obdtuner remap z22se ecu
2116 replies to this topic
#1701 Exmantaa
Posted 09 November 2015 - 10:41 PM
Fuel then ignition
That's where you start, as there is the most difference between builds. Mixture should be safe (thermally) for your engine's load, but you should always keep an eye (and ear) out for knock, as that can kill your engine fast.
So start with a safe basic timing map, learn fuel low loads, learn fuel high loads and then start optimising ignition => re-check fuelling => ignition again. :happy:
#1702 CHILL Gone DUTCH
Posted 09 November 2015 - 10:58 PM
chicken or the egg
lol
#1703 TFD
TFD
  • 607 posts
Posted 05 December 2015 - 12:22 PM
Short question: Does OBD-Tuner still work OK when I upgrade my laptop from Win 8.1 to Win 10?
Maybe a no-brainer but just want to make sure.
#1704 CHILL Gone DUTCH
Posted 05 December 2015 - 12:40 PM
I'm sure it will I have uprated my laptop with no issues after I got the right drivers
#1705 TFD
TFD
  • 607 posts
Posted 06 February 2016 - 06:52 PM
Did the first run today with the 2.2 turbo. When cold, in neutral, it sometimes want to stall when I rev the throttle and let go.. Ideas? Selected "liniar" trottlebody for that matter. This issue seems solved when warmed up.
How is your AFR while coasting? Mine ran 22.6:1 which is max lean. I know it should be lean due fuel cutoff, but still...
Thanx guys.
#1706 CHILL Gone DUTCH
Posted 06 February 2016 - 07:09 PM
Mine also goes to 22 when costing ( clutch in )
#1707 CHILL Gone DUTCH
Posted 06 February 2016 - 07:10 PM
Then build back up to 14s
#1708 CHILL Gone DUTCH
Posted 06 February 2016 - 07:11 PM
I'm Not a turbo How are you regulating the fuel and what happens to boost pressure when you cost ??
#1709 TFD
TFD
  • 607 posts
Posted 06 February 2016 - 07:51 PM
What do you mean by fuel regulating?
I run stock fuelpressure with VXR 470cc's and vacuum connected to intake manifold.
Below  a shot of mappressure vs. rpm
So drops to 20 kPa. Now I pressume 100kpa = 1 bar = sealevel pressure hence "0" bar. So 20kpa is actually -80 kpa = -0.8 bar which is good.
So 22 AFR when coasting is OK. Now the stall issue when cold...
Edited by TFD, 06 February 2016 - 07:55 PM.
#1710 CHILL Gone DUTCH
Posted 06 February 2016 - 07:58 PM
By regulating the fuel I meant are you using boost ? Which it looks like you are
#1711 TFD
TFD
  • 607 posts
Posted 06 February 2016 - 08:08 PM
Ahh..ok. Yes I did a short run in that screenshot-log. 0.5 bar of boost.
#1712 TFD
TFD
  • 607 posts
Posted 06 February 2016 - 08:26 PM
I just saw my Map Delta #'s. Looks like my Coasting <33C seems high? 27,5 ??
The example in the instructionbook says 14.9, not sure where that came from.
A higher value means the time the enrichment last is very short (the higher, the faster back to "0")
#1713 CHILL Gone DUTCH
Posted 06 February 2016 - 08:35 PM
its up to you but i wouldent drive the car when its that cold
#1714 Exmantaa
Posted 06 February 2016 - 09:44 PM
I would make those two tau values 14.9 indeed, like in most of the SC mappings, and see what that brings. X-tau settings are a bit trial an error... :-/
#1715 TFD
TFD
  • 607 posts
Recieved some log-files from Smiley tonight. Seems like the Harrop and DaveyC maps have simular [color=rgb(0,0,0);font-family:'Helvetica Neue', 'Segoe UI', Helvetica, Arial, 'Lucida Grande', sans-serif;font-size:14.6667px;]Time=1/vaue #'s.[/color]  So 3 people having some idle/cold problems with this one. Going to put the M62 values into my map tomorrow and see if this helps.
#1716 smiley
Posted 09 February 2016 - 10:01 PM
Is there any chance you can explain what the changes in the various transient maps made to your car?
That way we get a better impression of what these values do, versus "chuck this in, and life is good".
(maybe better in the obdtuner topic,  instead of Dave´s thread.)
Edited by smiley, 09 February 2016 - 10:02 PM.
#1717 CHILL Gone DUTCH
Posted 09 February 2016 - 10:12 PM
starting with throttle speed
quite straight forward.
setting up to 5000RPM
stationary and drive  (car parked and  car moving )
this is the speed the tb body reacts to your foot, this is probably quite unique to each driver i combined this with the throttle tab here when trying to tune the LS4
#1718 CHILL Gone DUTCH
Posted 09 February 2016 - 10:25 PM
Map delta is not quite as straight forward
Part 1
and what i think might not be correct exactly but its what i found when changing the figures
i think this is down to the amount of fuel which is added for when the map pressure isnt what is expected so lets hope most of that table is not used unless there is a issue somewhere
as you can see from my table when my map pressure is 100% ok (0% difference) and adding 0.8% of fuel i think this should be lower.
now i do wonder if this is to do with what is happening with atmospheric conditions  which could change the map pressure or a boost leak or exhaust restriction  /issue
#1719 CHILL Gone DUTCH
Posted 09 February 2016 - 10:39 PM
Thank q mods
#1720 CHILL Gone DUTCH
Posted 09 February 2016 - 10:57 PM
part 2
throttle fly position up to 50% self explained
correction i think is down to balancing the fuel with the change in the throttle
part 3
is down to the amount of time the change is applied
throttle valve delta,
this is what i think i need to do a lot more work on but think these values are so high because of the LS4 throttle bodie  which is now not supported without the reflash on the ecu but you will have to speak more to peter about this
i think the worry here was the control over the throttle body and these setting are this high incase the car runs lean.
    Bing (1)
