#1858 is pretty much up to the rev limiter
#1861
Posted 25 July 2016 - 12:21 PM
#1862
Posted 25 July 2016 - 12:32 PM
And was 3rd gear power runs#1858 is pretty much up to the rev limiter
#1863
Posted 25 July 2016 - 12:36 PM
#1864
All second gear attempts cut off near 7k?
#1865
Posted 25 July 2016 - 12:51 PM
#1866
Posted 12 August 2016 - 05:47 PM
#1867
Posted 12 August 2016 - 06:52 PM
Edited by ultimate, 12 August 2016 - 06:53 PM.
#1868
Posted 12 August 2016 - 07:24 PM
#1869
Posted 13 August 2016 - 07:47 AM
#1870
Posted 13 August 2016 - 07:54 AM
If you are running a stage 2, i asume you're running a stock engine?
That leaves you around the 250/260 mark, regardless if using CS map or obdtuner.
If you engine is enforced and you do go dutch, it's a matter of first trying more agressive ignition (contact chill), or a smaller pully.
Or both.
Edited by smiley, 13 August 2016 - 08:07 AM.
#1871
Posted 13 August 2016 - 07:55 AM
Im running stage 2 SC, im wanting more power though. Im assuming it would it be possible to run greater power at a later stage with no issues. Had the car just over a year now, and have the CS map on it, however, having heard about the improvements possible with this software, its mighty appealing.
Depends what you mean by 'at a later stage' if you change your con rods and pistons between now and then, then of course you can run more power, but its commonly accepted that 250/260 bhp is the limit for standard conrods (GM tested them failure slight above this, but this was with N2O injection and didn't include the HP lost to running the supercharger).
#1872
Posted 13 August 2016 - 08:38 AM
#1873
Posted 13 August 2016 - 09:04 AM
The mapping functionality is 100% identical for either stage 2, all the way up to 5.
#1874
Posted 13 August 2016 - 09:12 AM
I saw this for the first time this month, and thought i'd mention it.
When you run an obdtuner logging, and an error code is generated during the logging session, you will get an extra tab called "freezeframe".
It's not mentioned in the manual.
Edited by smiley, 13 August 2016 - 09:13 AM.
#1875
Posted 13 August 2016 - 10:18 AM
#1876
Posted 13 August 2016 - 12:17 PM
Download the software and play around with it. It essentially gives you an open ecu, you can set the temperature the fan comes on, injector type, disable get so on as well as mapping facilities and power measuremrntThe only benefit id have is better driveability, and no need for RR sessions?
#1877
Posted 15 August 2016 - 07:56 AM
#1878
Posted 15 August 2016 - 08:21 AM
I think this has been in the software for quite some timeI saw this for the first time this month, and thought i'd mention it.
Must mean you haven't any error codes Stefan
#1879
Posted 15 August 2016 - 08:26 AM
Was very useful for me when I was getting my car running again.
#1880
Posted 15 August 2016 - 08:44 AM
It was not my log indeed, when i first saw this
The Market Place →
Car Parts For Sale →
Piper 2.5” Manifold And Miltek Mid Section For Z22seStarted by F757lkk@gmail.com , 30 Jun 2024 ![]() |
General Discussion →
Tuning & Modifications →
The Market Place →
Car Parts Wanted →
2.4L Intake Manifold (Gm12587878) For Z22SeStarted by HydroMike , 11 May 2020 ![]() |
VX220 Discussion →
Replacing The Ecu And Having IssuesStarted by den7 , 29 Feb 2020 ![]() |
VX220 Discussion →
Dbilas Turbo Kit - Z22SeStarted by Franke , 24 Feb 2020 ![]() |
