Angel Eyes, My First Chav Mod.
#21
Posted 31 January 2013 - 09:30 AM
#22
Posted 31 January 2013 - 03:24 PM
#23
Posted 31 January 2013 - 04:23 PM
I would like to do this for the rear lights more for people to see you ie in the rain
I'm already working on this, but it could all go tits up yet!
#24
Posted 31 January 2013 - 04:35 PM
When I saw the title I was geared up to hurl some abuse but strangely it looks good. Top job!
same
#25
Posted 31 January 2013 - 06:58 PM
let me know how you get on rusty
Edited by frosty, 31 January 2013 - 06:59 PM.
#26
Posted 31 January 2013 - 07:00 PM
#27
Posted 31 January 2013 - 07:01 PM
#28
Posted 31 January 2013 - 09:36 PM
#29
Posted 31 January 2013 - 10:38 PM
#30
Posted 31 January 2013 - 11:09 PM
#31
Posted 31 January 2013 - 11:39 PM
Edited by smiley, 31 January 2013 - 11:40 PM.
#32
Posted 31 January 2013 - 11:46 PM
Edited by Rusty789, 31 January 2013 - 11:47 PM.
#33
Posted 31 January 2013 - 11:54 PM
I like them! May I ask how you have them wired?
The ledring comes with a + and - wire.
Turn your lamp upside down, and you see the rubber gromet with access to the small sidelight.
Pull it off, and you should see this:
Just pull off the black connectors (remember where each one was, for reverse references)
One of the 2 wires is yellow after a few centimeters. This is your +
The other one is full black and your -
Just create 2 small flat pins on your ledring wiring, and they slide right in.
With some fiddeling, you should be able to keep all wiring inside the headlight casing.
Reverse to original with 2 minutes work.
To connect the ledring to the casing, i would suggest to use double sided tape.
(not sure how long that will last, but glueing was not on my favorite list, due to damage to the casing)
Downside is that when activating main beam, the sidelight is also activated (thus the ledring)
Still working on regulation, on how to use it properly/legal.
Edited by smiley, 01 February 2013 - 12:12 AM.
#34
Posted 01 February 2013 - 12:02 AM
then it'll have to wait 3-10 working days for my rings to be delivered.
I hope you used the ones from my earlier ebay link, as searching for angel eyes you get various versions.
I have another 80mm ring, but as it's slightly wider (8 versus 7 mm), it does not line up as good as the one in my pictures.
Edited by smiley, 01 February 2013 - 12:15 AM.
#35
Posted 01 February 2013 - 12:23 AM
Smashing! Thank you very much!
#36
Posted 01 February 2013 - 07:57 AM
#37
Posted 01 February 2013 - 08:50 AM
Not sure if UK euro regulation is exact same as in NL, but over here:
- DRL (Daytime Running Lights) are allowed oem and after market.
- DRL's may not run together with any of the other lights at the same time. (ie switch off)
- If they do run together, the DRL's have to tone down to 30% of original capacity to be legal.
Still working on all the regulation stuff, so i could be off somewhere.
Wouldn't the simplest option be to use a DRL control module? It would do all the above and aren't a lot of money, 15 to 20 English quids seems to be the going rate.
#38
Posted 01 February 2013 - 09:41 AM
I didn't, I didn't see the link, I just ordered a generic set only cost £6.35 or something delivered, so I wont complain if they don't fit nicely!
Well if they exist thats the easiest option! Tbh when I fit some I will just power them off the sidelights, I can't really see the harm in having a bit more light at the front of the car, and I seriously doubt you'll get pulled over for it (in the UK atleast).
#39
Posted 01 February 2013 - 11:12 AM
#40
Posted 01 February 2013 - 11:23 AM
Does the 30% rule apply to UK?
With it being european legislation... good chance.
