Project Chill 1
4396 replies to this topic
#2081 CHILL Gone DUTCH
Posted 10 June 2015 - 07:52 PM
Knobs wouldn't move either they were solid But they were quite soft ( the shocks ) even when I got home and managed to turn them with tools on to the hardest stiffest setting The clicks are more clicky now and seen to locate a lot better before they were quite smooth and you didn't really no where you were on the clicks I think I'm going have to save up for sone different ones
Edited by CHILL Gone DUTCH, 10 June 2015 - 07:58 PM.
#2082 Captain Vimes
Captain Vimes
  • 2,755 posts
Posted 10 June 2015 - 08:16 PM
The rsr's I've replaced have always been because of worn edges (inner and/or outer). I ran higher pressure's at Anglesey and had increased camber. It helped a bit and I think the 1" ARB will help some more. I'm going to try different tyres next time. Maybe the nankang ns2r or Avon zzs.. I'll be interested how you find the tyre wear on the rsr's. I've only got 3 track days from the rears but they're pretty dead now.
Edited by Captain Vimes, 10 June 2015 - 08:17 PM.
#2083 CHILL Gone DUTCH
Posted 10 June 2015 - 09:37 PM
The rears which are on now 235 wide have done 3 track days and quite a few road miles and are just above wear markers The fronts have been on a long time 2 1/2 years and only noticed the shoulders at Anglesey they passed a mot a month before I suspect the shocks have played a part I did surfer with bad bump steer which was there before but not as bad as it was at Anglesey
Edited by CHILL Gone DUTCH, 10 June 2015 - 09:39 PM.
#2084 The Batman
Posted 10 June 2015 - 09:52 PM
My front 888s have done 3 trackdays and 1k miles and insside is on wear markers which I'm blaming on the geo setup or lack off!
#2085 CHILL Gone DUTCH
Posted 10 June 2015 - 09:57 PM
the tire wear rate has deffo increased since i had the geo last year
Edited by CHILL Gone DUTCH, 10 June 2015 - 09:57 PM.
#2086 The Batman
Posted 10 June 2015 - 10:36 PM
Sorry I made a mistake it's the outside that has worn down :lol:
#2087 CHILL Gone DUTCH
Posted 11 June 2015 - 12:14 AM
Its the inside of the drivers side which has gone and the outside of the passenger side (RHD) put this down to right hand bends
#2088 CHILL Gone DUTCH
Posted 18 June 2015 - 06:39 PM
Going to get some work done on this over the weekend,
1" ARB
Refit the rebuilt/refurbed shocks
new drop links
ive got four new tires to go on
give the car a good once over ready for croft on the 25th july
Oh and the kids have got me a shift light for fathers day so should at least have a look at how im going to do that which im hoping to do before croft
Edited by CHILL Gone DUTCH, 18 June 2015 - 06:42 PM.
#2089 CHILL Gone DUTCH
Posted 22 June 2015 - 03:31 PM
ARB is on but it took ages to remove the old one lol Anyway front end all back together now Just got to swap shocks on the rear and fit the shift light And then change the tires ready for going to see my mate at croft 😜
#2090 CHILL Gone DUTCH
Posted 01 July 2015 - 03:52 PM
well its that time again to buy brake pads,
The last set were RC6 which have lasted a little longer than the RC5+ pads i had last time (1 track day RC5+)
Has anyone had any experience with the pagid range im after a pad which will last longer or as long as the RC6.
The RC6 definitely didnt have the byte of the RC5+ pad
so im after some information on these two types of pad
Pagid RS14 Brake Pads[color=rgb(50,50,50);font-family:Arial, Helvetica, sans-serif;font-weight:bold;background-color:rgb(204,204,204);] [/color]
Pagid RS42 Brake Pads
is one a more endurance pad than the other
and what differences is there in these pads
i have no experiences with the paigid range so any info would be great #
Edited by CHILL Gone DUTCH, 01 July 2015 - 03:54 PM.
#2091 Captain Vimes
Captain Vimes
  • 2,755 posts
Posted 01 July 2015 - 04:10 PM
I thought the rs42 was supposed to be more durable. I run the RS14 and get 5/6 trackdays from the fronts, rears are still on and going strong. Does your ARB squeak?
#2092 Acidpopstar
Acidpopstar
  • 3,556 posts
Posted 01 July 2015 - 04:16 PM
I've had two sets of RS14s and can't fault them. Great initial bite, good resistance to fade on track and fine for road use. The CL6s I moved to possibly have longer endurance on a long track session but initial bite is not a good. As far as I know the RS42s are not as track focussed a pad as RS14s. Full details on the Pagid website of course
#2093 CHILL Gone DUTCH
Cheers for the info captain My car has not moved since putting the ARB on So not sure if it squeaks or not
#2094 CHILL Gone DUTCH
Posted 01 July 2015 - 04:18 PM
Looks like the RS14 are worth a try However it's worrying that they don't last as long as the rc6
Edited by CHILL Gone DUTCH, 01 July 2015 - 04:19 PM.
#2095 CHILL Gone DUTCH
Posted 01 July 2015 - 04:21 PM
Some people may laugh but none of the RC range had the byte I had from the mintex 1155
#2096 Zoobeef
Zoobeef
    Joes bedroom assistant.
  • 11,103 posts
Posted 01 July 2015 - 04:27 PM
Have you got cooling to your from brakes to try and lower the pad wear?
#2097 CHILL Gone DUTCH
Posted 01 July 2015 - 04:29 PM
I'm going to remove fog lights and put some cooling in As this seems to be the secret of getting pads to last longer
#2098 Kieran McC
Kieran McC
  • 3,416 posts
Posted 01 July 2015 - 04:42 PM
Ferodo DS 2500 pads what are these like ? Ducting via the fog lights keeps the discs a lot cooler certainly noticed a difference.
Edited by Kieran McC, 01 July 2015 - 04:50 PM.
#2099 Zoobeef
Zoobeef
  • 11,103 posts
Posted 01 July 2015 - 05:33 PM
It'll be a cheapish mod to do but you probably won't know for sure if it makes a difference unless you use the same pads again. I found there was to many combinations of other pads and didn't know what was worse or better so stayed with RC6S. May look again at performance friction once these run out but that will be in a year or so time.
#2100 CHILL Gone DUTCH
Posted 01 July 2015 - 05:46 PM
I'm going to fit brake before croft with the old rc6 on the car but unless it's significant better I will have to change pads at the track 👍
