obdtuner remap z22se ecu
2116 replies to this topic
#1421 smiley
Posted 31 December 2014 - 09:29 AM
I'm afraid so.
How are you running the PCV just trying to get more information about trying to reduce this oil which everyone is suffering from at different rates it appears
My Z22SE was consuming quite some oil before i blew up the head gasket, as swapped for the B207.
The B207 has now done about 5000km with about 5 trackday. I only had to top it up a little 2 weeks ago.
Very happy with that. Also no i have heared of no oil problems from the lsj or the Z20NET when it comes to oil.
My pcv is open. Cam cover outlet goes to catchtank (empty last item i checked) and then to inlet pipe.
Oil smear on linlet pipe is at a minimum.
No changes on that for 2015 for me.
Edited by smiley, 31 December 2014 - 09:35 AM.
#1422 CHILL Gone DUTCH
Posted 31 December 2014 - 09:51 AM
 I'm afraid so.
  My Z22SE was consuming quite some oil before i blew up the head gasket, as swapped for the B207. The B207 has now done about 5000km with about 5 trackday. I only had to top it up a little 2 weeks ago.  Very happy with that. Also no i have heared of no oil problems from the lsj or the Z20NET when it comes to oil.   My pcv is open. Cam cover outlet goes to catchtank (empty last item i checked) and then to inlet pipe. Oil smear on linlet pipe is at a minimum.   No changes on that for 2015 for me.
This sounds like best option all round keeping any oil which is being pulled out of engine from blocking up the inlet, SC and laminovas 👍
#1423 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 31 December 2014 - 10:52 AM
if anyone wants a used good condition ls4 throttle bodies i can get them for £74 posted   chinky chinky
yes please Joe I have notice an increase in oil consumption/ loss sine fitting the harrop, must admit, I vent my breather overboard though stops the smell.
Edited by NickB777, 31 December 2014 - 11:00 AM.
#1424 Sutol
Sutol
    Well it's nearly a Lotus
  • 8,122 posts
Posted 31 December 2014 - 10:57 AM
On occasions I've noticed that the dipstick has lifted slightly after running on high revving type tracks. Also on checking the oil the oil level can be up to 150mm over Max, I know this is wrong though. It might seem daft but has anyone thought about putting a breather filter on the dipstick tube just to see if it makes a difference?
#1425 CHILL Gone DUTCH
Posted 31 December 2014 - 11:02 AM
I thought about putting a seperate breather somewhere at bottom of engine At the time though it was thought that you need a vacuume for the PCV works @fezzaus does oil expand much ??
#1426 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 31 December 2014 - 11:03 AM
It's hard for me as there's only really me and nick with harrops and z22se engines so it's going to behave different then there saab engines. I know mine is running sweet with no power loss ect and also the compression in all my pistions is the same so it's not loss through there. My PCV is the answer and I think maybe unblocking might be the thing to do and see how it gets on.
If someone could answer me this, I had the phonlic spacer blocking the hole in the head (how CS likes it for mapping) as there's no channel cut in the spacer and I noticed oil near the inlet after a track day
It looks like there's oil near where the injector goes in but it was bone dry done the hole and instead just oil moving to a lower point. I then stripped it down and found a little oil vapour in my inlet manifold which then I had to strip down and clean. I then sealed up this hole in the head as the phonlic spacer wasn't enough to stop the oil from pushing past it
Since sealing this ive had no oil getting into the inlet manifold as ive stripped it down and had a look but now have more oil coming out the breather as its venting into the atmosphere and is cable tied going down to my subframe which has fresh oil over it.
1.So do I risk it and open the pcv up?
2.Leave blocked and fit a catch tank?
3. Unblock pcv and fit catch tank?
#1427 NickB787
NickB787
  • 7,813 posts
there was a post by Vocky about making the breather hole on the cam cover larger, wonder if that might help
#1428 CHILL Gone DUTCH
Posted 31 December 2014 - 11:06 AM
On occasions I've noticed that the dipstick has lifted slightly after running on high revving type tracks. Also on checking the oil the oil level can be up to 150mm over Max, I know this is wrong though. It might seem daft but has anyone thought about putting a breather filter on the dipstick tube just to see if it makes a difference?[/quote ]I thought about putting a seperate breather somewhere at bottom of engine At the time though it was thought that you need a vacuume and under low revs you need opposite for the PCV works @fezzaus does oil expand much ??
Edited by CHILL Gone DUTCH, 31 December 2014 - 11:12 AM.
#1429 CHILL Gone DUTCH
Posted 31 December 2014 - 11:10 AM
You aren't getting anything in the inlet because it gets there from the pipe you have vented to atmosphere
#1430 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 31 December 2014 - 11:13 AM
The pipe is coming from the rocker cover so how does this go to the inlet?
#1431 CHILL Gone DUTCH
Posted 31 December 2014 - 11:17 AM
The same waY as air flows from inlet Pcv does 2 things Allows fresh air in and gets rid of bad gasses
Edited by CHILL Gone DUTCH, 31 December 2014 - 11:17 AM.
#1432 smiley
And Mige, and Lee, and Cliffie iirc. (not sure on chris_uk and Bargi)
Edited by smiley, 31 December 2014 - 11:18 AM.
#1433 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 31 December 2014 - 11:20 AM
Lee is Saab ain't he, and yeah I forgot about Chris. Not sure about the rest. Plus what I was meaning as well is z22se and dutch software.
Edited by haggi961, 31 December 2014 - 11:24 AM.
#1434 FLD
Posted 31 December 2014 - 11:33 AM
I'll have one fanny baws.
Hactually, I might give it a miss, it'll just sit in the loft!
#1435 smiley
Posted 31 December 2014 - 11:44 AM
Here's an attempt to create a list of harroped engines and software.
Feel free to correct where needed.
Edited by smiley, 31 December 2014 - 11:44 AM.
#1436 CHILL Gone DUTCH
Having the pipe from the cam cover open is a bad idea as it sucks under low rpm allowing fresh air into the engine which would be unfiltered and could pull debris in , @ sutil this is why it was decided a bad idea to vent from dipstick
#1437 FLD
Posted 31 December 2014 - 11:45 AM
Just reading through this it sounds like people are suffering from high crank case pressures.  It sounds like it could be either blow by from worn piston rings or from an enthusiastic overbore.  I'm not sure what clearance the wiseco pistons specify but could it be too great?
#1438 CHILL Gone DUTCH
Posted 31 December 2014 - 11:46 AM
I'm B207 2.2
Can you copy and paste rather than a picture so it can be edited
#1439 CHILL Gone DUTCH
Posted 31 December 2014 - 11:48 AM
Mine was standard bore and checked when vocky built engine ( new engine )
#1440 CHILL Gone DUTCH
Posted 31 December 2014 - 11:54 AM
Think it's also worth mentioning since putting my PCV back on to inlet my oil usage is less Than what it was when open to atmosphere Which o believe was caused by a build up if crank pressure rather than relieving it before it builds up to these levels
