yes put loads on i have never had a problem mine is well lubed up
Project Chill 1
#2121
Posted 04 July 2015 - 03:30 PM
#2122
Posted 04 July 2015 - 03:50 PM
#2123
Posted 04 July 2015 - 05:13 PM
#2124
Posted 05 July 2015 - 09:43 AM
With the 1" ARB and the nylatron mounts from EP make sure you ream out the mounts so the bar fits snug, but not clamped tight, when the bar and nylatron mounts are inside the horseshoe-shaped piece that holds it together. Not too hard, just take your time before bolting it onto the car to make sure it can rotate smoothly inside the mounts.
Normally the hole in the nylatron mounts tend to be a little under-sized and that means that when it's all pushed into the mount and done up the bar gets clamped down hard and it won't rotate freely. Also this means that any movement gives a squeeking/grinding noise.
#2125
Posted 05 July 2015 - 10:44 AM
#2126
Posted 05 July 2015 - 11:20 AM
I've just sent you a PM nick Did you change the pressure range when you put the smaller pulley on ? Also you need to Follow this Just thought I would share this for anyone who is running out of graph in pressure range and needs to change the pressure range So when you increase the pressure range from 12-240 to 13-260, it will make your engine run about 8% leaner. To compensate, you can simply select the whole fuel table by right clicking and clicking select all. Then use Edit->Edit selection % and make it 8% richer. For the ignition I would lower the whole table around 1-2 degree and then recalibrate it using the power measurement tool.it didnt like that much,, when to do a fuel learn session, ended up p1514, cylcing of the throttle 1500-2000 rpm rough running tried to upload a log but too big so the board keeps saying..
#2127
Posted 08 July 2015 - 09:21 PM
#2128
Posted 08 July 2015 - 09:24 PM
#2130
Posted 11 July 2015 - 04:07 PM
#2131
Posted 11 July 2015 - 04:15 PM
Chris What is the ID of the hole?
Its around 58mm
but the clam has a lip on the inside which will allow me to jubilee clip some ducting to probably up to 70mm if its flexible enough
i may find something solid to sit inside the hole so the jubilee clips dont crush the clam
#2133
Posted 13 July 2015 - 06:29 PM
#2134
Posted 13 July 2015 - 07:18 PM
nice new shiny tyres pal
#2135
Posted 19 July 2015 - 04:12 PM
Edited by CHILL Gone DUTCH, 19 July 2015 - 04:13 PM.
#2136
Posted 19 July 2015 - 04:29 PM
#2137
Posted 20 July 2015 - 03:00 PM
Funny I had the same issue a couple of days ago, did a repair but bot happy with it really, wonder if I can get another port and extend the wires to somewhere on the pax side as you said fixed under the dash.And also my wires on the obd port on the car have parted company so I've also repaired that I'm going to do something with the port maybe with a solid backing as it's just floating around at the moment and adding the software plug all the time and it hanging must be taking its toll on the wires
#2138
Posted 20 July 2015 - 04:43 PM
#2139
Posted 20 July 2015 - 04:45 PM
#2140
Posted 20 July 2015 - 04:47 PM
6 user(s) are reading this topic
0 members, 6 guests, 0 anonymous users
