Project Chill 1
4396 replies to this topic
#2061 Nev
Posted 01 June 2015 - 04:52 PM
WTF are you talking about, I made a unique change to my car only, noticed an unexpected improvement from it and mentioned it as it might help someone on here. Nowhere in any of that work did I read something online. It was a pure side effect from my own experimentation.
Edited by Nev, 01 June 2015 - 04:55 PM.
#2062 Kieran McC
Kieran McC
  • 3,416 posts
Posted 01 June 2015 - 04:53 PM
at least its lighting up the thread  but would like you now to take it else where
#2063 fezzasus
Posted 01 June 2015 - 04:59 PM
uh...
it is common place to counter balance axel weights with ballast on front/rear biased cars, and has been done numerouos times to great effect over the years, from Hillman Imps to Porsches.
#2064 leevx2.2
leevx2.2
  • 4,830 posts
    getting p!!sed
Posted 01 June 2015 - 05:03 PM
lmfao  why does suspension always cause  arguments lol
#2065 The Batman
Posted 01 June 2015 - 05:06 PM
Quantums are for gays Discuss :lol:
#2066 fezzasus
Posted 01 June 2015 - 05:07 PM
Discuss
:lol:
it's why they're purple
Can't be the colour, purple is a man's colour.
Edited by fezzasus, 01 June 2015 - 05:08 PM.
#2067 The Batman
Posted 01 June 2015 - 05:08 PM
Exactly!
#2068 Kieran McC
Kieran McC
  • 3,416 posts
Posted 01 June 2015 - 05:09 PM
Never to be Chills thread again lol
#2069 chris_uk
Posted 01 June 2015 - 06:00 PM
i think it was this
"[color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]Get back in your box you cantankerous arse, I know more about [/color]VX220[color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;] [/color][color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]handling than most of the people on here"[/color]
#2070 Mr Apex
Mr Apex
  • 320 posts
  • Interests:Karting, climbing, skiing, boxing, cycling
Posted 01 June 2015 - 06:01 PM
Positive thoughts on how you could improve your lap times - Looking at the videos, a lot of the time you could probably have been one gear higher and used the torque to achieve similar acceleration. The combination of engine braking and high power at high revs looked as though it was tricky to manage, particularly with other cars around. I don't know the track, but if you look at the area where you downchange to third, then straight to second over the crest, your apex speed is much lower than it needs to be. Then you hit the gas and wheelspin on exit. You also come completely off the throttle suddenly on fast corners, rather than blending out as you turn in, so you are putting a significant change in forces through the chassis and tyres, just as the car is about to load up into into the corner. Track driving is about smooth....
Not saying I could actually have done any of the above if I was driving - your car is more of a beast than mine and I have no idea how manageable it is.
#2071 chris_uk
Posted 01 June 2015 - 06:08 PM
oh look... i found a box.
#2072 CHILL Gone DUTCH
Posted 01 June 2015 - 07:48 PM
Ok just a little update,
shocks are going to Gaz tomorrow so they can dyno test them, they are ridiculaSLY soft ( not like before) despite having heavy springs on them, when at angelsey the knobs would not budge and didnt want to risk breaking somthing half way through a trackday
i managed to free them off today ( the more you turn them the loser they seem to get )
going to take them off the car tomoz and record where each shock came off the car and send them off
It would also appear the RSRs took a real battering at angelsey wearing the inside edge of the drivers front right down and the outer edge of the drivers side,
so its time for some new tires i think i will be going for a set of 888 next not the R888R
Edited by CHILL Gone DUTCH, 01 June 2015 - 07:49 PM.
#2073 chris_uk
Posted 01 June 2015 - 08:04 PM
id have a look at your geo aswell then, sounds like too much camber
#2074 Bargi
Bargi
  • 4,483 posts
Posted 01 June 2015 - 08:35 PM
first put an 1 inch anti roll bar on set it to max ,will make a big difference then if you still are not happy change the shocks .
^ what he says
#2075 leevx2.2
leevx2.2
  • 4,830 posts
    getting p!!sed
Posted 01 June 2015 - 08:42 PM
To much camber ? don't think Chris is running that much camber  .RSRs  i would say a few people have had similar problems the side walls to soft .
#2076 CHILL Gone DUTCH
Posted 02 June 2015 - 04:33 PM
Must say I have had these fronts on the car for 2 1/2 years so they owe me nothing
And have been a good tire
It will go some way in explaining the lack of turn in and corner speed
And wash out if you push to hard in the
I think I also mention the inside of the drivers side is a lot worse than this
This pis shows the hole tire
And you can see the tread is completely gone compared with other side
Edited by CHILL Gone DUTCH, 02 June 2015 - 04:37 PM.
#2077 leevx2.2
leevx2.2
  • 4,830 posts
    getting p!!sed
Posted 02 June 2015 - 04:36 PM
2 1/2 years you tight arse lol
#2078 CHILL Gone DUTCH
Posted 02 June 2015 - 04:38 PM
Yes Your right it seemed to wear down quickly at Anglesey as I never noticed it until after but I may of missed it
#2079 CHILL Gone DUTCH
Posted 10 June 2015 - 11:21 AM
Little update 4 new tires delivered Shocks are back from Gaz ARB ordered Need to make time to get the car ready for a croft track day
#2080 oakmere
oakmere
  • 2,143 posts
Posted 10 June 2015 - 07:46 PM
What had happens to the shocks Chill I can't believe all 4 failed at the same time. Were you turning the knob the correct way😂
Edited by oakmere, 10 June 2015 - 07:46 PM.
12 user(s) are reading this topic
0 members, 12 guests, 0 anonymous users
