obdtuner remap z22se ecu
2116 replies to this topic
#1461 CHILL Gone DUTCH
Posted 31 December 2014 - 03:12 PM
I have a Second oil vent on Mine Works very Well Not much oil cunsumption with my wieseco pistons
You got of pic of position ?
#1462 smiley
Posted 31 December 2014 - 03:19 PM
Kieranmcc Courtnays B20 2.0 (M62 @ moment)
Will you keep it on courtenay map with the harrop?
#1463 Kieran McC
Kieran McC
  • 3,416 posts
Posted 31 December 2014 - 04:26 PM
When the Harrop is fitted and maped ,I will see how its running with tempratures etc, If I face problems which I can't see , I will look at getting the Dutch map.😀
#1464 Graeme Lambert
Graeme Lambert
  • 5,543 posts
Posted 31 December 2014 - 05:52 PM
On my phone and new tapatalk is sh*t, but can someone add me to 2015 list please? B207 with standalone Engine is in car, and all being well will be running in next few weeks.
#1465 CHILL Gone DUTCH
Posted 31 December 2014 - 06:00 PM
orgers on harrops: Chris_uk                obdtuner       Z22SE Nick777                 obdtuner       Z22SE Bargi                      obdtuner      Z22SE/Saab head Haggi961               obdtuner      Z22SE Mige                      obdtuner      Z22SE Leevx2.2               standalone   Z22SE Cliffie                    courtenay     Z22SE with saab head (sold) Exmantaa             HP Tuners   LSJ 2.0 Speedster4fun      HP Tuners  Z20NET 2.0 Ultimate                obdtuner     B207 2.0
Planned for 2015: Chill                      obdtuner     B207 2.2 (m62 at moment Harrop in jan 2015) Smiley                  obdtuner     B207 2.0 (m62 at moment)
G lambert            standalone B207 2.0 ( engine in place finished before jan 2015)
Edited by CHILL Gone DUTCH, 31 December 2014 - 06:00 PM.
#1466 smiley
Posted 31 December 2014 - 06:08 PM
Orgers on harrops: Chris_uk                Obdtuner       Z22SE Nick777                 Obdtuner       Z22SE Bargi                      Obdtuner       Z22SE/Saab head Haggi961               Obdtuner       Z22SE Mige                       Obdtuner      Z22SE Leevx2.2                Standalone   Z22SE Cliffie                     Courtenay     Z22SE with saab head (sold) Exmantaa              HP Tuners   LSJ 2.0 Speedster4fun       HP Tuners   Z20NET 2.0 Ultimate                 Obdtuner      B207 2.0
Planned for 2015: Chill                       Obdtuner      B207 2.2 (M62 at moment Harrop in jan 2015) Kieranmcc             Courtenay    B207 2.0 (M62 at moment) Smiley                   Obdtuner      B207 2.0 (M62 at moment)
G lambert              Standalone   B207 2.0 (Engine in place finished before jan 2015)
#1467 CHILL Gone DUTCH
Posted 31 December 2014 - 06:22 PM
I'm still after a base map for my 2.2 B207 Harrop with 3.1 pulley and 3" exhaust Or at least can you tell me what pressure range to use for this setup
#1468 smiley
Posted 31 December 2014 - 06:40 PM
If Peter will not respond (heared he's very busy last few weeks) you may try Ultimate.
He's been working intensly with peter being one of the first, so may have a basemap or 2 lying around.
If not, maybe he knows one of the germans running that setup also, but not active here.
Edited by smiley, 31 December 2014 - 06:44 PM.
#1469 CHILL Gone DUTCH
Posted 31 December 2014 - 06:47 PM
Cheers I've just emailed peter but I was trying to get in touch on obd forum So others can pick it up to If I have no joy I will try someone else as you mentioned
#1470 Sutol
Sutol
    Well it's nearly a Lotus
  • 8,122 posts
Posted 31 December 2014 - 07:31 PM
@ Luke make sure you put a separate filter on if you don't connect to inlet pipe or you will pull shite in to engine
sorry not sure I agree or probably understand. With my breather to atmosphere, if you take the oil filler cap off, put your hand over the filler hole, you can feel the blow by hitting your hand. If you connect the breather to the intake you will feel suction at the filler hole. At know point do I think the breather will suck in air when leftcfree to atmosphere. Am I wrong?
#1471 mige
mige
  • 54 posts
Posted 31 December 2014 - 07:44 PM
http://shop.zzperfor...et-Oil-Cap.aspx Sorry No picture But i take this Part And Make a hole for a Banjo d10
#1472 CHILL Gone DUTCH
Posted 31 December 2014 - 07:50 PM
For reference original design Excess gas and oil vapour is vented from the port between the inlet ports on the cylinder head. The vapour is mixed with the fresh air in the inlet manifold and burnt off during normal combustion. Fresh air is pulled in from the cam cover which connects to to the intake pipe after the air filter to ensure the fresh air is filtered. During full throttle applications, the PCV vent closes (there is too much pressure in the manifold and it will actually pressurise the crankcase). This effectively reverses the flow and some gas/vapour will come out of the cam cover CS modification The exhaust vent into the inlet manifold is blocked. This results in just one vent to atmosphere (cam cover) as there is now air trying to flow both out and in through the same hole 'bumping' happens, where volumes of oil are ejected. It's exactly the same as holding a full bottle upside down and letting the liquid drain out - it gluts/bumps as it lets liquid out and air in. This results in higher oil loss. OBD tuner implementation This is exactly the same as the original implementation of the PCV, however the cars typically have higher rev limits which means more time with the PCV vent closed. The implication of this is more time using the cam cover for both venting and pulling in fresh air. Not a problem when an NA, but if this is directly connected to the inlet manifold when supercharged there will be oil pulled into the laminiovas. Place a catch tank or oil filter in line, or use a small separate air filter. So Chris, the reason your car behaves like the PCV is blocked is because you've got a high rev limit, and at high revs the PCV is blocked.
#1473 CHILL Gone DUTCH
Posted 31 December 2014 - 07:55 PM
The actual question is is you PCV valve actually working ??
#1474 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 31 December 2014 - 07:56 PM
How does the oil seperator catch tanks work with a closed PCV system?
#1475 CHILL Gone DUTCH
Posted 31 December 2014 - 08:01 PM
The valve becomes closed under higher revs There are separators in the head but are overwhelmed so access is sucked through cam cover In to catch tank if you have a scourer or obstacle in catch tank it should collect and cool the oil and air continues to the inlet pipe
#1476 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 31 December 2014 - 08:07 PM
As I was looking at something like this.http://rennlist.com/...-catch-can.html
#1477 CHILL Gone DUTCH
Posted 31 December 2014 - 08:18 PM
Does it show how the separators work Some work by having a maze for air/oil to travel which leaves oil behind
#1478 Sutol
Sutol
  • 8,122 posts
Posted 31 December 2014 - 08:40 PM
Sorry chris I forgot to mention that what I described earlier happens at warm engine tickover. So lowest revs.
#1479 Sutol
Sutol
  • 8,122 posts
Posted 01 January 2015 - 08:35 AM
Just one more point, do I have to adjust any of the settings via obdtuner or do any mapping runs now that the pcv has been put into operation?
#1480 CHILL Gone DUTCH
Posted 01 January 2015 - 08:39 AM
No It's fine to just use it, I think it's more the CS route can't handle it.
6 user(s) are reading this topic
    Bing (2)
