Project Chill 1
4396 replies to this topic
#2261 CHILL Gone DUTCH
Posted 13 September 2015 - 05:43 PM
went out for a little blast today and all is not good
would seem zandvoort has taken its toll on the car didnt really want to have to take the clam off before snetterton but looks like its coming off so i can stop the car from melting
as you can see the manifold has got very hot and melted all the heat shield on the inside of the boot
so ive ordered some nimbus and exhaust wrap
i didnt want to wrap the manifold on the exhaust as i figured i wanted as cool as possible to prevent cracking the manifold
not really what i wanted before snetterton but owning these cars dont always go to plan
#2262 The Batman
Posted 13 September 2015 - 06:24 PM
Just fit nimbus behind it bud No need to wrap it then IMO I suggest wrapping the u bends tho
Edited by The Batman, 13 September 2015 - 06:24 PM.
#2263 vocky
Posted 13 September 2015 - 06:35 PM
no need to even remove the clam, just add nimbus like this;
#2264 Kieran McC
Kieran McC
  • 3,416 posts
Posted 13 September 2015 - 06:38 PM
Chris time to get the angle grinder out rear clam vents required as well.
#2265 CHILL Gone DUTCH
Posted 13 September 2015 - 06:47 PM
Not sure I will be able to get it like that Vocky unless I take the clam off But that's what I will do @ Kieren I'm not cutting my clam
#2266 oakmere
oakmere
  • 2,143 posts
Posted 13 September 2015 - 07:51 PM
I have also added two little heat shields either side of the manifold. I made mine out of alloy with heat proof matting but nimbus should work better. Did you add any extra under tray vents?
Edited by oakmere, 13 September 2015 - 07:52 PM.
#2267 CHILL Gone DUTCH
Posted 13 September 2015 - 08:10 PM
Yep I added one But thinking I need a other one near the down pipe
Edited by CHILL Gone DUTCH, 13 September 2015 - 08:11 PM.
#2268 CHILL Gone DUTCH
Posted 15 September 2015 - 07:17 PM
Making a slight modification to my PCV system to reduce the vacuum pressure, as the Harrop seems to be producing  lot of vacuum in the PCV system
restrictors are these little beauty
just need a minor mod to make one of them work
#2269 The Batman
Posted 15 September 2015 - 07:30 PM
Have them on some machines at work :lol:
#2270 CHILL Gone DUTCH
Posted 15 September 2015 - 07:31 PM
but do you no what there for
:D
#2271 GeorgeBC
GeorgeBC
    Needs a cheaper hobby
  • 3,138 posts
Posted 15 September 2015 - 07:44 PM
Pneumatic non return valve with a flow restrictor on it, you think that will work??
#2272 CHILL Gone DUTCH
Posted 15 September 2015 - 07:58 PM
Yes unless you can tell me why not
#2273 The Batman
Posted 15 September 2015 - 08:16 PM
They make things go faaaaaaaaast or slooooooow
#2274 Zoobeef
Zoobeef
    Joes bedroom assistant.
  • 11,103 posts
Posted 15 September 2015 - 08:20 PM
Shouldn't that be fst or slllllloooooooooow?
#2275 The Batman
Posted 15 September 2015 - 08:27 PM
I said faaaaaast like 2 faaaaaaaast 2 furrrrrious
#2276 The Batman
Posted 15 September 2015 - 08:28 PM
But mainly because I'm mid argument because I won't let Ella drive my car at national lol
#2277 ArticMonkey
ArticMonkey
  • 4,792 posts
Posted 15 September 2015 - 08:31 PM
Let her drive it at Bedford. I need some competition . ;)
#2278 The Batman
Posted 15 September 2015 - 08:33 PM
Probably would be quicker as she doesn't have to rebuild it if it breaks :lol:
#2279 SteveA
SteveA
  • 9,156 posts
Posted 16 September 2015 - 08:35 AM
Probably would be quicker as she doesn't have to rebuild it [color=#ff0000;]when[/color] it breaks :lol:
Sorted that for you :P
#2280 Exmantaa
Posted 16 September 2015 - 08:56 AM
Making a slight modification to my PCV system to reduce the vacuum pressure, as the Harrop seems to be producing  lot of vacuum in the PCV system...
How do you reckon that happens? Vacuum is created in the intake manifold with closed throttle plate (and open bypass valve), so Harrop is doing not a lot at that moment.
But it creates more boost pressure, so more bypass gasses to the crankcase that need improvements to the breathing system...
