Angel Eyes, My First Chav Mod.
#61
Posted 02 February 2013 - 08:20 AM
#62
Posted 02 February 2013 - 04:23 PM
My inner Chav likes them, how bright are they in daylight?
I can't seem to get on picture what i see with my eyes.
I can see the individual leds, but the camera also without flash, just shows a bright ring.
With citylight on the left:
With main beam and citylight on the left (right does not have main beam fitted)
i'm going to order some H1 and H7 leds also, as i really like the brightness for cheaps.
Edited by smiley, 02 February 2013 - 04:42 PM.
#63
Posted 02 February 2013 - 08:30 PM
#64
Posted 03 February 2013 - 12:52 AM
So the effect is more fairy lights than halo? Would some form of light diffuser ring help? (if indeed you see it as a problem)
Yes and yes.
For myself i just want a visible solution that does not melt the headlight casing.
If your looking for cheap halos to mimic a beemer, this is not it.
#65
Posted 24 February 2013 - 05:22 PM
#66
Posted 24 February 2013 - 06:26 PM
#67
Posted 09 February 2014 - 11:36 PM
The 100mm cannot be trimmed on the inside. It cuts the wiring part when i tried that.
So i cannot get the 100mm to fit flush.
After another search i have found some 95mm ones, that should fit better. (there were no 95mm ones back in early 2013)
They also form a full halo, instead of a bunch of leds.
http://cgi.ebay.co.u...em=191062569019
If that fails to fit, there is also some sort of flexible version i can try:
http://cgi.ebay.co.u...em=251376657237
(they requires some sort of inverter, like included in the kit above)
Edited by smiley, 09 February 2014 - 11:39 PM.
#68
Posted 10 February 2014 - 08:15 PM
These where Pug lights of some form.
aren't they off a 206? or atleast meant for a 206?
#69
Posted 10 February 2014 - 11:13 PM
#70
Posted 11 February 2014 - 02:09 PM
wow, that Speedster looked alot more angry, liked it alot!
#71
Posted 12 February 2014 - 07:49 AM
#72
Posted 12 February 2014 - 09:11 AM
Looks feminine
Feminine, angry....all the same
Edited by smiley, 12 February 2014 - 09:29 AM.
#73
Posted 16 February 2014 - 10:59 PM
I'm with Chris... Hideous. The raised corner at the leading corner of the swage line between wing and upper clam centre section looks horribly awkward & out of keeping with the rest of the car. It also looks like there are inconsistent gaps around some of the radii where the units meet the bodywork. Nasty. Horribly, horribly nasty.I think it looks feckin stupid. Looks feminine
#74
Posted 16 February 2014 - 11:57 PM
#75
Posted 16 December 2014 - 07:23 PM
As mentioned last feb (oh dear; slow modder alert), they now have an (affordable) full halo version.
Result is much better, and the way forward for me.
(ignore the wiring and the yellowness of the rings. This is just a mock up headlight. Rings will be sprayed black to match my tubby light)
For some reason, now the 95mm version is spot on, and the 80mm is just a few mm to small.
Will order the 85mm, and use that set.
Very happy with these.
Sample of the 95mm: http://cgi.ebay.co.u...em=161058846022
And a pixie for once the add is gone.
Edited by smiley, 16 December 2014 - 07:41 PM.
#76
Posted 16 December 2014 - 07:26 PM
Good effort! One of mine fell off and I haven't bothered to split the light and fix it again
So much effort! Fezz needs to get the lights done as well as the lenes!
#77
Posted 16 December 2014 - 07:29 PM
Shenzen rulers. They should stick to electronics.
#78
Posted 16 December 2014 - 07:55 PM
Hmmm, edit rights allready gone.
Ah well. Just wanted to add these are just what i was looking for.
The ring is much thinner in width, and thickness, does not show any leds and shows a full (very white) halo.
#79
Posted 16 December 2014 - 07:56 PM
What did you use to bond them to the headlight?
#80
Posted 16 December 2014 - 10:15 PM
would love that angel eyes with the fezzasus headlights later
