next video i was getting more used to it
Edited by CHILL Gone DUTCH, 25 July 2015 - 07:26 PM.
Posted 25 July 2015 - 07:25 PM
Posted 25 July 2015 - 07:50 PM
there wasent much room when i over took the porsche around 9 mins, between him and the cones
it was a bit naughtey but he didnt move over enough but there was space
Posted 25 July 2015 - 08:05 PM
first time since putting the harrop on that i didnt change the brake fluid between track days and the car did suffer a bit
Posted 25 July 2015 - 09:02 PM
Edited by haggi961, 25 July 2015 - 09:02 PM.
Posted 25 July 2015 - 09:04 PM
Was good fun today and gave me the kick again to get mine done. Cheers for the pax ride.
you were the only one brave enough to get in with me
Posted 25 July 2015 - 09:16 PM
Posted 25 July 2015 - 09:22 PM
they were fine captain
didnt push to hard on them today
took advice and used 30 psi rear and 29 front and grip was great
Posted 25 July 2015 - 09:25 PM
What tyres was that psi in?
How are your brakes?
Posted 25 July 2015 - 09:28 PM
got a long peddle a few times after 10 mins ish
brakes are shot didnt do as many runs as i usually do
but luke can comment on brakes
but i did manage angelsey and croft on one set
Posted 25 July 2015 - 09:29 PM
29 front hot
30 rear hot
Posted 25 July 2015 - 09:33 PM
So still have quite high wear even with cooling?
I mean which make as I found those pressure good on 595s but had to go much lower on 888s!
Posted 25 July 2015 - 09:35 PM
ive never run pressures that high
but they work very well
Federals RSRs
brake cooling wasent delivered in time
Edited by CHILL Gone DUTCH, 25 July 2015 - 09:40 PM.
Posted 25 July 2015 - 09:39 PM
Posted 26 July 2015 - 05:43 AM
Posted 26 July 2015 - 05:10 PM
Good to see a positive result Chill. The car certainly looked like it was confidence inspiring
Yes it ran well nev, dont think i got anywhere near the potential of the car but i am getting there,
Posted 26 July 2015 - 05:23 PM
Reflection on croft:
car was 100% better, turn in was amense i was getting more confident mid corner, i couldent get the long right hander going in to the left kink right all day the left kink was very hard to get on the power unless i went in past the first bale very slow
i did lose the brake peddle a couple of times. i should of bled the brakes before i went, the consensus was i wouldent need to do it every track day lol.
bringing the power down did help me through the day
new tires were great
ARB made the car very pointy which took a bit of getting used to which did cause the rear to be mor skitish under heavy braking
the ads are now finished
i didnt do as much time on the track as i normally do which has helped to help with brake wear
very happy and think it is a good first step to find the limits of what the car can do, then i can think about running more power but at the moment im happy with its power which was reduced to around 345 hp
Posted 26 July 2015 - 07:00 PM
