Yes but it's still hanging from under dashCant you use Blue- tooth instead of a cable ?
I will probably put it in here
Posted 20 July 2015 - 04:58 PM
Posted 20 July 2015 - 06:16 PM
Posted 20 July 2015 - 07:26 PM
Posted 21 July 2015 - 08:43 AM
Edited by NickB777, 21 July 2015 - 08:57 AM.
Posted 22 July 2015 - 07:02 PM
Posted 22 July 2015 - 07:07 PM
Posted 22 July 2015 - 07:09 PM
Posted 22 July 2015 - 08:29 PM
Posted 24 July 2015 - 07:34 AM
Suppose now I'm putting air under wheel arches I should do something to let it out
There's a big arch shaped hole in the outside of the clam. I suspect the air will escape there! If not you're welcome round to make your own louvres.
Posted 24 July 2015 - 09:18 AM
Sounds like a plan When I stop working stupid hoursThere's a big arch shaped hole in the outside of the clam. I suspect the air will escape there! If not you're welcome round to make your own louvres.Suppose now I'm putting air under wheel arches I should do something to let it out
Posted 24 July 2015 - 12:27 PM
May be a stupid question but do you have to remove the arch liners for these louvres to have any effect at all?
Posted 24 July 2015 - 12:35 PM
Or modify them.
Unless you simply want the louvres for aesthetic reasons
Posted 24 July 2015 - 01:04 PM
Posted 24 July 2015 - 01:20 PM
Posted 24 July 2015 - 01:23 PM
Right. I'd never have them purely for aesthetic reasons. So a hole in the top of the arch liner is the usual method? Guess you just have to put up with (more) crap getting in.
mesh them, otherwise your paintwork will be peppered with grit etc
Posted 24 July 2015 - 01:31 PM
Posted 24 July 2015 - 01:53 PM
Personally I see little point in them, the wheel arch itself is a massive vent hole.
Posted 25 July 2015 - 07:04 PM
im back from croft and the car is a complete different animal from Anglesey
it took a while to get used to how much better the car turned in
it really was night and day from angelsey
Edited by CHILL Gone DUTCH, 25 July 2015 - 07:09 PM.
