what version off the software are you using smiley
as the later version ignore knock up to 1 degree
Posted 10 August 2015 - 05:24 AM
Posted 10 August 2015 - 07:54 AM
2.7.1.6
Posted 10 August 2015 - 08:08 AM
Saab B207 stock internals, flowed head, ZZP LSJ Stage 1 cams, dbilas uprated springs. M62 with 3.05" pully. Tmap 2.5 bar. Full 2.5" tullett system with an oem turdo cat welded in. (after the tullett one failed)
You might be on the knock limit with the 9.5:1 compression pistons.
Posted 10 August 2015 - 08:39 AM
We are now using 2.7.7 You well out of date Get the latest version2.7.1.6
Posted 10 August 2015 - 08:42 AM
It is possible Tom but I don't thing the learn ignition is very good at adding ignition but is very good at reducing it if knock is detected Adding ignition I've always done manually followed by the knock learn sessionYou might be on the knock limit with the 9.5:1 compression pistons.Saab B207 stock internals, flowed head, ZZP LSJ Stage 1 cams, dbilas uprated springs. M62 with 3.05" pully. Tmap 2.5 bar. Full 2.5" tullett system with an oem turdo cat welded in. (after the tullett one failed)
Posted 10 August 2015 - 09:02 AM
I read the changelogs on all new versions, and it was all LS4 stuff, but will load up the latest this evening when doing a few runs.
Posted 10 August 2015 - 09:12 AM
Laptop in the boot for Zandvoort... ;-)
Have to refresh my OBD skills a bit, but is there a table with ignition correction for temperatures? As Smiley's looks to be running less ignition (up top) than commanded @ 180KPa
ignition is pulled by knock
fuel added for temps
there maybe a something happening in the back ground
Ignition is off course pulled by Knock Retard, but even without any knock the ignition is still not identical to the commanded spark advance. There is a hidden table that puls a bit of advance with increasing IAT temps. (and there are lot's of hidden correction tables in the Z22SE ecu.. )
Posted 10 August 2015 - 09:13 AM
Posted 10 August 2015 - 09:15 AM
Posted 10 August 2015 - 09:16 AM
Posted 10 August 2015 - 09:27 AM
Are you tuning your car without a wideband?
How can you do that? AFR's are as important as timing and other stuff. Running lean can cause knock as well wich you are now trying to correct with ignition retard while fuel may be the key.
Smiley, get a wideband in first a.s.a.p.
Posted 10 August 2015 - 11:16 AM
Edited by NickB777, 10 August 2015 - 11:17 AM.
Posted 10 August 2015 - 06:53 PM
Posted 11 August 2015 - 08:01 AM
Posted 11 August 2015 - 08:44 AM
I guess we'll see how I get on with 10.4:1 and a 3.0" pulley then...
And no wideband!!! OMFG!
Posted 11 August 2015 - 09:37 AM
Smiley, which fuel are you using?
98 ron
Posted 11 August 2015 - 09:39 AM
For all you haters:
i'm putting back in the basemap, and will put in the wideband before continuing doing anything ignition related
Posted 11 August 2015 - 09:47 AM
Posted 11 August 2015 - 09:48 AM
The Market Place →
Car Parts For Sale →
Piper 2.5” Manifold And Miltek Mid Section For Z22seStarted by F757lkk@gmail.com , 30 Jun 2024 ![]() |
General Discussion →
Tuning & Modifications →
The Market Place →
Car Parts Wanted →
2.4L Intake Manifold (Gm12587878) For Z22SeStarted by HydroMike , 11 May 2020 ![]() |
VX220 Discussion →
Replacing The Ecu And Having IssuesStarted by den7 , 29 Feb 2020 ![]() |
VX220 Discussion →
Dbilas Turbo Kit - Z22SeStarted by Franke , 24 Feb 2020 ![]() |
