obdtuner remap z22se ecu
2116 replies to this topic
#1301 Sutol
Sutol
    Well it's nearly a Lotus
  • 8,122 posts
Posted 27 September 2014 - 04:41 PM
The gui supports standard windows keys, so ctr+a to select all cells, ctr+c to copy it, then paste in your spreadsheet.
thx Smiley that will be intersting. should i get curves or straight lines?
#1302 Bargi
Bargi
  • 4,483 posts
Posted 27 September 2014 - 04:44 PM
There's no problem with you doing multiple learns. You will go over some of the same cells again but it won't hurt. If anything just makes the map more accurate.
#1303 fezzasus
Posted 27 September 2014 - 04:47 PM
And remember the hard to reach points (high rpm, high boost), if not mapped fully with just be rich, which is hardly a problem given the small time you'll spend in that area.
#1304 fezzasus
Posted 27 September 2014 - 04:49 PM
Depends what you plot, and how you plot it.
Example
#1305 Sutol
Sutol
  • 8,122 posts
Posted 27 September 2014 - 04:55 PM
Let me put you in the picture. I get a surge if power occasionally around 2.5 to 3k rpm, not all the time but, I guess at a certain map and throttle position. It would be nice to isolate and iron it out.
Edited by Sutol, 27 September 2014 - 04:56 PM.
#1306 Bargi
Bargi
  • 4,483 posts
Posted 27 September 2014 - 05:07 PM
I still get that as well Chris
#1307 Bargi
Bargi
  • 4,483 posts
Posted 27 September 2014 - 05:09 PM
That would be interesting, potentially do up a graph like Fez posted
#1308 oakmere
oakmere
  • 2,143 posts
Posted 27 September 2014 - 11:00 PM
Sworks Mapping looks good. You could spend all day driving and not hit all the cells so don't worry about this. Also remember that time you carry out a fuel learn the results will be slightly different due to weather conditions.
#1309 sworks
sworks
  • 1,566 posts
Posted 27 September 2014 - 11:36 PM
thumbsup
#1310 Sutol
Sutol
  • 8,122 posts
Posted 28 September 2014 - 07:45 AM
Thought I'd give it a go. Means absolutely nothing to me. Each pressure range plotted against rpm.
#1311 fezzasus
Posted 28 September 2014 - 08:53 AM
Looks like you might have a boost leak
#1312 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 28 September 2014 - 10:32 AM
what does your ign table look like?
#1313 Kieran McC
Kieran McC
  • 3,416 posts
Posted 09 October 2014 - 05:49 PM
Does the Dutch software allow you to set the rev tickover level ?
#1314 CHILL Gone DUTCH
Posted 09 October 2014 - 05:52 PM
Yes
#1315 CHILL Gone DUTCH
Posted 09 October 2014 - 05:57 PM
It is also controller able dependant on temperature
#1316 CHILL Gone DUTCH
Posted 09 October 2014 - 06:10 PM
and
#1317 Kieran McC
Kieran McC
  • 3,416 posts
Posted 09 October 2014 - 06:19 PM
Mine developed a higher tickover , A trip to CS to get it reset .
#1318 CHILL Gone DUTCH
Posted 09 October 2014 - 06:23 PM
Does it drop when everything is warmed up ??
#1319 Kieran McC
Kieran McC
  • 3,416 posts
Posted 09 October 2014 - 06:29 PM
I went to CS today and had it sorted. When it got warm it did the opposite the revs stayed higher , It was hard work getting smooth gear selection , Doing a trackday on Monday so it needed sorting.
#1320 TFD
TFD
  • 607 posts
Posted 16 October 2014 - 02:52 PM
Sorry to hijack, but another question:
How much power are you N/A guys getting with supporting mods and OBD-tuner? OBD-tuner power-o-meter wise...
How much more fun is this compared to stock 147hp? Still thinking of turbocharching my 2.2 but really dont have much time to build and rebuild so I'm leaning towards "fit, forget and have fun".
Grtz,
Daniel
