obdtuner remap z22se ecu
2116 replies to this topic
#1561 CHILL Gone DUTCH
Posted 13 April 2015 - 04:07 PM
I take back the statement saying that Harrop is not worth having It is 😎
#1562 smiley
Posted 13 April 2015 - 04:17 PM
It just like to consume small apexi´s for breakfast.
#1563 Kieran McC
Kieran McC
  • 3,416 posts
Posted 13 April 2015 - 04:43 PM
Yep 2L with Vocky trigger wheel.
Are you fitting the Harrop as well ?
#1564 CHILL Gone DUTCH
Posted 13 April 2015 - 04:45 PM
He has
#1565 mige
mige
  • 54 posts
Posted 13 April 2015 - 06:54 PM
Looking good your filter
One of my Last measurements
Last Year
Very nice power line there, very good mapping is see,
Thanks it drives realy good
Nice Day
#1566 siztenboots
Posted 14 April 2015 - 08:58 AM
I thought the apexi was good for 500hp??!!
Never heard that but, never ever checked
What adapter plate would be required
Will see when I change my filter
But will be waiting for my ls4 to come before a choose a filter
Thinking of this
ideally go for the biggest filter possible as it will degrade slower , but still give best filtration
thus, 80mm MAF is the smallest part for mine and I used some hose as a sleeve to match the wider filter flange
#1567 TFD
TFD
  • 607 posts
Posted 14 April 2015 - 10:19 PM
Pic above: Don't know if its oem setup but I've learned not to put the MAF right after the filter because of turbulent airflow and therefore wrong readings. I had stalling issues with this setup on my Nissan. Put a 15cm ic-pipe between the filter and maf and all was well.
#1568 Arno
Arno
  • 1,238 posts
Posted 15 April 2015 - 07:53 AM
OEM air filter housings/attachments tend to have a coarse mesh or plastic honeybomb in the connecting pipe for that purpose. The mesh/honeycomb cuts the turbulence in the airflow and allows a MAF to work properly.
However, Z22SE doesn't have a MAF and only a MAP sensor which has no problems so no worries in this respect :)
#1569 siztenboots
Posted 15 April 2015 - 09:16 AM
bosch maf has a grid for laminar airflow
#1570 TFD
TFD
  • 607 posts
Posted 15 April 2015 - 08:30 PM
thumbsup
#1571 CHILL Gone DUTCH
Posted 20 April 2015 - 01:31 PM
Just thought I would share this for anyone who is running out of graph in pressure range and needs to change the pressure range So when you increase the pressure range from 12-240 to 13-260, it will make your engine run about 8% leaner. To compensate, you can simply select the whole fuel table by right clicking and clicking select all. Then use Edit->Edit selection % and make it 8% richer. For the ignition I would lower the whole table around 1-2 degree and then recalibrate it using the power measurement tool.
#1572 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 11 July 2015 - 10:00 AM
More map modification here please
#1573 CHILL Gone DUTCH
Posted 11 July 2015 - 10:26 AM
Matthew Bentley Racing Ltd, on 10 Jul 2015 - 5:39 PM, said:
Matthew Bentley Racing Ltd, on 09 Jul 2015 - 9:13 PM, said:
Afr will be 14's at idle. Late 13's low load running to late 12's on max boost.
Cock up alert, was just talking to someone about this and spotted my mistake. I meant Low 12's not late 12's at max boost. Sorry
But still not 11's
Don't think your running as lean as you first thought ( or I first thought ) after looking at the maps and various conversations
I've had with various people
Here is a more standard target AFR
And here is a MBR AFR on Bills car
Now on the face of it it looks like the settings on matts map his afr are running at 12.5 WOT depending on what pressure is running
But if you look at the correction numbers under the target AFR table it actually gives a different story
It only actual 12.5 of inlet temps are below 51 degrees
Where as a normally it's at 71 degrees before extra fuelling is added
So in effect if temps could be controlled on a RR than the 12.5 AFR would be being used for max powers but in reality on the road temps are very rare are below this temp
So matt has cleverly used the Tmap sensor on his calibration to control the power
At the same time keeping it safe enough on road/ track use when temps are likely to be higher
Edited by CHILL Gone DUTCH, 11 July 2015 - 10:30 AM.
#1574 NickB787
NickB787
  • 7,813 posts
Posted 11 July 2015 - 11:48 AM
Need to do some fuel and ign learning for the 2.7 then may have a look at the AFR.s and what we can gain
#1575 CHILL Gone DUTCH
Posted 11 July 2015 - 11:57 AM
The question is nick what do you want to gain Do you have a target ?? You may not need a smaller pulley if you use matt bentleys method
#1576 NickB787
NickB787
  • 7,813 posts
Posted 11 July 2015 - 12:03 PM
I had the 2.7 laying around for years since I'm not working much at the moment thought I would do some more R&D and see what IATs I get compared to the 2.9, will switch back then and try the different AFR settings, then add som WI
#1577 CHILL Gone DUTCH
Posted 11 July 2015 - 12:07 PM
👍 Data is key
#1578 NickB787
NickB787
  • 7,813 posts
Posted 11 July 2015 - 12:30 PM
Not impressed just making permanent of a safe ls4 map on the car and the computer crashed big time. Just hope I can recover the situ.
#1579 CHILL Gone DUTCH
Posted 11 July 2015 - 01:54 PM
This happened to me a few times nick I started reading the ecu during learning and saving every ten mins So there was no chance of losing it all
#1580 oakmere
oakmere
  • 2,143 posts
Posted 11 July 2015 - 04:13 PM
Regarding that dip at high rpm see my n/a graph from cs.
