7 replies to this topic
Posted 27 January 2013 - 07:13 PM
Coming up ther M40, became aware of strange knocking and rumbling noises over the normal wind noise and radio, and the performance dropped off. I moved over to the left lane, went to touch brakes and realised the pedal was already down further down than normal
Hooked foot up underneath and brought it back up, performance came back, but still has some knocking noises at over 70 mph. All appears to be working although the pedal seems to go down further.
Is there a spring that should pull it back up or is it something more fundamental, Am I likely to have done lasting damage?
Thanks
Tony
Posted 27 January 2013 - 07:14 PM
Have you checked your pads?
May have lost the braking material
Posted 27 January 2013 - 07:16 PM
Yep will check the pads
Posted 27 January 2013 - 07:27 PM
Checked brake fluid level?
Posted 27 January 2013 - 07:32 PM
level is ok,
there was an advisory last mot for the rear disks, So I will change all 4 disks and pads,
I was thinking more in terms of should I change the fluid, Iassume it boiled, should I be worried about excessive heat on thre wheel.bearings and seals
Edited by Tony, 27 January 2013 - 07:36 PM.
Posted 27 January 2013 - 07:38 PM
check if the return spring has not snapped and then caused the breaks to be applied when your driving about...
Posted 27 January 2013 - 07:58 PM
As above, see if the spring has gone on the pedal itself. Easiest thing to check first.
Posted 27 January 2013 - 09:49 PM
oh and other then boiling your fluid because the breaks were applied when driving, you might have warped a disk or overheaed your pads but you said you were changing them so it's a pointless point i just made... also I might of just made it up.. I feel like i know it from somewhere but no idea where
Also tagged with one or more of these keywords: brakes
The Market Place →
Car Parts For Sale →
Front DiscsStarted by Hammy of hamhouse , 18 May 2020 ![]() |
General Discussion →
VX220 Discussion →
Pitted Cl PadsStarted by james.a , 18 Feb 2019 ![]() |
Member Product/Service Reviews →
Bcs Automotive - Brake Calipers Re-FurbedStarted by james.a , 08 Aug 2018 ![]() |
Tuning & Modifications →
Brakes Soft At High Speed?Started by MattMacc123 , 26 Jul 2018 ![]() |
The Market Place →
Car Parts Wanted →
Braided Brake Lines For Rear OnlyStarted by james.a , 13 Jun 2018 ![]() |
