obdtuner remap z22se ecu
2116 replies to this topic
#1921 CHILL Gone DUTCH
Posted 13 September 2016 - 10:17 PM
One other thing I should mention peak power might come long before peak ignition But you need to think about what is happening when intake temps are high and knock is detected as you don't want the ignition to pull so much that it pulls it to far
#1922 CHILL Gone DUTCH
Posted 13 September 2016 - 10:30 PM
Also what I have found the closer to peak ignition you get the cooler the iat seem to be do always keep a eye on intake temps also
#1923 phippsy
phippsy
  • 472 posts
Posted 14 September 2016 - 07:33 AM
Cheers smiley I'll have a look at a tablet then, looks more practical than a laptop. Chill what sort of inlet Temps would you consider high? I don't know at what temperatures you begin to lose power. I have a pa cc rad and duel pass mod so I'm hoping for decent inlets temps
Edited by phippsy, 14 September 2016 - 07:34 AM.
#1924 Jocke_D
Jocke_D
  • 407 posts
Posted 14 September 2016 - 08:03 AM
phippsy - I'm just about on the same step as you. Completed my SC just before summer but as time is really limited I don't get to play that much.
I'll be looking a lot here to see what you come up with but of course also try to bring my own findings whenever I can.
First, I have bought an ASUS 10.1" tablet with detachable keyboard. It's running win10. No problems with OBDTuner at first. Then I got an OS upgrade and it didn't work but fixed that with a minor .net upgrade. Basically the tablet tells you what to do to make it work.
It is really easy to use OBDTuner with the laptop like keyboard with the bonus of an extra full size USB port so you can charge while logging and you don't have to bother with USB adapters.
I'm now looking at a neat way to make a fixed mount instead of putting it into the side pocket. I've bought a RAM mount which feels really good. The up side is that with this mount I can rotate and angle the tablet freely. The down side is that it might look a bit too "industrial" in some peoples eyes :) Once the tablet is fitted the mount is not visible so I don't think it'll bother me that much.
#1925 phippsy
phippsy
  • 472 posts
Posted 16 September 2016 - 10:23 AM
I only have two weeks left on my road tax before I put the car away in the garage until next year so I'm probably not going to learn a great deal this year. Car drives well on the base map that peter installed onto my ecu so I'm looking forward to seeing any changes once I do the fuel learn. Raining here today but tomorrow looks promising.
I like the sound of your tablet, do you know specifically which model it is as there seems to be quite a few when I was searching. I have seen those RAM mounts, they look good quality and I like the idea of a removable mount. I'm not looking for a permanent mount, id like something I can easily remove.
I'm probably not the first to say it on here, but I think peter might be a genius :)
#1926 smiley
Posted 16 September 2016 - 11:11 AM
Development started in 2008. 1 man job in his atick.
#1927 Jocke_D
Jocke_D
  • 407 posts
Posted 16 September 2016 - 12:23 PM
Couldn't get to an international site but this is it - http://www.asus.com/...sformer-T100HA/
Mine is called [color=rgb(0,0,0);font-family:Arial, sans-serif;font-size:12px;]T100HA-FU030T and has the 128GB hard drive. Absolutely hassle free when it comes to OBDTuner (for me at least). [/color]
There is actually two USB ports when using it in tablet mode. One normal micro and one USB type C. I have only used it with the keyboard attached and then you have another USB port, this one beeing the large old one.
[color=rgb(0,0,0);font-family:Arial, sans-serif;font-size:12px;]Also tried the OBDDash Smiely recomended. [/color]
[color=rgb(0,0,0);font-family:Arial, sans-serif;font-size:12px;]Unfortunately OBDDash wanted a bluetooth dongle and I want to use my USB dongle. So started looking in the garage and found five BT dongles :huh:[/color][color=rgb(0,0,0);font-family:Arial, sans-serif;font-size:12px;] [/color][color=rgb(0,0,0);font-family:Arial, sans-serif;font-size:12px;] Worked like a charm as well. In the Speedster that is, no go in the Saab 9-5 I tried :([/color]
[color=rgb(0,0,0);font-family:Arial, sans-serif;font-size:12px;]I've been in the car trying the RAM mount out a bit but have not yet started to drill in the interior...[/color]
[color=rgb(0,0,0);font-family:Arial, sans-serif;font-size:12px;]My idea is to mount some sort of aluminium sheet to the RAM mount and then use velcro for the tablet. Think that will work fine. That way I can also not only rotate the tablet but also move it around within the rotation (did that make any sense?)[/color]
[color=rgb(0,0,0);font-family:Arial, sans-serif;font-size:12px;]The mount will be permantent in the car but just a little piece of it, the "base ball". The rest will be easy to remove so I'll have to find a good place for the "base ball".[/color]
[color=rgb(0,0,0);font-family:Arial, sans-serif;font-size:12px;]The tablet will also act as navigator and music player for my bluetooth stereo :)[/color]
#1928 ChrisNo/Swe
ChrisNo/Swe
  • 71 posts
Posted 16 September 2016 - 01:09 PM
Have anyone integrated a touchscreen in the dash yet?
Been looking for pictures of such a mod but have not been able to find one.
#1929 phippsy
phippsy
  • 472 posts
Posted 16 September 2016 - 01:27 PM
Have anyone integrated a touchscreen in the dash yet? Been looking for pictures of such a mod but have not been able to find one.
  I think ive seen an integrated one on here somewhere on here. I'm sure someone will be along shortly with more info. Dab of oppo did a custom dash http://www.vx220.org...ashboard-build/
#1930 ChrisNo/Swe
ChrisNo/Swe
  • 71 posts
Posted 16 September 2016 - 01:54 PM
Wow, he went all in with that. Clever ideas though even if it was a bit much for my taste.
Playing with the thought of a oneinall stereo/obd-app/nav screen built in the dash.
I have done a few in the past when i was into car stereos and the modding involved in that.
#1931 smiley
Posted 16 November 2016 - 09:08 PM
Update:
Version 2.7.10 (2016-10-23)
  • Fixed: In the log files the throttle pedal position reached 100% to early.
#1932 Exmantaa
Posted 16 November 2016 - 11:59 PM
Ah, so he now has fixed that. thumbsup
#1933 Jetpilot
Jetpilot
  • 355 posts
Posted 25 December 2016 - 12:04 PM
A question for the wise as i think i will be going down this route in the new year, having bought my harrop done i am not sure of all the mods that i will be required to let Peter know for the base map, injectors, throttle body, cams etc
If i send Peter my current CS mapped ecu can he pull that map and install as the base map with his software on a spare ecu?
Edited by Jetpilot, 25 December 2016 - 12:04 PM.
#1934 smiley
Posted 25 December 2016 - 12:42 PM
Last time, Peter send me this list of questions for a basemap:
-    Engine type: -    Engine compression ratio: -    Desired rev limiter rpm: -    Super charger or turbo type: -    Super charger pulley size or expected (turbo) boost: -    Throttle body: -    Air filter/inlet setup: -    EGR valve connected: -    Injector type (part number): -    Spark plugs: -    Charge cooling setup: -    Exhaust setup: -    Cam shafts: -    Fuel pressure: -    Fuel pressure regulator connected to boost: -    Manifold Air Pressure sensor part number and position: -    Use Temperature sensor in TMAP for measuring intake air temperature: -    Other like cylinder head ported or other important info:
#1935 Jetpilot
Jetpilot
  • 355 posts
Posted 25 December 2016 - 12:52 PM
I am afraid a lot of that i wouldnt know, i will ask him if he can pull the map as it hasnt changed since mapping, but am changing some bits hence why i want this software :)
#1936 Chris P Duck
Chris P Duck
    I can change this?
  • 1,506 posts
Posted 25 December 2016 - 12:57 PM
Who did the conversion? Could probably answer most of that for you assuming it's a stage 2 if we knew who carried out the conversion.
#1937 Jetpilot
Jetpilot
  • 355 posts
Posted 25 December 2016 - 01:01 PM
Its a Harrop done by CS, i have spoken to them but there is lots they dont remember. I have pieced together various info but still unsure on finer details.
Thanks for the help.
#1938 Chris P Duck
Chris P Duck
    I can change this?
  • 1,506 posts
Posted 25 December 2016 - 01:05 PM
Its a Harrop done by CS, i have spoken to them but there is lots they dont remember. I have pieced together various info but still unsure on finer details.   Thanks for the help.
Ok, Harrop will likely have a lot more variety that a simpler stage 2. What bits haven't you got an answer for and perhaps someone can talk you through how to work it out.
Edited by Chris P Duck, 25 December 2016 - 01:05 PM.
#1939 Jetpilot
Jetpilot
  • 355 posts
Posted 25 December 2016 - 01:12 PM
Well for example i can see on receipts, comp cams (no idea which ones), larger throttle body (no idea which one), something about inlet (no idea what), no mention of injectors, engine comp ratio etc etc you get the picture and there is no point guessing. I will message Peter, seems the simplest way if he can pull the current map and install on another ecu :)
Thanks guys
#1940 smiley
Posted 25 December 2016 - 01:26 PM
The current map is a bodged version of what has been out there for years.
I doubt Peter can extract hardware info from that.
Could you not contact Courtenay asking them for a complete spec list?
Edited by smiley, 25 December 2016 - 01:27 PM.
    Google (1)
