Project Chill 1
#2361
Posted 23 December 2015 - 02:41 PM
#2362
#2363
Posted 01 January 2016 - 06:43 PM
Also got a magnetic bracket for my tablet similar to Haggies
Started to put the bushes in
Just need to get the new ball joints on the wishbones and then start getting them on the car
I've already removed the radio to save a little bit of weight from the car but I'm going to make a major weight saving which is me the driver who currently stands at 16.5 stone ( 104 kg ) and my first target is 15 stone ( 95 kg ) before Feb when the car goes back on the road
So wish me luck with that .
#2364
Posted 01 January 2016 - 07:07 PM
#2365
Posted 01 January 2016 - 07:23 PM
#2366
Posted 01 January 2016 - 08:06 PM
#2368
Posted 02 January 2016 - 02:56 PM
#2369
Posted 02 January 2016 - 03:02 PM
Those are the bolts that hold the hub into the upright. 210nm is for the M16? bolt that goes through the centre of the front hubs on the NA - not fitted to the turdo as they can't corner as quickly.What are the three wheel bearing bolts described as on this list
#2370
Posted 02 January 2016 - 03:08 PM
#2371
Posted 02 January 2016 - 03:11 PM
Yep the m16 front wheel bearing bolt is 210nm which isn't needed on the N/a or turbo model. It's has no purpose and just added extra weight. The 3 M12 x1.5 x 45mm Fine Pitch bolts are 90mn and need lock thread.Those are the bolts that hold the hub into the upright. 210nm is for the M16? bolt that goes through the centre of the front hubs on the NA - not fitted to the turdo as they can't corner as quickly.What are the three wheel bearing bolts described as on this list
#2372
Posted 02 January 2016 - 03:39 PM
Dunno. That depends on what bolts you were looking for.So the answer is 90 NM as Haggie suggested
#2373
Posted 02 January 2016 - 03:40 PM
Not necessarily so. Look at Arno's numerous explanations as to why it's there and why Elise Parts sell it as an upgrade for later cars.It's has no purpose and just added extra weight.
#2374
Posted 02 January 2016 - 03:46 PM
Ive bought this it wasent cheap
do you have a link to arno explanation ?
#2375
Watch out how you wire that up.
I fitted three of those a few years ago but got rid of them as they permanently use power, if they're connected to a permanent live, irrespective of if anything is plugged into them (and the blue LED always glowing is annoying). I ended up reverting to a 12v lighter socket on the passenger side and two more expensive versions of those USB sockets on the drivers side and in place of the standard cigarette lighter that only consume power when something is connected to them. Won't be an issue if you only connect them to an ignition switched power source but worth bearing in mind if you're replacing the standard permanently live cigarette lighter socket.
#2376
Posted 02 January 2016 - 03:55 PM
This will be wired up front on its own fuse via a relay switched from a switched feed, going to keeep the 12v cigarette,
yep there is a blue LED which is permanently lit up GBC has installed one and says his battery has not got dead after 4 weeks so cant have a great draw on it but dont want to risk it if somthing gets left plugged in
#2377
Posted 02 January 2016 - 04:15 PM
I ended up using a black permanent marker to colour the LED in to dull it a bit when I used to have it mounted in the sill covers.
7 user(s) are reading this topic
Bing (3)
