How many MM did you mill off the blocks and how much camber are you considering? Is your car just for track Chill, or do you use it on the road ?
Edited by Nev, 16 December 2015 - 10:15 AM.
Posted 16 December 2015 - 10:11 AM
Posted 16 December 2015 - 10:23 AM
Posted 16 December 2015 - 12:05 PM
Never needed that on the rears for my camber settings (~ -2.5°), but my front arms have some mm's shaved off.
Posted 16 December 2015 - 12:36 PM
Are you modifying the steering arms? You wont get 2 degrees with standard.
I fitted ep steering arms and with no shims only have 2 degrees.
Posted 16 December 2015 - 05:51 PM
yes ive got the steering arm with full bump steer kit
Posted 16 December 2015 - 07:30 PM
What % do you drive on the road ? -2.5 degrees camber is very severe for the tyre wear if you do any straight line driving...
Posted 16 December 2015 - 07:32 PM
Posted 16 December 2015 - 07:35 PM
Posted 16 December 2015 - 07:49 PM
Ive ran 2.5 neg rear camber for years and my tyres have always worn evenly. Not loads of road miles and mainly used on track but it's done at least one euro trip each year, driven to each track and the highland hoon, it's if you use it daily that kills the tyres. Interested to see how mine wear now with 3.2 deg rear camber.What % do you drive on the road ? -2.5 degrees camber is very severe for the tyre wear if you do any straight line driving...yes ive got the steering arm with full bump steer kit
Posted 17 December 2015 - 08:29 PM
1.998mm was taken off each one. I left the tiny bit so they could go on a surface grinder to take out the machine marks if necessary. I don't think they need it though.How many MM did you mill off the blocks and how much camber are you considering? Is your car just for track Chill, or do you use it on the road ?
Posted 18 December 2015 - 04:18 PM
1.998mm
whats 0.002mm between friends
Posted 18 December 2015 - 04:23 PM
Joes cock?
Posted 18 December 2015 - 04:27 PM
thats in total
Posted 20 December 2015 - 02:57 AM
Rear tyres are much more tolerant of neg camber for sure, its the fronts that don't wear well in my experience.
Edited by Nev, 20 December 2015 - 02:57 AM.
Posted 22 December 2015 - 04:44 PM
ive had the call
@nev i always lose the shoulders of the tyre before the general tread across the tire
Posted 23 December 2015 - 01:00 PM
Posted 23 December 2015 - 01:48 PM
crocs ffs!
Posted 23 December 2015 - 02:09 PM
steel toed no doubtcrocs ffs!
Posted 23 December 2015 - 02:12 PM
crocs ffs!
