version 2.7.9 released
Posted 22 February 2016 - 06:19 PM
Posted 26 February 2016 - 08:48 AM
What's new in this one?
I got my ECU back from flashing earlier this week so I guess I missed out on that one
Posted 26 February 2016 - 08:52 AM
As I understand it, the software on the ECU is constant, but the software on the computer is updated. you can download the newest version from the OBD tuner website.
Posted 26 February 2016 - 09:03 AM
No no That's just the software you use with the reflashed Ecu So you haven't missed out on anything See the download section in obdtuner website it's there for you to use
Don't I feel stupid now. It's obviously the client software that is new
I'll just go back to programming huge mine drilling rigs now...
Posted 26 February 2016 - 09:17 AM
you will basically have access to all of version 2 updates.
Posted 20 March 2016 - 07:53 PM
To keep it central in one topic.
Dip in the highrev range
Mail from Peter to Chill
[color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]Hi Chris,[/color]
[color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]I did have a look at the log and there are few things happening:[/color]
[color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]It looks like you did not drive very much full throttle after connecting the [/color]battery[color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;], the long term fuel trim for full power is at 0% so the ECU did not yet compensate for the weather conditions etc. Normally when driving on the track you also use the transition zone where the ECU is still in closed loop but already in the full throttle fuel trim. During this time the full throttle fuel trim gets learned.[/color]
So I guess this also appears for me (others?)
Posted 20 March 2016 - 08:02 PM
yeah after resetting the fuel trims or allowing the battery to go flat completely or disconnected
Posted 20 March 2016 - 08:14 PM
Need to drive more full beans to get the trim right I guess.
Posted 20 March 2016 - 08:17 PM
unless there perfect from the feed back from the sensors is a perfect match to fuel table they will be different ( no chance of this ) so yes you need to drive more over 3600 - limiter
Posted 11 June 2016 - 04:00 PM
Posted 11 June 2016 - 04:03 PM
Posted 11 June 2016 - 04:04 PM
Posted 03 July 2016 - 08:02 PM
Let's talk about (false) knock..
When building my timing map I allready dropped timing to about 13 degrees due knock.
Builded the map with more timiing up the rev range and finally got myself a knockfree powerrun.
Few days later I did the same powerrun on the same road and got 5 degrees knock retard. Did some more tests and the knock retard is very hard to reproduce (it occurs whenever it wants..).
I've checked my sparkplugs and they look good. Checked the top of the pistons and no sign of wear. When doing powerruns (or drive for that matter) I dont hear detonation rattle/ping (yes I know how it sounds). The SC guys run 5-8 degrees more advanced timing at the same boostlevel / afr.
I think something is off and the knocksensor is triggered by something other then engine-knock.
Could this be false knock? Caused by some vibrating stuff in the enginecompartment or something? No faultcodes either.
Posted 03 July 2016 - 08:06 PM
yes the knock sensor is very sensitive
chek undertrays are nice and tight and soften the shocks and it might sound mad but pump the tires up to 30 psi right round
Posted 03 July 2016 - 08:08 PM
many years ago I recall reading that the guys in the states had a similar issue (false knock), they mentioned fitting a rubber washer between the knock sensor and the engine block.
I cannot remember what the outcome was or even if it was a sensible solution or a total waste of time.
Edited by vocky, 03 July 2016 - 08:08 PM.
Posted 03 July 2016 - 08:10 PM
i also found that running ignition that was to low can also cause knock so dont automatically go low, but as you are turbo charged things may be a bit different
also here in the uk most will run a higher octane fuel so if there is knock its with a lot higher advance
Posted 03 July 2016 - 08:24 PM
This is a simple one but a lot of others have suffered with a simple mistake
After you built the ignition up are you sure you made it permanent on to the ecu
if not it can reset back to the original settings when you turn ignition off
Posted 03 July 2016 - 08:25 PM
I'll look up the rubber washer trick, thanx.
About to retarded timing can cause a lot of heat due too to late of burning. This can be compensated a little by running rich (slow flame burn).
Haven't found out if too retarded causes high EGT's and therefore knock (if high EGT's would cause knock in the first place..).
Thanx guys
Posted 03 July 2016 - 08:27 PM
Nope, I've read the manual
The Market Place →
Car Parts For Sale →
Piper 2.5” Manifold And Miltek Mid Section For Z22seStarted by F757lkk@gmail.com , 30 Jun 2024 ![]() |
General Discussion →
Tuning & Modifications →
The Market Place →
Car Parts Wanted →
2.4L Intake Manifold (Gm12587878) For Z22SeStarted by HydroMike , 11 May 2020 ![]() |
VX220 Discussion →
Replacing The Ecu And Having IssuesStarted by den7 , 29 Feb 2020 ![]() |
VX220 Discussion →
Dbilas Turbo Kit - Z22SeStarted by Franke , 24 Feb 2020 ![]() |
