obdtuner remap z22se ecu
2116 replies to this topic
#1961 CHILL Gone DUTCH
Posted 26 December 2016 - 04:47 PM
as above just use the software power measurement, theres enough of us the software now to use the software measurements as standard
#1962 Exmantaa
Posted 27 December 2016 - 12:42 AM
I would put some decent 60lbs injectors (Bosch EV14's...) in that engine and start from there. Owww, and fit an unmodified Z22SE fuel pressure regulator back on the rail.
#1963 Jetpilot
Jetpilot
  • 355 posts
Posted 27 December 2016 - 08:20 AM
https://fuelperforma...product_id=5287 Thanks, been looking around today and shall get some ordered, are these the right ones:
#1964 smiley
Posted 27 December 2016 - 10:56 AM
You can download the obdtuner client from the site. (asuming you have a windows pc)
Then download a mapping file from the obdtuner forum to unlock all features.
You will see all available injectors, and their corresponding part numbers in the parameters tab.
And no, siemens is not bosch.
#1965 Jetpilot
Jetpilot
  • 355 posts
Posted 27 December 2016 - 12:56 PM
Why do i need Bosch injectors?
#1966 CHILL Gone DUTCH
Posted 27 December 2016 - 12:58 PM
BOsch a have a better spray pattern
#1967 Jetpilot
Jetpilot
  • 355 posts
Posted 27 December 2016 - 01:00 PM
Any part numbers for whats required?
#1968 smiley
Posted 27 December 2016 - 02:29 PM
Like i said; if you download the client you can have a look yourself.
That will help you get comfortable with it, and see all options we talk about.
#1969 Jetpilot
Jetpilot
  • 355 posts
Posted 27 December 2016 - 02:56 PM
Thanks, although any i can find with that part number are 590cc not 650cc,
#1970 siztenboots
  • 26,613 posts
Posted 27 December 2016 - 03:09 PM
those are Corsa VXR ones, they are 613cc (3bar rail)
#1971 Jetpilot
Jetpilot
  • 355 posts
Posted 27 December 2016 - 03:22 PM
But not 650cc as per above or they run higher because of fuel rail pressure?
#1972 CHILL Gone DUTCH
Posted 27 December 2016 - 06:12 PM
Have you considered getting the Pro version over V2
#1973 CHILL Gone DUTCH
Posted 27 December 2016 - 06:15 PM
FYI i run similar power to you and run the siemens 107961 and running at 88% duty cycle on a harrop with 3.1 pulley
#1974 siztenboots
  • 26,613 posts
Posted 27 December 2016 - 06:20 PM
do you run with much longer duration inlet cams , in which case you can adjust the injector firing , earlier and for longer duration.
#1975 Jetpilot
Jetpilot
  • 355 posts
Posted 27 December 2016 - 06:24 PM
Ok I am now confused, you run the siemens I linked, but recommend bosch and in the parameters section the part numbers dont tally to the cc of either bosch or siemens and sorry I have no idea what pro is over v2, I thought there is only one version of obd.
#1976 CHILL Gone DUTCH
Posted 27 December 2016 - 06:26 PM
There not much longer tbh
#1977 CHILL Gone DUTCH
Posted 27 December 2016 - 06:28 PM
Thats why i used the part number rather than the CC as they can be different dependant on fuel pressure etc etc
i do have the siemens but if i end up needing more injectors i would go for a ev14 bosch version
i you get the details of the injector peter will put it in to the software
#1978 CHILL Gone DUTCH
Posted 27 December 2016 - 06:34 PM
As for the PRO version over V2
PRO is only just completed trials with various users over europe
V2 is very user friendly and you have to do something seriously wrong to do something which will end in disaster
the PRO version is very new infact ive only just got my original ecu back with the customer version on it, there are many advantages to the Pro version but it wont be for everyone V2 would still be a good place to be
i will drop Peter a email and see if he will let me post a PDF i have with what the Pro version has over V2 the best thing for me was turning a lot of the original safe protection systems and running dual maps
#1979 Exmantaa
Posted 27 December 2016 - 09:18 PM
shameless copy/paste:
=> http://www.hptuners....ll=1#post330636
Injector Selection.....and reasons why
The stock injectors are a split pattern dual cone spray injector. There is a huge reason for this, since our motors are a 4 valve design. There is an intake runner splitter right in front of the valves. The proper injector will spray right on the back of both valves for maximum fuel atomization and efficiency....just like the factory injectors does.
And here is a good read too... http://www.usrallyte....ex&cPath=10_44
Problem here is most people slap in the Siemens 60 and 80 pound Deka injectors, which are a single pattern cone spray. This intake split is about an inch and a half away from the tip of the injector, so this single 26* cone is spraying right on the split before it is even broader than an inch. This is very very bad, as it causes the fuel to lose its atomization and leads to fuel pooling in the intake as well as very inconsistent transient fueling. This single factor right here is why the idle is so poor with these injectors. Many people tell me they got their car to idle great with these injectors, and I simply have to call bullshit. No way you can get this style injector to idle as smooth as stock. You can get them to idle OK with no surging, but not perfect.
The injector I chose is a Bosch EV14 injector, part number 0280158123. You have to use an adapter on the nozzle to make it work, but many injector shops have this adapter. They are slightly longer than 60mm(stock length) at 64.5mm, but I had no trouble since the stock fuel rail is at a 45 degree angle. The spray pattern is a split cone 25* just like the factory injector. They flow 60.5lb/hr @43.5psi, and 72.02@58psi which is the stock LSJ fuel pressure. Another good point is the minimum linear pulse width is .711ms, compared to the 1.4 for the Siemens 60's. This is HUGE for our tiny motors, since idle is typically around 1.2, and deaccel is .7ish. My idle is as good if not better than factory right now, and transient fueling is very smooth with these.
More info about the injector I went with: http://www.bosch-mot....2775993867.pdf
I bought them from Fuel Injector Connection in Georgia for about $60 each. That makes them about $100 more than the Siemens, and it is money well spent. Ask for Jon there, and he will know exactly which injectors you need. He will put the tip adapters on them and they will be a direct drop in.
I started with the Siemens 60's, and I can tell you those are a terrible injector for a 4 valve motor. You want the injector to spray on the back of the valves, not at the intake split. Please do some research before you follow everyone else and purchase the Siemens.
Edited by Exmantaa, 27 December 2016 - 09:24 PM.
#1980 smiley
Posted 27 December 2016 - 10:24 PM
Ask him when pro is available  in general and what the pricing will be please?
