Project Chill 1
4396 replies to this topic
#2181 CHILL Gone DUTCH
Posted 26 July 2015 - 07:03 PM
345 BHP is certainly a meaty shove in the backside, I didn't realise you were running so much power till I looked at you flying by those others on the track.
put the harrop on over last winter
was running more power but i dont want need it yet
#2182 Captain Vimes
Captain Vimes
  • 2,755 posts
Posted 26 July 2015 - 07:50 PM
Car is looking nice and settled in the video. The brake fade and wear is an interesting one. Is part of the issue in driving technique? Tuition could make a bigger difference than brake cooling. It'll be good to see your car at Snetterton. The speed down the back straight should be interesting!
Edited by Captain Vimes, 26 July 2015 - 07:50 PM.
#2183 CHILL Gone DUTCH
Posted 27 July 2015 - 04:00 PM
pic from croft 25-07-2015
#2184 Exmantaa
Posted 27 July 2015 - 05:00 PM
Any log done on your IAT temps on track?  :glare:
#2185 CHILL Gone DUTCH
Posted 27 July 2015 - 05:04 PM
never got chance at the weekend but this was from a warm sunny day at angelsey
is this similar to what you were expecting ??
#2186 CHILL Gone DUTCH
Posted 29 July 2015 - 06:48 PM
ok with croft just a few days ago it time to start the prep for zaandvoort
brake pads
bleed brakes
brake cooling
add fuel
catch the ferry
#2187 chris_uk
Posted 29 July 2015 - 10:02 PM
RF1000 was the brake fluid i was talking about.
#2188 CHILL Gone DUTCH
Posted 01 August 2015 - 06:35 PM
Managed to get a few pics from croft
#2189 CHILL Gone DUTCH
Posted 14 August 2015 - 06:14 PM
Temps were through the roof at zaandvoort today They were in the late 80s after 2 laps maybe a few extra after the dinner break I also met Peter and his other half today Estimated the car loses around 50-60 hp at these temps It was very very hot today and I physically felt the lack of power But it was still a cracking day
#2190 Acidpopstar
Acidpopstar
  • 3,556 posts
Posted 14 August 2015 - 06:20 PM
When you fitting the water injection? :)
#2191 CHILL Gone DUTCH
Posted 14 August 2015 - 11:04 PM
Asap
#2192 CHILL Gone DUTCH
Posted 17 August 2015 - 12:48 PM
Well zaandvoort was epic Didn't go 100% smooth 2 mins before leaving the charge cooler pump relay packed in which put us back a hour Day of coming home water got in the the spark plug hole in the head and got a massive misfire Easy fixes but wished they haven't happened. The inlet temps on track were through the roof and the car was considerably slower than previous UK track days ( probably a good job as I was still hitting over 140 mph down the pit straight The front brakes were a lot better and had little wear The rear brakes still had heavy wear so I'm guessing the brake ducting has really helped cool the front brake which in turn has helped keep the brake pads from wearing out quickly The rear wheels were covered in brake dust but the fronts hardly had any on them
#2193 Zoobeef
Zoobeef
    Joes bedroom assistant.
  • 11,103 posts
Posted 17 August 2015 - 12:56 PM
Glad that's sorted then! Now how do you sort the rears. Air from the ears ducted through or extra naca ducts underneath ducted through?
#2194 CHILL Gone DUTCH
Posted 17 August 2015 - 01:00 PM
I would like to use 2 small naca ducts as I need all the air I can get through the engine bay
#2195 CHILL Gone DUTCH
Posted 17 August 2015 - 01:01 PM
I also think the lack of power could of been down to the fuel in Holland
#2196 CHILL Gone DUTCH
Posted 17 August 2015 - 01:03 PM
Me and lee turning into the chuckle brothers I also like the bit when lee tried to slow the car down by putting his hands up 😜
#2197 smiley
Posted 17 August 2015 - 01:05 PM
WUT?
Our 98ron is not good enough for you?
#2198 The Batman
Posted 17 August 2015 - 01:07 PM
the texaco garage which is closest to the track is 102 ron
#2199 sford
sford
  • 1,454 posts
Posted 17 August 2015 - 01:10 PM
Could you go for a naca duct in the lower area under the ear in the sill, with the tubing going past where the hard brake lines (passenger side, not sure what's on the driver's side) are and then out of the fiber glass inside the wheel arch away from the wheel and toward the brakes?
Or have one higher up and coming in through the top of the arch liner? Think you would need the feed forward of the brake disc so the air path is in one direction and not trying to turn back on itself.
See crudely drawn photos stolen from google below.
If you could get the duct to match the color of your car then it would be relatively subtle.
Edited by sford, 17 August 2015 - 01:19 PM.
#2200 CHILL Gone DUTCH
Posted 17 August 2015 - 01:18 PM
I didn't know that joe ( wish I did ) @ smiley as soon as I filled up in the UK the car came alive
