obdtuner remap z22se ecu
2116 replies to this topic
#1441 FLD
Posted 31 December 2014 - 11:55 AM
Hmm, it is odd.  Blowing out the dipstick and high oil consumption definitely sounds like blowby.  I'll have to have a read on the wiseco data sheet.  Total seal rings definitely help with crank case pressures.
ETA: has anyone had some wiseco's out and checked the ring gaps?  I'm wondering if the rings aren't so good.
Edited by FLD, 31 December 2014 - 11:56 AM.
#1442 CHILL Gone DUTCH
Posted 31 December 2014 - 12:01 PM
Hmm, it is odd.  Blowing out the dipstick and high oil consumption definitely sounds like blowby.  I'll have to have a read on the wiseco data sheet.  Total seal rings definitely help with crank case pressures.   ETA: has anyone had some wiseco's out and checked the ring gaps?  I'm wondering if the rings aren't so good.
Think it's also worth mentioning since putting my PCV back on to inlet my oil usage is less Than what it was when open to atmosphere Which o believe was caused by a build up if crank pressure rather than relieving it before it builds up to these levels Dipstick also only blew out on mine when the PCV cam pipe was open to atmosphere not had this issue since re connecting back to inlet
Edited by CHILL Gone DUTCH, 31 December 2014 - 12:02 PM.
#1443 smiley
Posted 31 December 2014 - 12:03 PM
Can you copy and paste rather than a picture so it can be edited
orgers on harrops
Chris_uk             obdtuner      Z22SE Nick777              obdtuner      Z22SE Bargi                  obdtuner Haggi961           obdtuner      Z22SE Mige                   obdtuner      Z22SE Chill                    obdtuner      B207 2.2 Leevx2.2            standalone   Z22SE Cliffie                  courtenay    Z22SE with saab head (sold)
Exmantaa          HP Tuners   LSJ 2.0 Speedster4fun   HP Tuners   Z20NET 2.0 Ultimate             obdtuner      B207 2.0
Edited by smiley, 31 December 2014 - 12:04 PM.
#1444 CHILL Gone DUTCH
Posted 31 December 2014 - 12:05 PM
Pcv was also discussed last year http://www.vx220.org...eather-options/
#1445 CHILL Gone DUTCH
Posted 31 December 2014 - 12:06 PM
orgers on harrops   Chris_uk             obdtuner      Z22SE Nick777              obdtuner      Z22SE Bargi                  obdtuner Haggi961           obdtuner      Z22SE Mige                   obdtuner      Z22SE Chill                    obdtuner      B207 2.2 (m62 at moment ) Leevx2.2            standalone   Z22SE Cliffie                  courtenay    Z22SE with saab head (sold)   Exmantaa          HP Tuners   LSJ 2.0 Speedster4fun   HP Tuners   Z20NET 2.0 Ultimate             obdtuner      B207 2.0
Edited by CHILL Gone DUTCH, 31 December 2014 - 12:07 PM.
#1446 smiley
Posted 31 December 2014 - 12:08 PM
orgers on harrops   Chris_uk             obdtuner      Z22SE Nick777              obdtuner      Z22SE Bargi                  obdtuner Haggi961           obdtuner      Z22SE Mige                   obdtuner      Z22SE Leevx2.2            standalone   Z22SE Cliffie                  courtenay    Z22SE with saab head (sold)   Exmantaa          HP Tuners   LSJ 2.0 Speedster4fun   HP Tuners   Z20NET 2.0 Ultimate             obdtuner      B207 2.0
In that case you're out buddy.
Come back when it's on :sleep:
#1447 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 31 December 2014 - 12:09 PM
No oil loss when I was on the m62, only started since harrop and software change.
#1448 CHILL Gone DUTCH
Posted 31 December 2014 - 12:13 PM
This is why I think it's down to increased vacuume when it's connected to inlet Or Unrelieved crank pressure when it's not connected
#1449 FLD
Posted 31 December 2014 - 12:16 PM
Just another thought then...
The cam cover breather has a biiig maze type separator in it.  I wonder if, when on boost, this is proving restrictive causing higher crank case pressures.  When you come off  boost the PCV may get rid of the pressure.  The extra boost of stage 3 or harrop beyond that will just increase the crank case pressure problem.  I wonder if its a combination of piston fit causing crank case pressure and an inadequate breather system.
#1450 CHILL Gone DUTCH
Posted 31 December 2014 - 12:20 PM
@ Luke make sure you put a separate filter on if you don't connect to inlet pipe or you will pull shite in to engine
#1451 CHILL Gone DUTCH
Posted 31 December 2014 - 12:33 PM
  In that case you're out buddy. Come back when it's on :sleep:
Possibly next week
#1452 fezzasus
Posted 31 December 2014 - 12:54 PM
On occasions I've noticed that the dipstick has lifted slightly after running on high revving type tracks. Also on checking the oil the oil level can be up to 150mm over Max, I know this is wrong though. It might seem daft but has anyone thought about putting a breather filter on the dipstick tube just to see if it makes a difference?
I thought about putting a seperate breather somewhere at bottom of engine At the time though it was thought that you need a vacuume for the PCV works @fezzaus does oil expand much ??
approximately 10 % increase over 200 deg. C
#1453 Bargi
Bargi
  • 4,483 posts
Posted 31 December 2014 - 01:55 PM
orgers on harrops Chris_uk             obdtuner      Z22SE Nick777              obdtuner      Z22SE Bargi                  obdtuner Z22SE/Saab head Haggi961           obdtuner      Z22SE Mige                   obdtuner      Z22SE Chill                    obdtuner      B207 2.2 (m62 at moment ) Leevx2.2            standalone   Z22SE Cliffie                  courtenay    Z22SE with saab head (sold)   Exmantaa          HP Tuners   LSJ 2.0 Speedster4fun   HP Tuners   Z20NET 2.0 Ultimate             obdtuner      B207 2.0
#1454 smiley
Posted 31 December 2014 - 02:11 PM
orgers on harrops: Chris_uk                obdtuner       Z22SE Nick777                 obdtuner       Z22SE Bargi                      obdtuner      Z22SE/Saab head Haggi961               obdtuner      Z22SE Mige                      obdtuner      Z22SE Leevx2.2               standalone   Z22SE Cliffie                    courtenay     Z22SE with saab head (sold) Exmantaa             HP Tuners   LSJ 2.0 Speedster4fun      HP Tuners  Z20NET 2.0 Ultimate                obdtuner     B207 2.0
Planned for 2015: Chill                      obdtuner     B207 2.2 (m62 at moment) Smiley                  obdtuner     B207 2.0 (m62 at moment)
Edited by smiley, 31 December 2014 - 02:11 PM.
#1455 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 31 December 2014 - 02:16 PM
No problems here with dip stick when on the M62 or harrop and mine is blocked off.
Edited by haggi961, 31 December 2014 - 02:17 PM.
#1456 Arno
Arno
  • 1,238 posts
Posted 31 December 2014 - 02:27 PM
Have to agree with FLD.. Sounds a lot like crank pressurisation, especially if dipsticks are pushed out. The breather hole in the cam cover on the Z22 is quite small if you compare to other engines.
Honda boys that run big turbo's on the K20 do this sort of thing:
Connection in the top left is the OEM one. Two big vents are added/welded on and all are then routed to a big catchtank which collects the droplets and either breathes to the air (via a filter, smelly) or back to the intake.
Perhaps something similar can be found on US sites/forums with turbo'd or heavily SC'ed LSJ's?
#1457 fezzasus
Posted 31 December 2014 - 02:37 PM
The Z22SE (L61) GM build book also used a wider PCV vent
#1458 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 31 December 2014 - 02:39 PM
Mines venting to the atmosphere but there is no smell that everyone seems to talk about, what would this mean for me?
#1459 Kieran McC
Kieran McC
  • 3,416 posts
Posted 31 December 2014 - 02:43 PM
orgers on harrops: Chris_uk                obdtuner       Z22SE Nick777                 obdtuner       Z22SE Bargi                      obdtuner      Z22SE/Saab head Haggi961               obdtuner      Z22SE Mige                      obdtuner      Z22SE Leevx2.2               standalone   Z22SE Cliffie                    courtenay     Z22SE with saab head (sold) Exmantaa             HP Tuners   LSJ 2.0 Speedster4fun      HP Tuners  Z20NET 2.0 Ultimate                obdtuner     B207 2.0   Planned for 2015: Chill                      obdtuner     B207 2.2 (m62 at moment) Smiley                  obdtuner     B207 2.0 (m62 at moment)
Kieranmcc Courtnays B20 2.0 (M62 @ moment)
Edited by kieranmcc, 31 December 2014 - 02:46 PM.
#1460 mige
mige
  • 54 posts
Posted 31 December 2014 - 02:56 PM
I have a Second oil vent on Mine Works very Well Not much oil cunsumption with my wieseco pistons
