks Arno been looking a bit more closely and it was working ok up to 3500 ish rpm the went to 20 and stayed there so as you say most probably a loose connection, although it did it twice near the same rpm, Strange
#1255 Arno
Arno
  • 1,238 posts
Posted 30 August 2014 - 02:13 PM
Vibrations and intermittent connections can be hell to track down :(
To verify you could try to rig a separate gauge or digital data readout on the PLX controller to see if it's really reading 20+AFR or if the PLX controller itself is still reading normal values. (I think they include a serial cable and software?)
That should tell you if the problem is somewhere Lambda - PLX connection or PLX - ECU connection or perhaps even the power supply to the PLX controller itself.
#1256 NickB787
NickB787
  • 7,813 posts
Posted 30 August 2014 - 03:04 PM
three runs, stopped at that, same approx rpm I don't think it's a connection/ vibration problem all at about the same rpm. Better go through the PLX troubleshoot section
Edited by NickB777, 30 August 2014 - 03:06 PM.
#1257 CHILL Gone DUTCH
Posted 07 September 2014 - 08:22 AM
just thought i would ask what peoples thoughts were on this it could somthing or nothing,
I have recently uploaded my long term fuel trims and was very surprised how high they were
the last time i used the car was on a track day at angelsey and a spirited drive home but i have been starting the car up regularly getting it up to temp and then turning it off
is it because i  have only been starting the car up and not going anywhere or somthing more, normally my fuel trims are no more than 2.5%
#1258 NickB787
NickB787
  • 7,813 posts
Posted 07 September 2014 - 05:26 PM
will check mine in the morning for you, just used it for work for the first time in ages. great to be out again
#1259 oakmere
oakmere
  • 2,143 posts
Posted 07 September 2014 - 08:36 PM
O2 sensor working ok? Did you fit a new one with the Saab engine? My trims have never been over 8% and are generally less than 3%. Take it for a drive and run the data logging to check the O2 sensor.
#1260 CHILL Gone DUTCH
Posted 08 September 2014 - 08:31 AM
Could this be down to a boost leak of some sort, Went out in the car last night after resetting the fuel trims And noticed a hissing noise from the engine bay Not investigated yet but I'm off work tomoz so will strip it down and have a look
    Bing (1)
