Airbag Removed - Mot Failure?
Posted 22 January 2013 - 07:01 PM
Posted 22 January 2013 - 07:07 PM
Posted 22 January 2013 - 07:15 PM
Posted 22 January 2013 - 07:18 PM
Posted 22 January 2013 - 07:19 PM
Don't think the opcom can do it. There must be a way of "cheating" it by attaching something to the loom in place of the real connector. It's the same unit as a corsa I think... see if some corsa boys have made something :)/>
I still need to do this as well! It is an mot failure, and I believe a resistor can turn the light off I know their is a thread on here somewhere with information I'm sure someone will be along shortly with info !
Posted 22 January 2013 - 07:20 PM
Posted 22 January 2013 - 07:23 PM
Edited by Stuwy, 22 January 2013 - 07:23 PM.
Edited by vocky, 22 January 2013 - 07:24 PM.
Posted 22 January 2013 - 07:24 PM
Posted 22 January 2013 - 07:25 PM
not if no airbag is installedNot sure if just blanking the lights is acceptable - my understanding from my 'friendly' MOT station is that they need to see the light on when the ignition is turned on, the go out when the engine starts ???
Posted 22 January 2013 - 07:33 PM
But it's also a fail to remove the airbag from a car that came with it as standard, according to the rules. Theoretically, the examiner should look for the startup sequence to check the ABS and airbag lights come on and go off. Clearly, lots don't.
Posted 22 January 2013 - 09:35 PM
Posted 22 January 2013 - 10:54 PM
This rule only came in force in September 2012, so it might simply be a case that not many people have been pinged on it yet.
Posted 22 January 2013 - 11:10 PM
It is a fail if the light is on. I blanked the Airbag and ABS bulbs when I had the Speedo and Rev counter out to change the LEDs.
Not according to my MOT center apparently it's still only an advisory as after anouncing it would become a failure it's never did. Most irritating as I only found out after paying to get it fixed om my shed
Posted 23 January 2013 - 06:40 PM
You're right - the MOT requires the airbag to be fitted if it came as standard on the car and I believe it is all still only an 'advisory', but I can't find any official confirmation of this on line. Any information here would be useful?
I think a lot of this comes down to interpretation by the MOT station and/or the MOT guy who does the actual MOT. I also think it might come down to how friendly they are and/or how well you have made alternative safety provisions, i.e.; full harnesses, etc.
Also tagged with one or more of these keywords: Airbag removed, Seatbelt removed, MOT
General Discussion →
VX220 Discussion →
Supercharged With Or Without Egr?Started by PHB1969 , 02 May 2018 ![]() |
VX220 Discussion →
No Front GrilleStarted by TazN , 27 Jun 2014 ![]() |
Tuning & Modifications →
Radiators - Yet Again!Started by Gopherit , 17 Nov 2012 ![]() |
VX220 Discussion →
Eagle F1 Tyres And MotsStarted by mikegray999 , 20 Sep 2012 ![]() |
De Cat - Advice Please :)Started by green_machineGC , 01 Feb 2012 ![]() |
