obdtuner remap z22se ecu
2116 replies to this topic
#1821 siztenboots
Posted 08 July 2016 - 01:56 PM
if only those figures were torque ( foot pounds )
#1822 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 08 July 2016 - 02:22 PM
Might be a good idea to get some sleep if your yawning as its affecting what your typing 😀 When I was in your car it didn't feel as quick as it could be, which is down to your map I reckon. All your have done is fuel learning so in theory your on the base map. Are engines are the same with internals but no two engines are the same as i run my engine in different then yours for a start.. Mine is also decat plus has a good breathing Airfilter where as yours is a paper cone filter from a puma which is in direct contact of water through the vents. I also have 6 rib conversion so less likely of belt slip and fatter tyres to put the power down better.
#1823 chris_uk
Posted 08 July 2016 - 02:28 PM
lol.
#1824 Crabash
Crabash
    Scared
  • 1,686 posts
Posted 08 July 2016 - 02:58 PM
Vid is private and wish it to stay so, don't want that kind of attention, thanks for respecting.
#1825 The Batman
Posted 08 July 2016 - 03:05 PM
Luke's car ha a lot of porting on it so should make some nice difference :)
#1826 chris_uk
Posted 08 July 2016 - 04:11 PM
My my dads harder than your dad..
#1827 The Batman
Posted 08 July 2016 - 05:00 PM
I would hope so under the circumstances!
Edited by The Batman, 08 July 2016 - 05:13 PM.
#1828 ArticMonkey
ArticMonkey
  • 4,792 posts
Posted 09 July 2016 - 09:40 PM
Considering haggi hasn't had years of experience on PlayStation driving he's done pretty well keeping up with the northern scuffers. I love forum politics and indirect fallouts. :lol:
Edited by ArticMonkey, 09 July 2016 - 09:42 PM.
#1829 chris_uk
Posted 09 July 2016 - 10:06 PM
:gayfight:  :gayfight:
#1830 leevx2.2
leevx2.2
  • 4,830 posts
    getting p!!sed
Posted 10 July 2016 - 07:20 AM
Northern Scuffers i love it , Nail on head lmfao
#1831 Nev
Posted 10 July 2016 - 09:04 AM
If you PM me your private linky, I'll send you one of mine from my last outing ;)
Edited by Nev, 10 July 2016 - 09:05 AM.
#1832 chris_uk
Posted 10 July 2016 - 09:08 AM
it aint that exciting nev. lol
#1833 leevx2.2
leevx2.2
  • 4,830 posts
    getting p!!sed
Posted 17 July 2016 - 12:32 PM
Looking for the colour of wire to connect to the EGR for my wideband ,as I cut of plug and wired cheat in so can't copy position on obd book .Anybody no ? Cheers
#1834 smiley
Posted 17 July 2016 - 12:44 PM
Brown with blue stripe. (Y4 from the diagram:)
http://www.speedster...e Z22SE - 1.pdf
Edited by smiley, 17 July 2016 - 12:45 PM.
#1835 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 17 July 2016 - 12:46 PM
Brown and purple rings a bell but will double check through my pictures. Beaten to it and not brown and purple 😂
Edited by haggi961, 17 July 2016 - 12:47 PM.
#1836 TFD
TFD
  • 607 posts
Posted 17 July 2016 - 08:44 PM
...and now something completely different.
I fitted the one step colder NGK ITR7IX-11 spark plugs instead of the OEM grade 6 plugs. Gapped them to 0,8mm.
Right now I'm around 18 degrees timing @ 0.5 bar of boost and running 240ish bhp. Seems more like it then the 14 degrees timing I ran previously.
Knocksensor still seems to work.
Stuff got heatsoaked so stopped the powerruns and called it the day. Looks like there is a tiny bit more timing to be gained at this boostlevel.
Set the fuel target to 11.7:1 on boost from 3000rpm. Not spot on right now but will be this week.
Gonna finetune the map per 0.1 bar of boost and see what happens. So far so good.
#1837 CHILL Gone DUTCH
Posted 17 July 2016 - 09:20 PM
Will you increase the temp rating (plugs ) when you increase the boost level further
Edited by CHILL Gone DUTCH, 17 July 2016 - 09:21 PM.
#1838 TFD
TFD
  • 607 posts
Posted 17 July 2016 - 09:37 PM
No. I think NGK grade 7 is good enough. Ran the 7 on 1.4 bar/400hp car in the past and did great.
It's still a bit confusing though.
In the US the L61 guys run a grade 5 plug as stock while the EU Z22SE guys run a grade 6 as stock plug.
Most stock turbocharged engines come with the grade 6 and the 7 would be the normal upgrade when tuning for more.
Have to work on the engaging btw. Car wans to stall when taking off in first gear. Need to rev it a bit. Tweaking the transient map I guess.
#1839 CHILL Gone DUTCH
Posted 17 July 2016 - 10:04 PM
I run ngk 8 and was going to try A 9 next year As I still don't get the browning I would like to see on the plug insulator ( ceramic )
Edited by CHILL Gone DUTCH, 17 July 2016 - 10:06 PM.
#1840 Bargi
Bargi
  • 4,483 posts
Posted 17 July 2016 - 10:19 PM
you got stage 2/3 cams? If so send your map to Peter and ask him to add changes for the cams. Made a big difference on ZZP stg 2 cams for me.
