Do you power them at 100 % in normal operation? Most DLR LEDs are operated at 50 % using a PWM to a target brightness and extend the life of the LEDs.
Angel Eyes, My First Chav Mod.
Started by
, Jan 30 2013 09:39 PM
104 replies to this topic
#101
Posted 27 February 2016 - 11:21 AM
#102
Posted 27 February 2016 - 12:30 PM
I have another set of rings coming over and I will measure the pwm (duty cycle) in normal mode of these rings and original hardware. In my new hardware setup lowering the brightness will be done with pwm (lowering duty cycle) and logical behavior with the help of a small arduino.
#103
Posted 20 April 2016 - 11:45 PM
Unfortunately i do like these, could you contact me if you fancy selling a set
#104
Posted 21 April 2016 - 07:48 AM
Hi i stopped working on this for the moment. Some leds are failing.
#105
Posted 21 April 2016 - 08:59 AM
Run them on a lower duty cycle. Most OEMs operate at 50 % duty cycle on full. Drops to ~10-20 % when dimmed for indicators/ dipped beam ect.
Also worth adding a heat strip to the unit to monitor temperatures. Suspect things get quite hot there.
