Did you ask Peter for the latest "track oriented" tune? (for the expected higher IAT's..)
#1641
Posted 11 August 2015 - 09:48 AM
#1642
Posted 11 August 2015 - 10:01 AM
That's a good one.
Not that i will need it this Friday, as it looks now, but may come in handy.
#1643
Posted 11 August 2015 - 10:06 AM
Is Peter going to be there on Friday? Or does the thought of being pestered all day by 20 VX and Speedster owners fill him with dread?
#1644
Posted 11 August 2015 - 10:18 AM
So go back to base map add the fuel learn
But don't smooth it until you do the wideband WOT mapping then smooth it out
okidokie.
You think just another fuel session will help me get the knock out?
Here's the result from yesterday evening, trying to smooth the basemap (with my small knock issue at low rpm)
I managed to turn my mountain into a W shape. with just a small correction.
I think you're right Chris. This is going to take forever to get spot on.
Lot's to learn.
#1645
Posted 11 August 2015 - 10:21 AM
Not sure where he is with his car now.
He sold the rotrex kit to MarkV (www.verboom.net) and was planning to put a turbo on.
Unfortunately he's not much of a forum poster, and his name is not on the list for friday. So i doubt he wil be there.
#1646
Posted 11 August 2015 - 10:38 AM
Probably wise.
#1647
Posted 11 August 2015 - 10:53 AM
Probably wise.
afaik he only has happy customers.
Just with lot's of questions
#1648
Posted 11 August 2015 - 10:57 AM
#1649
Posted 11 August 2015 - 10:58 AM
#1650
Posted 11 August 2015 - 11:05 AM
#1651
Posted 11 August 2015 - 11:21 AM
Smiley have you tried my map directly on your car 😬🔥😈😼
i am getting tempted......
#1652
Posted 11 August 2015 - 11:23 AM
#1653
Posted 11 August 2015 - 11:28 AM
FYI I also went through the heavy knock values you are seeing and found tHe sweet spot on the other side ie more ignition
I did not expect that
#1654
Posted 11 August 2015 - 11:33 AM
How far of are your fuel values from mine ??
i'll check.
Here's my full current base map with the fuel learning i did earlier this year (minus the small ignition update from yesterday evening)
http://www.speedster...ive/fullecu.zip
Edited by smiley, 11 August 2015 - 11:33 AM.
#1655
Posted 11 August 2015 - 12:10 PM
I'm a little underwhelmed with it, since fitting it, if I'm honest. Apart from the cold running improvements and the flexibility of changing components at will, the whole car feels a bit lethargic when compared with the original Courtenay map and it has a nasty occasional misfire type thing (a little like you get with a Scangauge connected) when making progress and shifting quickly between gears. Hadn't encountered the misfire until I applied a different map from Peter to better handle aftermarket cams.afaik he only has happy customers. Just with lot's of questions
#1656
Posted 11 August 2015 - 12:11 PM
It took me 2 months to get the stage 3 file I sent you as smooth as it is with no knock Fuel is also important As is a wideband
How did you find that one out, as it's pretty scary to dial in more ignition when you have knock...
#1657
Posted 11 August 2015 - 12:23 PM
Peter is usually very helpfull with sorting map issues, so maybe talk to him.
(Or Chill, as he seems to be becomming the nr 2 expert on obdtuner )
#1658
Posted 11 August 2015 - 12:29 PM
After spending even longer to get the car to run well on the cams I basically took a punt and added a lot of ignition The car ran better immediately so I took it from there and did a knock learn session which pulled the ignition down where knock was detected by the ecu It was a last resort because I couldn't get it to make anything like the power I was expectingHow did you find that one out, as it's pretty scary to dial in more ignition when you have knock...It took me 2 months to get the stage 3 file I sent you as smooth as it is with no knock Fuel is also important As is a wideband
Edited by CHILL Gone DUTCH, 11 August 2015 - 12:30 PM.
#1659
Posted 11 August 2015 - 12:32 PM
Edited by CHILL Gone DUTCH, 11 August 2015 - 12:33 PM.
#1660
Posted 11 August 2015 - 12:45 PM
The Market Place →
Car Parts For Sale →
Piper 2.5” Manifold And Miltek Mid Section For Z22seStarted by F757lkk@gmail.com , 30 Jun 2024 ![]() |
General Discussion →
Tuning & Modifications →
The Market Place →
Car Parts Wanted →
2.4L Intake Manifold (Gm12587878) For Z22SeStarted by HydroMike , 11 May 2020 ![]() |
VX220 Discussion →
Replacing The Ecu And Having IssuesStarted by den7 , 29 Feb 2020 ![]() |
VX220 Discussion →
Dbilas Turbo Kit - Z22SeStarted by Franke , 24 Feb 2020 ![]() |
