Project Chill 1
4396 replies to this topic
#1 CHILL Gone DUTCH
Posted 17 February 2013 - 08:41 AM
Ok here goes, I was planning on gathering all the items required to carry out a SC conversion next winter, Which would allow to purchase parts without the other half (wife ) not nojng the real cost of me doing the conversion, I managed to purchase a super charger kit from Ross A bit earlier than expected but there you go the right kit at the right price, first major purchase made and the wife just said I was stupid. ( I agreed) The wife will probably be the biggest factor or problem in this small project.
Edited by Chill, 17 February 2013 - 08:42 AM.
#2 CHILL Gone DUTCH
Posted 17 February 2013 - 08:45 AM
Yesterday after a short run to Wrexham and back I discovered coolant on front wing Worst scenario broken/ split rad Best scenario Hose or bleed nipple
#3 CHILL Gone DUTCH
Posted 17 February 2013 - 08:48 AM
After a bit of investigation I did not locate where the coolant was coming directly from, With help from George we discovers coolant under the rad in the channel running towards front of car, I think worst scenario rad gone
#4 CHILL Gone DUTCH
Posted 17 February 2013 - 08:51 AM
Could this be a opportunity not to be missed, My Mrs is really looking forward to highland hoon So, Looks like a new rad is needed before then I also have Cadwell booked,MOT due and was also planning on getting the engine rebuilt Unless someone has a proven low mileage engine available
#5 CHILL Gone DUTCH
Posted 17 February 2013 - 08:57 AM
I've managed to convince the wife to do the hole project before the highland hoon including SC As the front clam has to come of to change rad anyway I could fit charge cooler etc at the same time, My wife still has no clue of the costs Here is my plan so far, The rad leak is minimal Do Cadwell MOT Engine rebuild or new engine SC conversion. With a lot of help from George and members on here Peaks meet A other track day Highland hoon
Edited by Chill, 17 February 2013 - 08:58 AM.
#6 CHILL Gone DUTCH
Posted 17 February 2013 - 09:07 AM
I bought my Silver VX in April last year at a ridiculous low price, it is a Catergory car but I don't care, the damage was minor and documented. after a summer of meets I was hooked by the people and the car. My first track day in the VX at blyton helped to make my mind up that I wanted a more track day focused car which I could still enjoy meets. Whilst at blyton the car went through around 1-2 litres of oil so this problem needs to be fixed first.
#7 CocoPops
CocoPops
  • 17,182 posts
Posted 17 February 2013 - 09:10 AM
Will you do the sc work yourself? And engine?
#8 CHILL Gone DUTCH
Posted 17 February 2013 - 09:11 AM
Going to take a few pics of the car now. and really other than tires and brake pads how I bought the car. The only major difference in the car compared to the way I bought it is the major Rash on the front from nelly and mani Thanks for that
#9 CHILL Gone DUTCH
Posted 17 February 2013 - 09:13 AM
Me and George are going to do the Sc conversion our selves but I don't no enough about internals of engines to do it my self
#10 CHILL Gone DUTCH
Posted 17 February 2013 - 09:14 AM
I do think I'm going to need some coaching from fellow orgers on the SC conversion
Edited by Chill, 17 February 2013 - 09:14 AM.
#11 G-Bob
G-Bob
    Embarrassing VX's in an MX5
  • 8,256 posts
Posted 17 February 2013 - 09:18 AM
Good luck with the conversion Chill. Is the leak a bad one or are you at least able to use the car at the moment?
#12 CHILL Gone DUTCH
Posted 17 February 2013 - 09:32 AM
I did blyton with it and using it when ever I can,
So very minor water levels are not dropping much
Infact if I ha dent seen a bit of coolant in the wing you wouldent of noticed from levels in header tank
Edited by Chill, 17 February 2013 - 09:33 AM.
#13 ArticMonkey
ArticMonkey
  • 4,792 posts
Posted 17 February 2013 - 10:21 AM
Good luck with the conversion, wish I'd done mine from scratch. If your rebuilding the engine then speak to vocky for sure! He has a price to take the engine out, rebuild, and fit again. It's not ££££ either. :) IMO if I was taking my engine apart I'd at least get all the chains done and possibly stretch to forged rods so your safe for 280bhp. Even go the whole hog and get a fully forged engine ;) Good luck.
#14 JohnTurbo
JohnTurbo
    SuperScruff
  • 3,635 posts
  • Interests:Performance cars!
Posted 17 February 2013 - 10:32 AM
Ive both clams off mine, and Im balls deep into the conversion if you wanted to bob over for a look Chris.
#15 vocky
Posted 17 February 2013 - 10:42 AM
You should decide what bhp you want from your car before spending any money on the engine, if you are happy with 250bhp then try and get a complete low mileage z22se engine and fit that. But you will need to replace both chain kits on any engine you use, unless they have been very recently changed (they are all due for replacement due to being at least ten years old), look out for the later spec z20net chain tensioner with the bulge.
#16 CHILL Gone DUTCH
Posted 17 February 2013 - 10:47 AM
Chains need doing on mine was going to get done with rebuild.
#17 Nelly Vx
Nelly Vx
    3/3 Of a Queen
  • 5,928 posts
Posted 17 February 2013 - 10:48 AM
If you need a hand Chris just ask :-)
#18 CHILL Gone DUTCH
Are you working on car next weekend, all experience is good
#19 CHILL Gone DUTCH
Posted 17 February 2013 - 10:50 AM
Cheers nelly was going to ask about your cooling setup
#20 Nelly Vx
Nelly Vx
    3/3 Of a Queen
  • 5,928 posts
Posted 17 February 2013 - 10:51 AM
It's working fine bud :-)
