Edited by CHILL Gone DUTCH, 16 September 2015 - 09:15 AM.
Project Chill 1
#2281
Posted 16 September 2015 - 09:14 AM
#2282
Posted 16 September 2015 - 01:49 PM
Maybe I should bring melissa along so your Mrs can convince her that cars are a good thing and tracks are great. I can't convince her to come out as a passenger on the road let alone on track or drive it. On second thoughts my headache will be less as I'm not bringing herBut mainly because I'm mid argument because I won't let Ella drive my car at national lol
#2283
Posted 23 September 2015 - 04:07 PM
Chris, I notice on the throttle tab of OBDT there is a drop down menu with a 'sport' option. Have you tried it or modified anything on this tab?
#2284
Posted 23 September 2015 - 05:04 PM
Yes I've played with this quite a bit to get the LS4 smoother But not used the sport throttle mapChris, I notice on the throttle tab of OBDT there is a drop down menu with a 'sport' option. Have you tried it or modified anything on this tab?
#2285
Posted 23 September 2015 - 06:59 PM
Emm might give it a go just to see if I notice the difference.
#2286
Posted 23 September 2015 - 08:07 PM
Let me know how you get on with itEmm might give it a go just to see if I notice the difference.
#2288
Posted 23 September 2015 - 09:29 PM
#2289
Posted 23 September 2015 - 10:53 PM
Oh snap!
#2290
Posted 24 September 2015 - 01:55 PM
It makes a big differance on my N/A but to aggressive for me. The SC softens the throttle response so it might feel ok.Emm might give it a go just to see if I notice the difference.
#2291
Posted 29 September 2015 - 02:15 PM
Edited by CHILL Gone DUTCH, 29 September 2015 - 02:21 PM.
#2292
Posted 29 September 2015 - 02:18 PM
#2293
Posted 29 September 2015 - 02:19 PM
#2294
Posted 29 September 2015 - 05:45 PM
Nice one Chris you've clearly done a cracking job with your engine build. Your car will be a beast once it handles as well as it accelerates.
Water injection is defo the way forward for inlet temps as I've proved. Make sure you get Aquarist system and talk to Crabash about how he installed mine.
#2295
Posted 03 October 2015 - 02:38 PM
#2296
Posted 03 October 2015 - 02:55 PM
Haha, isn't the trick to try and stop spending! Somehow I've managed it for a year now and it makes the car seem like value for money !Time to make time for the winters spending 😜
#2297
Posted 03 October 2015 - 02:58 PM
Hopefully after this year Nev when I've got the car behaving as I want it in the corners and get the throttle control where I want it I can start to think about just adding fuel 🚙💨 I've accepted to enjoy these cars to the max you have to spend the cashHaha, isn't the trick to try and stop spending! Somehow I've managed it for a year now and it makes the car seem like value for money !Time to make time for the winters spending 😜
Edited by CHILL Gone DUTCH, 03 October 2015 - 03:01 PM.
#2298
Posted 03 October 2015 - 03:53 PM
Sort the handling out yourself. I'd highly recommend DIY geo, where you experiment with settings, road test, then itterate. You can set the car up how YOU want it, it's satisfying, costs £0 and you will learn how you can change settings to suit conditions. I spent about 3 weeks (did about 10 iterations), learnt a lot and according to others VX220 owners who have driven it, it has more grip than their own and very neutral hanlding. On a wet roundabout, it breaks traction perfectly at all 4 corners and drifting it is easy. Even when I was on track I could drift it "quite" safely. I'd recommend at least new drop links on the front ARB, or better still a "moderately" uprated front ARB. Then set the ride hights as close to OEM as you can (or change the hub carriers). Then set castor to how you'd like the wheel to return to centre, then set camber to about -0.5 front, -2.5 rear for the road (but go further for more tracking), finally set toe ins. I find that last setting really affects high speed stability, even +/- 2mm is noticeable. It's easy, really. Just takes a bit of time.Hopefully after this year Nev when I've got the car behaving as I want it in the corners and get the throttle control where I want it I can start to think about just adding fuel 🚙💨 I've accepted to enjoy these cars to the max you have to spend the cashHaha, isn't the trick to try and stop spending! Somehow I've managed it for a year now and it makes the car seem like value for money !Time to make time for the winters spending 😜
Edited by Nev, 03 October 2015 - 04:00 PM.
#2299
Posted 03 October 2015 - 04:08 PM
#2300
Posted 03 October 2015 - 11:08 PM
What's the problem with throttle control Chris?Hopefully after this year Nev when I've got the car behaving as I want it in the corners and get the throttle control where I want it I can start to think about just adding fuel I've accepted to enjoy these cars to the max you have to spend the cashHaha, isn't the trick to try and stop spending! Somehow I've managed it for a year now and it makes the car seem like value for money !Time to make time for the winters spending
