Cam Belt Kit Differences
Posted 18 January 2013 - 05:43 PM
Posted 18 January 2013 - 07:00 PM
Posted 18 January 2013 - 07:24 PM
Posted 18 January 2013 - 07:30 PM
Posted 18 January 2013 - 07:34 PM
Posted 18 January 2013 - 07:40 PM
Posted 18 January 2013 - 08:56 PM
Posted 19 January 2013 - 10:42 AM
Posted 19 January 2013 - 10:50 AM
happened to me in an astra, snapped in half the day before it was due to be done by the dealersI've never actually known a belt fail
Posted 20 January 2013 - 01:57 PM
Posted 17 April 2015 - 11:06 AM
I too am in the process of changing my cam belt. Which I am planning to change myself this weekend.
There are 2 kits available:-
- 93174265 (Z20LET up to and including 2003 cars)
- 93185844 (Z20LET 2004)
From the VIN number of my car I have been told to use the 93174265 2003 kit. (This is the second CAM belt change on my car, but I am unsure which kit was used during the change)
From research the only difference between the kits is that one of the idler pulleys is made entirely from metal on the later 2004 kit, where the 2003 kit has plastic ones. Although the metal pulley is the same diameter, it does appear to be 2mm thicker (compared by eye in the shop).
My question is can the later 93185844 2004 spec kit be used on a 2003 spec engine? I am just thinking that they must have moved to a metal pulley for a reason, any would this be a prudent modification.
Posted 17 April 2015 - 11:42 AM
There are 2 types of cam wheel for the Z20LET/H, one is square cut teeth, the other more rounded. You can visually see the difference if you find pics.
Posted 17 April 2015 - 12:14 PM
Cheers Nev,
I should have a good idea what’s fitted when I take it apart later. The chaps at Autovaux were very helpful and said I can exchange the kit if it’s the wrong type.
Posted 17 April 2015 - 12:40 PM
check the tightness of the bolt holding the cam sensor ( between both cam wheels )
Posted 17 April 2015 - 12:46 PM
thanks for the advice mate.
i will be changing the water pump at the same time.
