obdtuner remap z22se ecu
2116 replies to this topic
#1841 TFD
TFD
  • 607 posts
Posted 17 July 2016 - 10:22 PM
No cams installed right now.
#1842 CHILL Gone DUTCH
Have to work on the engaging btw. Car wans to stall when taking off in first gear. Need to rev it a bit. Tweaking the transient map I guess.
you got stage 2/3 cams? If so send your map to Peter and ask him to add changes for the cams. Made a big difference on ZZP stg 2 cams for me.
Just so you now ray ( bargi ) this one is also a turbo 😜 TFD what came are you running
#1843 Bargi
Bargi
  • 4,483 posts
Posted 17 July 2016 - 10:33 PM
All the same when they're off boost :) Sent from my GT-I9305 using Tapatalk
#1844 TFD
TFD
  • 607 posts
Posted 19 July 2016 - 08:52 PM
I run the stock 2.2 cams. There shoudnt be a reason for poor engaging compared to oem. Like bargi said.. its all the same offboost (as well as on boost btw).
#1845 chris_uk
Posted 20 July 2016 - 09:36 AM
My compcam blower cams are god awful atm when trying to pull away in first.. If its cold just forget it, it does get better as the car warms.
#1846 oakmere
oakmere
  • 2,143 posts
Posted 20 July 2016 - 01:16 PM
For poor engaging try increasing fueling in the main fuel table for 600 800 and 1000 rpm. I found this helped me out. Look at the OEM fuel map on the obdtuner forum and you will see there is more fuel at 600 rpm than most of the map where as my map tailed the fueling down through the rpm range.
#1847 TFD
TFD
  • 607 posts
Posted 20 July 2016 - 01:23 PM
Thank you. Will give it a go tonight.
#1848 Bargi
Bargi
  • 4,483 posts
Posted 20 July 2016 - 08:31 PM
have you mentioned this to Peter?
There's an update he can do, improved mine in stop start traffic a lot.
There's a post and video about it somewhere.
Drop him and email with your current map and he'll do the adjustments.
#1849 chris_uk
Posted 21 July 2016 - 02:06 PM
I intend to once its all sorted and i have done another fuel learn.
#1850 fezzasus
Posted 21 July 2016 - 02:15 PM
I would strongly suggest you do that before you do another fuel learn, as any changes on how to ECU handles cams will affect fuel
#1851 chris_uk
Posted 21 July 2016 - 02:19 PM
If it does ill just do another learn.
#1852 smiley
Posted 21 July 2016 - 02:32 PM
Can you do a powerrun while you're out? We''ll add 30bhp due to the hot weather 😊
#1853 CHILL Gone DUTCH
Posted 21 July 2016 - 03:02 PM
He got water injection now
#1854 vocky
Posted 21 July 2016 - 04:05 PM
are they vernier'd in ?
#1855 chris_uk
Posted 21 July 2016 - 10:44 PM
I dont know, you fit them, did you vernier them in?
#1856 smiley
Posted 25 July 2016 - 07:56 AM
Does anyone have a dynolog or obdtuner power log from a Z22se using obdtuner or courtenay mapping that shows a Climbing result over 7k rpm?
#1857 CHILL Gone DUTCH
Posted 25 July 2016 - 11:50 AM
7200
#1858 CHILL Gone DUTCH
Posted 25 July 2016 - 11:52 AM
#1859 CHILL Gone DUTCH
But none of then raising to the limiter
#1860 smiley
Posted 25 July 2016 - 12:19 PM
Anybody tried a powerrun in 3rd gear giving the ecu more time to log?
