its the green line not the blue sorry
for your pressures
your setup is running 150kpa @ 2500-180 kps @ 7000 go a few squares above and below
Edited by CHILL Gone DUTCH, 09 August 2015 - 08:35 PM.
Posted 09 August 2015 - 08:32 PM
for your pressures
Posted 09 August 2015 - 08:39 PM
after you have done the WOT use the ignition and knock measurement in the learn mode tab
this will reduce ignition in the table if you have knockt hroughout different pressures
This is what i missed, and is indeed in the manual.
After my powerrun, my kpa values were weird, and did not show the 90 (hence could not correct).
I then did a manual correction on my regular map.
Will try the ignition learn mode thingy again tomorrow evening.
Edited by smiley, 09 August 2015 - 08:42 PM.
Posted 09 August 2015 - 08:41 PM
there is a lot of trial and error with this
aha. Just what i like.
This is what i missed, and is indeed i the manual.
After my powerrun, my kpa values were weir, and did not show the 90 (hence could not correct).
i would find your max power/ignition @WOT first before doing this using the power method
Posted 09 August 2015 - 08:43 PM
i dont think the learn ignition sessions are very good at adding ignition but very good and removing it, so good idea to add the ignition first ( manually ) then allow the learn session to remove it where necessary
Edited by CHILL Gone DUTCH, 09 August 2015 - 08:44 PM.
Posted 09 August 2015 - 08:45 PM
im surprised that your pressures are that low
scrub that i forgot you were M62
Edited by CHILL Gone DUTCH, 09 August 2015 - 08:47 PM.
Posted 09 August 2015 - 08:52 PM
where you have that low down knock try putting you ignition to 20 ish as your cams look like they like it there ( just like my stage 2 cams)
Ok, so update my problem area to about 20, do another power run and see what happens on knock.
Posted 09 August 2015 - 08:55 PM
here is my stage 3 M62 stage 2 cams with 3.1 pulley trace versus yours
Can you email me the full log, so i can better understand your ignition table?
i'll pm you my email adress.
like i say its all trial and error you have to find the sweet spot
Posted 09 August 2015 - 09:01 PM
sent you a email,
ps it took 2 months to find the sweet spot on my stage 3 setup
Posted 09 August 2015 - 09:03 PM
you should also get a wideband fitted
Posted 09 August 2015 - 09:04 PM
I know.
Just trying to get a grip on what is a silly (small) correction, and what is an OTT correction that may get the engine into trouble.
Comparing stuff works best for me to get an understanding.
Posted 09 August 2015 - 09:06 PM
That's on my todo list
Posted 09 August 2015 - 10:37 PM
Laptop in the boot for Zandvoort... ;-)
Have to refresh my OBD skills a bit, but is there a table with ignition correction for temperatures? As Smiley's looks to be running less ignition (up top) than commanded @ 180KPa
Posted 09 August 2015 - 10:42 PM
I don't think so.
All you can see in the client software, is all i can see.
Posted 09 August 2015 - 11:14 PM
That log shows ~17° advance at max rpm, but your ignition table commands 18.8° @ 7000rpm and 180KPa...
(Think that is why your torque/power drops down near max rpm, but ignition tuning takes a lot of time and experience....)
Edit; think there is an IAT-ignition correction table in the Z22SE ecu, but not accessible through the OBD client software. And that is the table Peter changes when people complain of the power fading away on higher track temps...
Edited by Exmantaa, 09 August 2015 - 11:24 PM.
Posted 09 August 2015 - 11:35 PM
I believe you can get a custom one on request from Peter with less fade then starting at 57 degrees.
It's not in the client software, but quite a few cars have been done i heared, so Peter is comfortable with this by now (hearsay).
Posted 10 August 2015 - 05:13 AM
ignition is pulled by knock
fuel added for temps
there maybe a something happening in the back ground
The Market Place →
Car Parts For Sale →
Piper 2.5” Manifold And Miltek Mid Section For Z22seStarted by F757lkk@gmail.com , 30 Jun 2024 ![]() |
General Discussion →
Tuning & Modifications →
The Market Place →
Car Parts Wanted →
2.4L Intake Manifold (Gm12587878) For Z22SeStarted by HydroMike , 11 May 2020 ![]() |
VX220 Discussion →
Replacing The Ecu And Having IssuesStarted by den7 , 29 Feb 2020 ![]() |
VX220 Discussion →
Dbilas Turbo Kit - Z22SeStarted by Franke , 24 Feb 2020 ![]() |
